Author Topic: Real dimensions of GH60  (Read 11741 times)
Offline Bjack795
« on: Tue, 09 October 2018, 07:52:41 »
Hi all,
I'm a bit confused because
here:
https://www.banggood.com/GH60-DIY-Mechanical-Keyboard-PCB-Support-Breathing-LED-60-Cherry-MX-Poker2-Poker3-p-1084998.html?utm_campaign=15750054_1084998&utm_content=3216&p=AS022115750054201711
I see that the GH60 pcb is 18.5 cm long
and here:
https://meckeyalpha.com/products/caplwh001
I see that the case is 29.5 cm long
Since I don't think that the border is 5 cm on every side, could you explain to me which are the real dimensions of the GH60?
I have to 3d print a custom case that should be as small as possible.
Offline Mechboards
  • Mechboards UK
    • Mechboards
Re: Real dimensions of GH60
« Reply #1 on: Tue, 09 October 2018, 08:17:58 »
Roughly 28.5cm. The case is bigger than the PCB.
Offline Tactile
« Reply #2 on: Tue, 09 October 2018, 08:22:39 »
I don't know anything about whatever "GH60" is sold on bangood but info about the real GH60 can be found here.
You probably don't need anything more than this.
205131-0
REΛLFORCE
Offline Bjack795
« Reply #3 on: Tue, 09 October 2018, 08:24:51 »
Perfect, thanks to both.
(Maybe on banggood they confused 28.5 with 18.5)
« Last Edit: Tue, 09 October 2018, 08:27:31 by Bjack795 »
