Author Topic: Micro Mechanical Keyboard (uMK) firmware  (Read 3658 times)
Offline marcv81
« on: Wed, 10 October 2018, 06:53:48 »
Hi all,
I made a custom firmware for ATmega32U4-based keyboards. https://github.com/marcv81/umk.
The features set is minimal: anything you can do with a regular keyboard + remapping keys + layers. On the bright side it takes less than 3kb and the matrix poll rate is close to 2kHz.
Although it is my daily driver casual users would be better off with a mainstream firmware and a strong community.
I'm sharing in case some of the tinkerers here find it worth having a look at. The code should be simple enough for any developer to understand and experiment with, which I believe is the main strength of the project.
By the way, I'm not looking for contributors: the firmware has all the features I want already. I'm unlikely to accept PRs other than bug fixes. This said feel free to fork or reach out with questions and comments!
Cheers,
Marc.
Offline OldIsNew
Re: Micro Mechanical Keyboard (uMK) firmware
« Reply #1 on: Wed, 10 October 2018, 12:07:38 »
Cool! I'll definitely give the code a look over. I've been dabbling in Arduino C code for my boards,  but am always interested  in seeing how someone  who knows C well approaches things.
Offline kriminal
« Reply #2 on: Wed, 10 October 2018, 21:54:29 »
I'll check it out also, will learn a thing or two
Sent from my Moto G (4) using Tapatalk
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline marcv81
« Reply #3 on: Fri, 12 October 2018, 06:23:30 »
Thanks for the interest!
I might not know C as well as you think. I made some potentially controversial design decisions. For instance each translation unit statically allocates the resources it needs. So for instance there can only ever be one report_builder. It goes against the usual good practices, but given the resources constraints it is a reasonable compromise which avoids heap allocation and reduces complexity. This said I still chose to decouple the translation units, which is generally a good idea but results in a slight performance impact.
Any specific question feel free to ask!
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #4 on: Fri, 12 October 2018, 07:07:21 »
That's pretty much what every other keyboard firmware does. The usual best practices for embedded development are sometimes very different than the traditional best practices.
