Author Topic: Strange wyse / esprit keyboard conversation  (Read 4178 times)
Offline sexzual
« on: Mon, 08 October 2018, 00:19:30 »
Pics here: http://imgur.com/a/BCxNQrt
Anyone ever have any luck converting one of these to USB? It's an esprit / wyse lr54106. Uses the standard wyse 4p4c connector, but doesn't work when plugged into a soarers wyseverter. At least not when it's wired to work with other wyse boards. Was going to try hooking it up to a standard soarers converter, as it's 4 wires, but weirdly enough the two middle wires are soldered together / jumped where they are first soldered to the board ( see pic for details - top left corner)
Any suggestions?
Offline sexzual
Re: Strange wyse / esprit keyboard conversation
« Reply #1 on: Tue, 09 October 2018, 23:34:23 »
Update: I'll send one of these to anyone who helps me convert it for the cost of shipping for helping me out
Offline abrahamstechnology
« Reply #2 on: Mon, 22 October 2018, 09:56:25 »
It has a voltage regulator, so the input it wants is probably more than 5 volts.
Offline ErgoMacros
« Reply #3 on: Mon, 22 October 2018, 15:04:41 »
Disclosure: I have not done his before.
I guess my approach to this would to treat it like a "hand-wired" project.
1. Remove the existing controller  (40-pin, lop left of the PBC) and replace it with a socket
2. Map put which pins are for the rows, which for the columns, and for now ignore the LEDs
3. Given the required # of rows and columns (sum=rows+columns) will tell you the minimum number of IO pins your controller needs.
   Looks like you have 100 keys, so 10 rows + 10 columns or 20 IO pins is the least it could be configured for, but more likely it's
   something like 5-6 rows * 20 columns requiring 25 or 26 IO pins needed
4. Get a capable controller (Teensy perhaps? with enough pins. Summary here: https://www.pjrc.com/teensy/pinout.html) or maybe you can use the soarer?
5. Configure QMK or TMK to set the row and column pins used
6. Add the key-map
7. Cross-connect the needed Teensy pins to the existing controller socket. Don't connect anything other than the keyboard scan matrix.
Later, maybe, try to add the LEDs too.
It's a bit of work, but should be possible.
All the beast.
Today's quote: '...“but then the customer successfully broke that.”
« Reply #4 on: Mon, 22 October 2018, 15:14:27 »
I'd talk to snacksthecat on Deskthority, he has successfully converted many terminal boards in the past.
Offline ErgoMacros
« Reply #5 on: Fri, 26 October 2018, 13:23:32 »
Here's someone with, essentially, my suggested approach.
  https://geekhack.org/index.php?topic=97885.0;topicseen
