Author Topic: [IC] Enjoypbt Kuro/Shiro (GB CLOSED)  (Read 430703 times)
Offline gok_nz
  • Enjoy your PBT
    • Website
« on: Thu, 11 October 2018, 19:57:08 »
ENJOYPBT KURO / SHIRO
This is an Interest Check for a PBT dye-sublimated keyset which combines the legends from the popular Enjoypbt Black Japanese set and the more recent Enjoypbt Black on White.
The kit is largely based on the Enjoypbt Black on White set with the revised legends and icon modifiers.
All the Japanese legends have been redone with a slightly different font than that of the Japanese Black set.
I will also use thinner legends than my previous sets and also bundle some reverse dye-subbed accents as shown in the kit preview.
Enjoypbt have prepared tools to facilitate reverse dyesubbing for this set which is something that is currently unique to this set.
The colour of the white will be a little less beige than GMK's WS1 white but should retain a similar brightness. The current samples match WS1 but I am currently looking at a Pantone colour that is more to my liking.
THE GB IS LIVE! Click here
Above is a photo comparing the Enjoypbt Black on White sample (top) with the current Kuro/Shiro samples.
NEW
RAMA black PVD brass with enamel infill keycaps:
These will also be run through KBDfans.
PHOTOS
Click below to see more photos
KITS
Essentials kit
Click below to see the rest of the kits
Standard mod kit
Japanese mod kit
Spacebar kit
Numberpad
40% Ortho kit
International kit
SAMPLES
Click below to see the rest of the samples
Essentials kit
Japanese mod kit
Standard mod kit
International kit
Ortho kit
Numberpad kit
If you'd like to support this project, you can copy and paste the code below into your signature to display a banner
Code: [Select]
[url=https://geekhack.org/index.php?topic=97699.0][img width=390 height=120]https://i.imgur.com/fF4NwCs.jpg[/img][/url]
UPDATES
11/10/2018 UPDATE: After looking at the survey, I have started working on some options regarding a Japanese mod kit. Once that is ready, I will be posting it here and opening up another google form to see what your guys preferences are. From the short while that I've worked on the Japanese kit, I've already formed an opinion on which combinations work well but I haven't decided what will be part of the base kit and what would be an addon. I'll also be posting documentation showing how I arrived at some of the design choices.
17/10/2018 UPDATE: Added a google form about the International ISO kit. I will be leaving this open till the end of the week unless I don't receive enough responses, in which case I will leave it up for longer and work on the other kits before coming back to this. Also added individual kits.
20/10/2018 UPDATE: Added the International kit to the list.
31/10/2018 UPDATE: Sent design files to be prototyped. EST is 16th of November at this stage.
07/12/2018 UPDATE: Samples produced. Waiting for high-res photos from KBDfans and then for them to ship the samples to me. Expecting to receive the samples early January.
21/12/2018 UPDATE: Replaced photos of the samples with a new batch of photos and updated some of the info.
05/01/2019 UPDATE: HAPPY NEW YEAR! Updated the kit previews and added a spacebar kit and split the numberpad into its own kit. I will be ordering some pantones to try and find a white that is slightly less yellow. This will push the GB date out and I have edited the estimated date to reflect that.
06/01/2019 UPDATE: Replaced photoshopped mock up with actual photos. Thanks to Zekkin for letting me use his photo of his E6-V2 for the mock up. You can find the photo here
15/01/2019 UPDATE: Updated the International ISO kit preview.
22/01/2019 UPDATE: Colour swatch en-route to KBDfans. New keycap samples estimated to arrive after Chinese New Year.
03/03/2019 UPDATE: First colour samples got lost in the mail system but KBDfans have received the 2nd package so the factory can proceed with the production of the next batch of prototypes.
18/03/2019 UPDATE: Added renders of the RAMA collaboration keycaps.
29/03/2019 UPDATE: Group buy is live!
05/04/2019 UPDATE: MOQ has been reached on both the set and the RAMA artisan.
« Last Edit: Fri, 26 April 2019, 22:12:43 by gok101 »
Offline fcoury
Re: [IC] Enjoypbt Kuro/Shiro
« Reply #1 on: Thu, 11 October 2018, 20:06:55 »
I think it looks magnific and even though I see the overlap with BoW, I would buy this in a heartbeat. Great work as usual!
