Author Topic: [IC] KAM Wraith  (Read 369191 times)
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #50 on: Tue, 04 September 2018, 05:24:24 »
Totally willing to try out KAM for this set.
I'll try to get samples soon™
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #51 on: Thu, 06 September 2018, 08:16:37 »
Hey :)
Some small kits update on the first post of the thread
'Caps Lock' legend changed to 'Extend Mode' (in reference to ZX Spectrum +, thanks for the suggestion) which avoids confusion between 'caps shift' and 'caps lock'.
With some additions:
ps: spacebars are convex (in the ortho kit too)
Someone suggested me to make an alternative version of the alphas without sub legends, let me know what do you think of it:
I'm also working on ISO kits, I don't know if I wanna make a NorDeUk kit or separate kits (ISO UK, ISO INT, etc.), any thoughts?
I'm planning to work on a blank kit too…
And, second question: What is your opinion about making regular modifiers for control, alt and super (or whatever you wanna name it)?
Btw, if someone has a color swatch and a ZX Spectrum, pm me please :thumb:
« Last Edit: Thu, 06 September 2018, 08:51:13 by biip »
Offline EightDiagram
Re: [IC] KAM Wraith
« Reply #52 on: Thu, 06 September 2018, 08:53:54 »
Looking good!
Do you know if 6u spacebar is offset stem or centered?
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #53 on: Thu, 06 September 2018, 09:04:13 »
Looking good!
I'll ask Keyreative, since I really wanna go KAM!
(so you could edit your signature… ;D)
Offline monkt
Re: [IC] KAM Wraith
« Reply #54 on: Thu, 06 September 2018, 10:22:42 »
I think the Mono option looks great, and I hope it gets offered.
I know these profiles are new, but has anyone here had any hands-on experience with KAM/KAT? What's the texture supposed to be like relative to other sets?
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #55 on: Thu, 06 September 2018, 10:29:54 »
KAM is basically KAT r2.
I own a KAT set and I have to say that it's really pleasant to use. It's thick and smooth, not too tall (compared to SA)…
Offline Kavik
Re: [IC] KAM Wraith
« Reply #56 on: Thu, 06 September 2018, 10:42:30 »
Looks really good. Interested.
Re: [IC] KAM Wraith
« Reply #57 on: Thu, 06 September 2018, 11:02:28 »
Looking good!
 :)) doh...fixed!
Offline konstantin
  • Formerly constexpr
Re: [IC] KAM Wraith
« Reply #58 on: Thu, 06 September 2018, 11:35:32 »
That's R3 in standard row notation (top to bottom). Simply put, the home row.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #59 on: Thu, 06 September 2018, 13:31:15 »
Well according to the side view from Zfrontier website it’s row 2 (row 4 for us).
Source
But yeah it’s basically the flat keycaps from KAT set.
Offline elfick
  • Can I get Colemak and a side of fries with that?
Re: [IC] KAM Wraith
« Reply #60 on: Thu, 06 September 2018, 14:13:05 »
I'm really digging the mono alphas and would probably choose them over the original. I'd like to see regular modifiers would look like.
Offline joe405
Re: [IC] KAM Wraith
« Reply #61 on: Thu, 06 September 2018, 22:32:42 »
Ooh have KAT sets already been produced? I thought it was just the alpha set which finished the GB recently.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #62 on: Fri, 07 September 2018, 01:11:51 »
I’m talking about the alpha yea :)
Offline Neodeus
Re: [IC] KAM Wraith
« Reply #63 on: Fri, 07 September 2018, 11:32:29 »
Interest!  :p :p :p :p :p :p :p :p :p
Offline jebbra
  • jebbra.net
Re: [IC] KAM Wraith
« Reply #64 on: Sat, 08 September 2018, 01:28:13 »
Really dig the busy looks! One thing that I still not sure is the arrow design. It kind of off-design having them in stetched style.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #65 on: Sat, 08 September 2018, 02:46:26 »
Well it’s inspired by the orignal ones. It’s kinda different from the other keycaps we usually see IMO.
