Author Topic: Gaming, red vs black vs brown  (Read 25416 times)
Offline Shirukii
« on: Sat, 01 May 2010, 14:39:06 »
I've been lurking here for a while, growing more and more frustrated with my mushy membrane g15 bought in ignorance of the glorious mechanical master race. It's time to join the club.
My time is spent primarily on gaming, and from what I've read (I have read most gaming related posts on here) this leaves me with three options:
Cherry Blacks: Highly praised for gaming, high actuation force is great for rts games to prevent accidental keypresses and linear switching will do well with double tapping and speedy fps reactions. However, often said to be terrible for typing and potentially fatiguing. I find my pinky getting tired on the crouch (ctrl) key when I play for extended periods of time, so this is my main concern with blacks.
Cherry Reds: All the benefits of blacks at lower fatigue. Double edged sword, accidental keypresses in rts are more likely and also in fps since I rest my hands on wasd when I play. Typically described as "typing on air", which doesn't sound ideal, coming from a g15 I have a pretty heavy hand.
Cherry Browns: Middle ground, good for typing, decent for gaming, my main concern here is the small tactile bump which makes double tapping slightly harder.
I have a friend going to Hong Kong soon and she might be able to track down a cherry red keyboard for me, that's why it's an option here.
All in all, I'm leaning towards blacks, but I'm still wary of the fatigue that it may cause my pinky while gaming and otherwise while typing normally.
I don't have any questions in particular, I'm opening the floor up to discussion so that I can narrow down my needs and address my concerns. So have at it! I'll answer any questions that'll help me make my choice.
CM Storm QuickFire Rapid | Ducky DK9008 | IBM Model M
Offline clickclack
  • Board Chow EXTRAORDINAIRE
Hi =)
« Reply #1 on: Sat, 01 May 2010, 15:16:54 »
First, welcome to geekhack! =)
I have tried each of the switches you have mentions as well as most others (for a cherry red I just used softer springs in a linear setup) and I happen to really like cherry blacks. I find them great to type one and I don't get any fatigue. I had used them for about 4 months straight and found that I can type the fastest on them. It's also the only switch that I can easily type without bottoming out on, I don't even have to think about it and I just glide over the keys with ease. I also make relatively few mistakes on that board when typing too!
I have given my mom the board now (while I test others) and she loves it and has been using it for a few months now and does not find it tiring, she uses it quite heavily and everyday. I know its different for many people but I really think it's worth trying.
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline clickclack
it's a curse! =P
« Reply #2 on: Sat, 01 May 2010, 15:43:20 »
Quote from: webwit;177880
I advise you to buy a Cherry Black, Red and Brown board. For starters.
Yup! It is almost unavoidable :S
hahaa
Offline Shirukii
« Reply #3 on: Sat, 01 May 2010, 15:50:38 »
My hands tremble in excitement at your advice, my wallet trembles in fear.
+1 for black.
Offline ch_123
« Reply #4 on: Sat, 01 May 2010, 18:22:49 »
I remember reading about your idea to convert that thing to Cherry switches for the first time and thinking "Heh, that's one of those overambitious ideas that's doomed to failure..." Fair play on getting it working!
Offline Shirukii
« Reply #5 on: Sat, 01 May 2010, 18:28:48 »
That is one bizarre creation, well done pulling it off. I did read that G80-3600LYC review, that board being the only cherry red I know of in existence. My plan right now is to find somewhere with a steelseries 7g on display and spend a good while poking at it to get an idea of how the blacks feel, if I like them I'll pull the trigger on a filco with blacks. If they're too stiff I'll get my friend to bring me back a G80-3600LYC.
Offline ricercar
  • mostly abides
« Reply #6 on: Sat, 01 May 2010, 20:45:53 »
Majestouch has a Cherry red board. I'm trying to decide how much I'll pay before I PM him.
