Author Topic: MassDrop CTRL PCB  (Read 3019 times)
Offline umalip
MassDrop CTRL PCB
« on: Thu, 13 September 2018, 11:04:15 »
Do you know if the the massdrop CTRL PCB be used in another TKL case?  Or a sandwich case?  I have my eye on an acrylic TKL and a Carbon Fiber TKL sandwich case.  And was wondering if I could move the PCB into another case in the future.
Offline schoolbus
Re: MassDrop CTRL PCB
« Reply #1 on: Thu, 13 September 2018, 11:59:54 »
probably not there is no standardized TKL screw layout.
Offline axios67
« Reply #2 on: Mon, 17 September 2018, 22:41:02 »
this most likely
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Tue, 18 September 2018, 10:45:10 »
What's the point? The CTRL was designed to pretty much be an all-in-one aluminum RGB keyboard.