Offline myyrddraal
Re: [IC] KAM Wraith
« Reply #66 on: Sat, 08 September 2018, 03:05:17 »
Please don't stride away from speccy. It will loose the charm and become totally uninteresting for those riding the nostalgia wave.
Offline jebbra
  • jebbra.net
Re: [IC] KAM Wraith
« Reply #67 on: Sat, 08 September 2018, 04:14:07 »
Ah you're right. I was saying that because I don't see the arrows on the OG keyboard but when I look again they're printed on the case instead on the keycaps, my bad.
Offline jmg123
Re: [IC] KAM Wraith
« Reply #68 on: Sat, 08 September 2018, 06:35:49 »
The mono alphas look a bit dull, love the look of the non mono ones though
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #69 on: Sat, 08 September 2018, 08:59:21 »
Here is a try on light alphas
Offline myyrddraal
Re: [IC] KAM Wraith
« Reply #70 on: Sat, 08 September 2018, 15:33:30 »
While esthetically it's not the worst thing, somehow it does not make any sense with the speccy basic keywords in the non-speccy colors.
Offline dededecline
    • Linktree
Re: [IC] KAM Wraith
« Reply #71 on: Sat, 08 September 2018, 15:35:06 »
Agreed
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #72 on: Sat, 08 September 2018, 18:05:00 »
What do you mean? I basically inverted the dark blue gray with the white.
Offline helix999
Re: [IC] KAM Wraith
« Reply #73 on: Sat, 08 September 2018, 19:17:04 »
Beautiful set! The more I look at the renders the more I like it. Not crazy about the mono alphas as I think the charm of this set lies in the legends. Undecided on the light alphas. Although they do look interesting I think there's enough going on with this set that I'd stick with dark gray alphas.
Either way hope this happens, most def in for a set.
Offline myyrddraal
Re: [IC] KAM Wraith
« Reply #74 on: Sat, 08 September 2018, 19:18:39 »
Which is not the original ZX Spectrum color. It looses the resemblance to Original Sinclar ZX Spectrum thus you don't need any of the Basic keywords printed on caps.
As I said, it's still quite nice design, but not Speccy anymore. I would not mix them into one. Maybe the white one without the keywords just keeping the font...
Offline Zilleon
Re: [IC] KAM Wraith
« Reply #75 on: Sun, 09 September 2018, 00:14:28 »
Loved the Alpha Mono, I would go with that.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #76 on: Sun, 09 September 2018, 05:56:40 »
I agree with that opinion. I mean, it doesn’t look bad, but it’s just too different, and not in the theme anymore.
Yeah, I shouldn’t make too many sets, don’t wanna lose the spirit of my original idea.
Offline OracleKev
Re: [IC] KAM Wraith
« Reply #77 on: Mon, 10 September 2018, 00:31:53 »
If the sample looks anywhere near the renders, I'm in!
Also heard good things about KAT incl. tactile feel department, I've yet to try myself but have high expectations.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #78 on: Mon, 10 September 2018, 03:08:13 »
I'll try to order them asap since most of the people seem happy with the alphas and modifiers.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #79 on: Mon, 10 September 2018, 07:38:10 »
2.5 u convex spacebar added.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #80 on: Tue, 11 September 2018, 08:19:49 »
Poll results: 300 responses
How do you like the keyset so far?
Love it, would buy!: 245 (81,7%)
Would buy with some changes: 39 (13%)
I like it but I won't buy it: 16 (5,3%)
I don't like it: 0 (0%)
Is KAM profile ok for you?
Sure!: 255 (85%)
I'd prefer XDA: 31 (10,3%)
I'd prefer another uniform profile: 14 (4,7%)
Which kits would you buy?
Alphas: 277 (92,3 %)
Modifiers: 213 (71 %)
Specialities: 142 (47,3%)
40bit: 49 (16,3%)
Ergo: 47 (15,7%)
Addons: 113 (37,7%)
Ortho: 84 (28%)
Numpad: 66 (22%)
Colevrak: 28 (9,3%)
Arrows: 90 (30%)
NorDeUk: 28 (9,3%)
Spacebars: 70 (23,3%)
Blanks: 28 (9,3%)
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #81 on: Tue, 11 September 2018, 17:59:42 »
Arrows kit update
  • VIM
  • WASD
  • HHKB
« Last Edit: Tue, 11 September 2018, 18:02:12 by biip »
Offline eas
Re: [IC] KAM Wraith
« Reply #82 on: Tue, 11 September 2018, 20:12:15 »
Well since Symbiosis drops CADR I really hope this is a success. For my sake.