Offline imsto
    • imsto.cn
« Reply #7 on: Sun, 02 May 2010, 01:05:25 »
Seems Cherry MX red is hard to be found in US?
it's easy to get in China
Use the springs in Cherry MX blue take the place of the Cherry MX black, then get the red feel.
Suerb'd made some springs with the same parameters as Cherry MX red.
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline imsto
    • imsto.cn
« Reply #8 on: Sun, 02 May 2010, 01:10:29 »
Cherry MX black might be the best choice.
imsto.cn
Offline Phaedrus2129
« Reply #9 on: Sun, 02 May 2010, 01:14:51 »
My MX Browns work just fine for gaming, no complaints whatsoever except that my MX-11800 isn't NKRO, which I've found has a real impact in at least one case:
Shift W V
(run forward, voice)
Press R to reload--oh noooo, it's blocked.
But that's the keyboard, not the switch. MX browns work fine for gaming. I don't know about double tapping, but for FPS games they work just fine.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline nraymond
« Reply #10 on: Mon, 03 May 2010, 08:58:29 »
Quote from: Phaedrus2129;178012
My MX Browns work just fine for gaming, no complaints whatsoever...
I also like my Filco Tenkeyless with browns for gaming.  I'm not a pro/competitive person (not a member of clans or anything), but I own about 80 games of many genres, and it's been good for all of them so far.  I like the Cherry MX Browns better than the Alps black clones in the ABS M1, which I was using previously.
Offline kriminal
« Reply #11 on: Mon, 03 May 2010, 09:53:36 »
i say cherry blacks, i have a black and brown, my hands dont get tired playing on the blacks for extended periods, i actually like the blacks.
and this is a person coming from a g11 kbd.
EDIT: browns are good for gaming, however the blacks feel so natural for it i like the springing feedback.
« Last Edit: Mon, 03 May 2010, 09:56:13 by kriminal »
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline Shirukii
« Reply #12 on: Mon, 03 May 2010, 13:18:02 »
I'm more or less settled on blacks now, I've yet to find a SS 7G to poke at, but I'm convinced my already heavy typing will suit me well for blacks. Now to wait for elitekeyboards to get them back in stock and to mentally prepare myself to spend over $150 on a keyboard.
Offline itlnstln
« Reply #13 on: Mon, 03 May 2010, 13:37:58 »
Quote from: Shirukii;178552
It's not that hard once you do a few times.  It's just like killing someone in that way.
Offline ironcoder
« Reply #14 on: Mon, 03 May 2010, 13:43:11 »
Quote from: itlnstln;178562
Hammer: "Never shot a man before I shot a man."
Oh I fogot, never piss off anybody who's name ends in a vowel. Can I buy a vowel, Pat?
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline ironcoder
« Reply #15 on: Mon, 03 May 2010, 13:47:00 »
Quote from: ripster;178563
ItlnStln - someday you'll have to tell me how your IT department let's you get away with this.  They must have TERRIBLE filters.
That's his new job..he is the IT department. Cutbacks, you know.
Offline Shirukii
« Reply #16 on: Mon, 03 May 2010, 13:50:23 »
Relevant: I've spent about $1,500 on my audio set up so far, so I have practice.
Offline DryDry
« Reply #17 on: Tue, 04 May 2010, 04:09:15 »
Quote from: imsto;178011
i agree with you
I am not tall,not handsome,but a little bad……
Offline ricercar
  • mostly abides
« Reply #18 on: Wed, 05 May 2010, 17:50:17 »
my already heavy typing will suit me well for blacks .... prepare myself to spend over $150 on a keyboard.
Heck, I'll sell you a backlit TG3 with Cherry blacks for $100.
Product page
http://www.tg3electronics.com/products/backlit/bl82
I'll put up a classified.
