Author Topic: What are Your fingers for CNTR+c and CNTR+x  (Read 9449 times)
Offline test157
« on: Wed, 28 April 2010, 16:10:23 »
what are your fingers for CNTR+c and CNTR+x if you are using caps lock instead of control?
CNTR+z - 5 + 4
CNTR+x - 5 + 3
CNTR+c - 5 + 2
CNTR+v - 5 + 2
or
CNTR+z - 5 + 4
CNTR+x - 5 + 4
CNTR+c - 5 + 3
CNTR+v - 5 + 2
Offline itlnstln
« Reply #1 on: Wed, 28 April 2010, 16:14:54 »
For either Ctrl position, I use my pinky on Ctrl and my index to press C, V, etc.
Offline test157
« Reply #2 on: Wed, 28 April 2010, 16:21:56 »
and for c without control u still use index finger? or next to it finger?
Offline ch_123
« Reply #3 on: Wed, 28 April 2010, 16:29:46 »
I just feel sorry for Mac users who have to use Command for everything. For the most important key in the Mac OS, they picked a stupid place to put it :p
Offline itlnstln
« Reply #4 on: Wed, 28 April 2010, 16:30:11 »
I press the C key with my index finger at all times.  This might be bad typing form on my part, though.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #5 on: Wed, 28 April 2010, 16:31:10 »
For those key strokes, I prefer the conventional Ctrl location.
Offline ch_123
« Reply #6 on: Wed, 28 April 2010, 16:37:48 »
Quote from: itlnstln;177005
Make sense to me, I use pinky and second as well. Far more comfortable from the real position because you don't have to do a contortionist act for stuff like Ctrl - S
Offline test157
« Reply #7 on: Wed, 28 April 2010, 16:41:03 »
so middle finger for cntr+S?
Offline ch_123
« Reply #8 on: Wed, 28 April 2010, 16:49:19 »
'Cue', even.
Offline nanu
    • http://T-T.be/portal
« Reply #9 on: Wed, 28 April 2010, 16:51:15 »
Quote from: test157;176993
CNTR+z - 5 + 4
CNTR+x - 5 + 3
CNTR+c - 5 + 2
CNTR+v - 5 + 2
or
CNTR+z - 5 + 4
CNTR+x - 5 + 4
CNTR+c - 5 + 3
CNTR+v - 5 + 2
looks like a bunch of unsimplified math to me i don't know what you're trying to say whats with the 5 on every line
Offline test157
« Reply #10 on: Wed, 28 April 2010, 16:53:57 »
5 = Pinky finger
4 = Next to pinky
3 = middle finger
2 = index finger
so CNTR+v - 5 + 2 means that to press CNTR+V you are using Pinky + Index Finger
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #11 on: Wed, 28 April 2010, 16:56:49 »
What's a CNTR key?
kishy.ca
Offline test157
« Reply #12 on: Wed, 28 April 2010, 16:57:44 »
Control?
Offline didjamatic
« Reply #13 on: Wed, 28 April 2010, 16:59:55 »
Ctrl+z - 1 + 1
Ctrl+x - 1 + 1
Ctrl+c - 1 + 1
Ctrl+v - 1 + 1
j/k.  I use pinky for Ctrl, ring for Z, middle for X, index for C and V
Offline test157
« Reply #14 on: Wed, 28 April 2010, 17:02:11 »
Quote from: ripster;177030
Hint:  This is the guitarist version.
Looks like it's the version I used:
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #15 on: Wed, 28 April 2010, 17:10:16 »
Quote from: test157;177036
Control?
I know, I was poking fun at how it was referenced quite incorrectly in the OP.
Poking fun, not trying to be a nuisance, but I bet I did that too.
kishy.ca
Offline hyperlinked
« Reply #16 on: Thu, 29 April 2010, 06:24:58 »
Quote from: ch_123;177003
Aack! Not having access to the "command" key as my main modifier key is my biggest headache when I'm on Windows. I think the command key spot is a much better spot for the main modifier key because you can use your thumb to hold it down.
It's only a stupid location if you use your pinky to hit it. If you use your thumb, it's actually way easier than using a pinky on any of the modifier keys because it's pretty close to home position for your thumb and since your four fingers share some common musculature, your reach and dexterity is affected if any one of them needs to be used to hold down a button while you reach with the other ones.
To the OP, this will seem funny, but I do have CTRL mapped to my caps lock, but I usually use the pinky CTRL reach for common CTRL commands because I'm so used to it and also I find it easier to on my hands when doing shortcuts with my left hand only. If I do shortcuts with my right hand, I use the caps lock remapped CTRL key because then it's less stressful for my hands.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline ch_123
« Reply #17 on: Thu, 29 April 2010, 06:27:34 »
The problem with using your thumb is that it requires you to take your hand out of the usual typing position moreso than is necessary. The Caps Lock key would be a much more useful place for it.
Offline Mental Hobbit
« Reply #18 on: Thu, 29 April 2010, 06:53:50 »
Don't know about OS X, but the classic MacOS had the most common functions such as copy&paste on F-keys too. Isn't this kinda what F-keys are for? After ten years on Win, I still roll my eyes every time I have to create a new folder via mouse menu.
Typing on blues.