Down for 2
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #83 on: Thu, 13 September 2018, 05:32:14 »
ISO NorDeUk kit added, and small update on arrows kit.
« Last Edit: Thu, 13 September 2018, 05:37:50 by biip »
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
Re: [IC] KAM Wraith
« Reply #84 on: Thu, 13 September 2018, 06:25:56 »
Loving the ISO addition. I’m 100% in
Sent from my iPhone using Tapatalk Pro
Offline Kristof
Re: [IC] KAM Wraith
« Reply #85 on: Fri, 14 September 2018, 10:10:50 »
Looks awesome. Love that you added NORDKIT!
Joined geekhack from reddit for this keycap set and 1 custom keyboard.
Will be definitely ordering this.
Who will be the EU proxy? I might have seen candykeys posting a picture about this, but i might be wrong
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #86 on: Sat, 15 September 2018, 01:47:49 »
Hey! Glad you enjoy the project! Candykeys is definitively interested to be the EU proxy so yeah it should be it.
Offline 5inn3d-
Re: [IC] KAM Wraith
« Reply #87 on: Sat, 15 September 2018, 02:20:11 »
@ts any indication on pricing?
interested to get this kit & may hold off getting other keycaps to save for this  :)) :eek:
Offline Kawamashi
Re: [IC] KAM Wraith
« Reply #88 on: Sat, 15 September 2018, 08:56:35 »
Great news !!!
Offline young_won
Re: [IC] KAM Wraith
« Reply #89 on: Sun, 16 September 2018, 19:43:03 »
I want to one more 3u space bar
https://geekhack.org/index.php?topic=97289.0
Lynx L50 requires two 3u space bar.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #90 on: Mon, 17 September 2018, 02:13:21 »
That would depend a lot of the interest on that addition to be honest. At this moment I only had 1 suggestion (adding 3u spacebar)…
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #91 on: Tue, 25 September 2018, 15:59:47 »
Quick update, I should receive 3d files next week or so in order to make more accurate renders :thumb:
Keyreative will also be available next month so I might order some samples.
Offline dededecline
    • Linktree
Re: [IC] KAM Wraith
« Reply #92 on: Tue, 25 September 2018, 16:09:43 »
Does this mean we can probably expect November GB start?
Offline AuthenticDanger
Re: [IC] KAM Wraith
« Reply #93 on: Tue, 25 September 2018, 16:50:57 »
Eager to see samples. Multi-color reverse dye sub legends seem tricky, but if they're sharp, this is a really interesting idea.
F Keys belong on the left.
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #94 on: Tue, 25 September 2018, 18:10:24 »
This will depend on the quality of the samples. Legends have to be sharp, clean and centered. I don’t wanna hurry and launch a GB with an unperfect product :)
Offline dededecline
    • Linktree
Re: [IC] KAM Wraith
« Reply #95 on: Wed, 26 September 2018, 10:54:56 »
Agreed, definitely don't want it to be rushed! I'm just confirming that it won't happen in October, so that sounds good.
Offline portbaron
Re: [IC] KAM Wraith
« Reply #96 on: Wed, 26 September 2018, 14:20:40 »
I love the gray color  keys. How is this different than XDA?
| LIVING THE 1800 LIFE |
Offline biip
    • @biipmk
Re: [IC] KAM Wraith
« Reply #97 on: Thu, 27 September 2018, 01:21:18 »
It's not flat. It's basically taller and thicker DSA
Offline portbaron
Re: [IC] KAM Wraith
« Reply #98 on: Thu, 27 September 2018, 02:05:26 »
Noice
Offline Data
Re: [IC] KAM Wraith
« Reply #99 on: Fri, 28 September 2018, 07:22:49 »
Awesome.