« Last Edit: Wed, 05 May 2010, 18:05:36 by ricercar »
Offline Shirukii
« Reply #19 on: Wed, 05 May 2010, 18:55:53 »
So as a point of testing/comparison, I'm typing on a newly acquired Model M. I'm really loving how it feels and sounds to type on it. That being said, I am finding it slightly tiring on my fingers to use. This post is the first thing that I'm typing with it so there's a bit of getting used to, but my conflict is back.
It's pretty hard to accidentally press a key with the Model M, whose actuation force is supposedly lighter than cherry blacks, but at the same time I'm having to press harder than I'm used to compared to membranes.
Can anyone compare the Model M to cherry blacks? The actuation force is close but the latter lacks the tactile bump.
Regardless, I'm really happy with the Model M, no buyers remorse here.
CLACKACLACKACLACKA <3
Offline ricercar
  • mostly abides
« Reply #20 on: Wed, 05 May 2010, 22:44:08 »
Model M feels the same as blacks for force; however the M is crisp and the blacks are soft.
someone's bound to correct me if the numbers are not exact for black and bs.
Offline Shirukii
« Reply #21 on: Fri, 07 May 2010, 13:45:10 »
I can't find anywhere locally that stocks a Steelseries 7G and are willing to let me open up the box and have a poke at the keys. I love the Model M for typing purposes, but gaming feels labored on it, I think I'm going to go for browns.
Offline itlnstln
« Reply #22 on: Fri, 07 May 2010, 16:02:00 »
I think browns are a good choice, if not a good compromise.  The only time I have tried blacks is on a customer terminal (G80-11900) in a store, and I really did not like them.  You might be able try them in a similar way (store terminal) before you buy something, but I think you'll be happy in something with browns.
Offline Shirukii
« Reply #23 on: Fri, 07 May 2010, 16:37:52 »
Yep, I've made my choice, getting ready to order the Filco tenkeyless with browns when it comes back in stock. Originally I wasn't going to get a tenkeyless, but when I switched to the Model M, which is smaller than the g15, it brought my mouse hand in closer and it was more comfortable when gaming.
And whenever I need the numpad for some serious data, entry, I can always swap out. Keyboards are awesome!
Offline itlnstln
« Reply #24 on: Fri, 07 May 2010, 16:41:33 »
Keep in mind, too, that the Filco 104 is less wide than the Model M.  If you do end up needing a numpad fairly often, you could always get and external one and break it out when you need it.
Offline Shirukii
« Reply #25 on: Sat, 08 May 2010, 14:36:04 »
One other option I might have available to me is a Ducky keyboard, I have a friend in mainland China right now, if anyone has any idea where she'd be able to get one there. Alternatively, is there any way I can get one shipped over to Canada?
Offline elbowglue
« Reply #26 on: Sat, 08 May 2010, 17:32:31 »
Ashley, have you been on this forum before under another name?  I think I've spoken with you before, it sound so familiar!
Quote from: Ashley;180268
Hello,
Keyboard can't give a better controls than joysticks.The better option is to use the joysticks for gaming.
__________________________
"Want to get-on Google's first page in 48 hours and flood your site with traffic?
Try Traffic Geyser, the internet's #1 video marketing software at Traffic Geyser "
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline LordGurciullo
« Reply #27 on: Sat, 08 May 2010, 21:31:18 »
Don't get browns.
I have cherry red black and brown. browns are not in the same league whatsoever for gaming.
not even close.
Offline Shirukii
« Reply #28 on: Sun, 09 May 2010, 02:17:49 »
You guys are going to make an indecisive wreck of me, but I think I'll stick to my decision for browns, if blacks really are the equivalent force of the Model M.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #29 on: Sun, 09 May 2010, 12:13:07 »
My favorite Cherries are the red ones and the yellow ones.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #30 on: Sun, 09 May 2010, 12:19:03 »
I like the tasty ones.
kishy.ca
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #31 on: Wed, 12 May 2010, 01:18:54 »
It's clear to me there's a switch loose somewhere.  Fresh are tasty.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
