Author Topic: [GB]ChicoryBLE-wireless 40% keyboard(100% Shipped)  (Read 38601 times)
Offline oldcat
  • 65% is Life
Re: [GB]ChicoryBLE-wireless 40% keyboard(50%Shipped)
« Reply #50 on: Sat, 09 February 2019, 15:01:18 »
Has anyone managed to find a battery that fits the case? If so, can you provide a link? I’ve been searching but had no luck with the dimensions.
This should fit: https://www.amazon.com/1200mAh-battery-Rechargeable-Lithium-Connector/dp/B07BTSPZW8
or: https://www.amazon.com/ADAFRUIT-INDUSTRIES-1578-Lithium-Polymer/dp/B00L0W61VO
or: https://www.amazon.com/battery-Rechargeable-Lithium-Polymer-Connector/dp/B07BTSL7Z8
The slot dimension is 115mm X 40mm X ~5mm (depth is 4mm but it can be a bit higher than that)
Offline neon_tom
« Reply #51 on: Sat, 09 February 2019, 15:10:41 »
Oh perfect, thanks! I was going by the 4mm depth from the OP and that’s what was causing me issues in my search.
Offline oldcat
  • 65% is Life
« Reply #52 on: Sat, 09 February 2019, 17:08:28 »
guys make sure you connect the red cable to the +(positive) side
some batteries have the two cables' sides reversed and you will need to be careful.
Offline VXQN
« Reply #53 on: Sun, 10 February 2019, 10:50:36 »
I was on the fence about getting this at the time of the drop, and ended up springing for a preonic instead. After seeing the latest photos (as well as realising that ortho is not really for me), boy am I regretting that decision! I'd certainly appreciate the chance to purchase an extra whenever they become available!
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #54 on: Mon, 11 February 2019, 15:56:26 »
Yes, same here, if no extras, any plans for rd2?
Offline prod
« Reply #55 on: Thu, 14 February 2019, 08:58:34 »
WOW, Thanks so much old cat!
Chicory|YDPv2(BLUP)|BLE40|Daisy|YDPM|YD40w|Golbat
Offline prod
« Reply #56 on: Thu, 14 February 2019, 09:07:11 »
I am so happy you guys like ChicoryBLE, extras will come out for sale after all GB finished shipping, you can join ALF discord #40chicory channel for news.
Re: [GB]ChicoryBLE-wireless 40% keyboard(75% Shipped)
« Reply #57 on: Thu, 14 February 2019, 09:45:53 »
Thanks, just joined your discord
Offline heedpantsnow
  • Old enough to know better
« Reply #58 on: Mon, 25 February 2019, 08:03:43 »
OK nevermind I will use my usual screw in pcb cherry stabs.  thx
« Last Edit: Mon, 25 February 2019, 12:12:49 by heedpantsnow »
I'm back.
Offline mxgian99
« Reply #59 on: Mon, 25 February 2019, 09:02:51 »
i used PCB mount stabs.
Offline prod
Re: [GB]ChicoryBLE-wireless 40% keyboard(90% Shipped)
« Reply #60 on: Fri, 26 April 2019, 08:59:59 »
2019.4.26 update
As known some cases were flawed and have been re-anodizing in Feb. Because of the factory schedule, there is no way to finish it all at once, so every time I can only receive a part of re-anodizing cases.
According to keep communicate with the person in charge of ALF, I expect to receive the all rest cases soon.
This is first time I run a formal GB, there are indeed a lot of unexpected situations that I didn’t think of before started.I have already prepared some gifts for delay.
Offline prod
Re: [GB]ChicoryBLE-wireless 40% keyboard(100% Shipped)
« Reply #61 on: Fri, 17 May 2019, 09:46:40 »
2019.5.17 update
All packages have already shipped. Thanks so much for patience and understanding.
Offline ChilliGilly
« Reply #62 on: Sun, 23 June 2019, 13:35:46 »
Discord link expired. Even the link on kevinhong.me.
Are there still extras available?
Gesendet von iPhone mit Tapatalk
Offline Argan12345
« Reply #63 on: Mon, 23 November 2020, 13:38:27 »
someone should do another round of these
Offline littlesmall
« Reply #64 on: Sun, 20 December 2020, 00:31:41 »
So cool ;)
Offline yuejia
« Reply #65 on: Mon, 21 December 2020, 20:16:15 »
Awesome!!!
Offline xenotch
« Reply #66 on: Mon, 31 May 2021, 05:57:35 »
Hi all,
I have recently damaged my chicory ble pcb. Does anyone have any spare pcbs for sale?
Offline nickthaskater
« Reply #67 on: Sun, 02 October 2022, 16:58:44 »
Risking my life necroing this thread, but wondering if there's any hope in the ChicoryBLE 40 ever seeing the light of day again. There's nothing else that compares that I've been able to find - this is exactly what I'm looking for.
Hard to believe there are no other 40% BLE boards that aren't ortho.
