Author Topic: [IC] 2020COMMANDO - SP SA 112344  (Read 20082 times)
Offline William_S_Jones
  • Best Prime Ever!!!
Re: [IC] 2020COMMANDO - SP SA 112344
« Reply #50 on: Fri, 12 April 2019, 10:48:29 »
Like it, would love a staggered 40% kit. Also, any plans for an alternate alpha set or no plans to go as big as 88 Commando w/ it's kit options this time?
Offline jil_jil32
  • Tokyo Press <3
« Reply #51 on: Wed, 17 April 2019, 15:37:43 »
Any possiblity TKL mods n alphas be broken in two kits? Also no more Russkie kit??
Sadly no. It should go as a TKL kit.
And what's the Russkie kit?  :-[
Yes actually there's a plan for a follow-up GB if the first one's successfully done, and there will be some more colors (and maybe a special set).
« Reply #52 on: Wed, 17 April 2019, 16:10:49 »
Great, I'll be in for this & looking forward to the special set!!!
Offline jil_jil32
  • Tokyo Press <3
« Reply #53 on: Wed, 22 May 2019, 08:14:34 »
I'm grateful for all the feedbacks and support. This IC was really helpful and the kits have been finalized.
UPDATE - May 22nd 2019:
The GB for 2020 Commando Keyset will go live in the next few days, and will be distributed as follows:
  • 2020 Commando Keyset
  • Manufactured by Signature Plastics in the USA
  • Doubleshot ABS Plastic in custom colors
  • SA Profile Sculpted 1-1-2-3-4-4
  • Distributed by zFrontier, Kono, Mykeyboard, and JiL
  • Designed by Sơn Lê a.k.a JiL (jil_jil32)
  • Estimated fulfillment Q1 2020
Final pricing TBA when the GB launchs.
          1/ Base kit
          2/ Numpad kit
          3/ Upgrade kit 01
          4/ Upgrade kit 02
          5/ Upgrade kit 03
          6/ FPS Gamer kit
          7/ Mighty Cross kit
          8/ Space kit
Some renders:
Offline Simen
« Reply #54 on: Sat, 01 June 2019, 15:12:52 »
What is color codes for this set? same as commando 88 ?
Offline jil_jil32
  • Tokyo Press <3
« Reply #55 on: Sun, 02 June 2019, 05:43:26 »
The colors will be custom made and will not be the same as 88 Commando.
The GB thread is LIVE here => https://geekhack.org/index.php?topic=100981