Offline hyperlinked
« Reply #19 on: Thu, 29 April 2010, 07:13:34 »
Quote from: ch_123;177194
I guess it depends on what keyboard you're using, but my hands rest very comfortably on home row with my thumb on the command key on just about any current day board I can think of. I don't have any vintage boards to compare against.
On the caps lock, the position is ok. It's better in some ways and not as good in other ways. I'd still prefer using my thumb because it's a stronger appendage and using it won't amplify flexor tendon tension because of the lack of shared musculature with the other fingers. My hands hurt when I overuse the capslock control key.
« Last Edit: Thu, 29 April 2010, 07:16:55 by hyperlinked »
Offline hyperlinked
« Reply #20 on: Thu, 29 April 2010, 07:20:11 »
CH, you know what also matters is hand positioning. I'm just now realizing that I use a slightly altered hand position. My forearms are angled in like I'm using an ergo keyboard, but I adust for the offset in finger positioning by extending some fingers more than others. This lets me rest my thumb straight over the command key without any reach.
My hands move a lot when I type. I don't leave home row much, my hands and elbows pivot all the time to change the angle of reach depending what I'm doing.
If I adopt a standard typing posture where your hands are supposed to be parallel on the keys, the command key is indeed hard to reach.
« Last Edit: Thu, 29 April 2010, 07:24:47 by hyperlinked »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #21 on: Thu, 29 April 2010, 07:50:49 »
Quote from: Mental Hobbit;177196
F-keys were application-based (running application dictated what they did) for the longest time and it's something I'd like to see make a comeback. Probably won't, though.
kishy.ca
Offline D-EJ915
« Reply #22 on: Thu, 29 April 2010, 21:13:46 »
I use my index finger and pinky (on caps lock key).  Just a holdover from gaming and browsing the web lol.
Offline aegrotatio
« Reply #23 on: Fri, 30 April 2010, 09:54:39 »
My pinky has been using the caps lock for control for so many years it's reflexive.  Unfortunatly it means I'm left trying to find keyboards that have full-width caps lock keys.
This cramps my style as I have yet to find a full-width caps lock for my extensive Model M collection.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline bhtooefr
    • bhtooefr.org
« Reply #24 on: Tue, 04 May 2010, 08:32:11 »
I use my pinky for Ctrl, and index for C. Sometimes I use my index for X, sometimes my middle finger.
Offline ironcoder
« Reply #25 on: Tue, 04 May 2010, 08:40:25 »
I was taught to use the left thumb on control and the index finger for C or X, etc. Works for me.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline hyperlinked
« Reply #26 on: Tue, 04 May 2010, 10:05:22 »
Quote from: ironcoder;178771
Ouch! You must have long fingers. That's a hell of a long reach. Doesn't that hurt after a while? Even just the reach for my thumb on the Apple command key makes my thumb hurt sometimes. I started substituting my own alternates for command key shortcuts until I realized that I could get my flexor tendons to hurt even faster than I could get my thumb to hurt by relying on the CTRL key in place of the commmand key.
Offline ironcoder
« Reply #27 on: Tue, 04 May 2010, 10:25:59 »
Does it hurt? I have no idea. I've been at it so long I have no feeling in my hands.
In all seriousness I don't notice it at all.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #28 on: Tue, 04 May 2010, 10:34:44 »
Humm... Ctrl: Pinky, X: Middle, C: Index
« Last Edit: Tue, 04 May 2010, 19:02:57 by TheSoulhunter »
A Ghost From The Past
Offline noctua
« Reply #29 on: Tue, 04 May 2010, 10:49:32 »
i type ctrl ever with smallest finger (4 or d), then dependend on action..
 - x (2)
 - c (1)
 - v (1)
Selfmade Keyboard I (done)
DT225 CH Trackball
Selfmade Keyboard II (95% completed)
L-Trac CST2545W-RC Trackball
both use Cherry MX Blue switches, an Teensy++ controller and have an Colemak layout
Offline zXWF
    • http://www.gnu.org
« Reply #30 on: Tue, 04 May 2010, 11:00:02 »
Thumb for "Alt", smallest finger for "Ctrl"
:: Lemote YeeLoong / FuLoong :: Loongson :: gNewSense ::
Free Software Foundation Europe
GNU Operating System
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #31 on: Tue, 04 May 2010, 11:10:37 »
CTRL: Left pinky...pinkie?
Modified key: left index, regardless of which key, supposing it's left of about the Y/H/B "column".
kishy.ca
Offline test157
« Reply #32 on: Tue, 04 May 2010, 14:00:17 »
if you all use index finger for C button, so what is your finger for S and D key when you use it with Control key?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #33 on: Tue, 04 May 2010, 14:06:37 »
Quote from: test157;178889
Same...
kishy.ca
Offline D-EJ915
« Reply #34 on: Tue, 04 May 2010, 19:08:33 »
ahahaha F5
Offline bhtooefr
    • bhtooefr.org
« Reply #35 on: Tue, 04 May 2010, 19:57:17 »
There also needs to be a P, for saying things are CP.
Offline bhtooefr
    • bhtooefr.org
« Reply #36 on: Wed, 05 May 2010, 04:38:28 »
Spam post reported.