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #2 on: Thu, 11 October 2018, 20:14:25 »
Yup, I've tried changing a few things to reduce the amount of overlap:
  • Thinner legends as outlined in the original post
  • I will be using a different white
  • Japanese legends - slightly different to Enjoypbt Black Hiragana
But the main thing will be the Japanese mod kit which I have been working with Ai03 on which should provide Japanese alternatives to almost every mod key.
Offline fcoury
« Reply #3 on: Thu, 11 October 2018, 20:19:56 »
I think those are more than enough for justifying getting it even if you already own BoW, which is my case.
Offline Allo
« Reply #4 on: Thu, 11 October 2018, 20:20:28 »
Can we change the 1.5u backspace to use the same arrow as the 2u backspace?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #5 on: Thu, 11 October 2018, 20:23:16 »
I'll be keeping the box backspace in the base kit as is but the Japanese kit currently has a different design of small icon + kanji.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #6 on: Thu, 11 October 2018, 20:28:19 »
not sure if it's just me but the picture links don't work.
i'd pick up a set, haven't picked up one of the sets already out since i'm not really into beige on my current keyboard.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #7 on: Thu, 11 October 2018, 20:38:21 »
I've just switched the link to a different host. Does it work now?
Offline finalarcadia
« Reply #8 on: Thu, 11 October 2018, 21:35:07 »
Why not take advantage that it's dyesub and make sublegends a different color, like red.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #9 on: Thu, 11 October 2018, 22:15:00 »
Hi. I chose black sublegends because I wanted something more simple and clean than this:
I thought there is already enough visual interest, especially when combined with Japanese mods.
Offline yap68
« Reply #10 on: Thu, 11 October 2018, 22:52:42 »
Or the sublegends in gray?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #11 on: Thu, 11 October 2018, 23:04:13 »
I'll give it a go but I'm still inclined towards just black
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #12 on: Fri, 12 October 2018, 00:03:15 »
I'd definitely be interested in a Japanese mod kit. One thing I like about the alphas with sublegends is the greater amount of legend color that's on the caps, but in contrast the normal mods seem a bit empty and plain.
Offline voight-kampff
« Reply #13 on: Fri, 12 October 2018, 00:10:49 »
I am in
Offline vonswoopington
« Reply #14 on: Fri, 12 October 2018, 01:25:25 »
Sublegends with color would be amazing. I'd be all in with that.
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
Offline oumakavoula
« Reply #15 on: Fri, 12 October 2018, 01:31:36 »
would only buy an alpha only addon
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #16 on: Fri, 12 October 2018, 01:40:31 »
I am generally a fan of icon mods but I think the shift keys look a bit empty and I'm not afraid to mix it up a little.
When pooling the kits that I have planned, my preference will be standard bottom row (includes Japanese sublegends for certain keys), Japanese shift, Icon enter, tab and backspace keys and Japanese navigation cluster.
If you look at some of the old Japanese keyboards, there is actually a fair bit of English on them.
My aim is to have both the base and kits consistent with each other so that you can choose whichever key you want to swap in on a case by case basis and not have them stick out like a sore thumb.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #17 on: Fri, 12 October 2018, 01:43:16 »
I won't be splitting the alphas out, sorry. They wouldn't work with Epbt BoW because it will use a different white, if that was what you were thinking of doing.
Offline equalunique
« Reply #18 on: Fri, 12 October 2018, 02:02:04 »
Will this set be capable of populating a JIS layout keyboard, like for example the ones by Filco?
Sent from my LG-H918 using Tapatalk
Offline stoic-lemon
« Reply #19 on: Fri, 12 October 2018, 02:19:21 »
At the risk of sounding like one of those people who thinks they know everything about Japan because they watched Karate Kid in the 80's: they say shiro kuro, not kuro shiro.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #20 on: Fri, 12 October 2018, 02:48:34 »
You are right but I was trying to follow the pattern of Black on White. Shiro Kuro would seem more like White on Black to me.
« Reply #21 on: Fri, 12 October 2018, 02:52:28 »
Black and white is good, cleaner then black white and grey.
Is there a timeframe for the GB?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #22 on: Fri, 12 October 2018, 02:58:40 »
I'll need to check. With the sheer number of keys, I'm guessing you would since it also includes fringe keys like 3u spacebars but I really need check.
I can get all the design done by the end of the month but what will delay starting the GB would be getting the samples in.
It took a long time to get the samples for the normal BoW, which was partly responsible for some of the delays, so I'd prefer to have the samples on hand and have everything confirmed before opening the preorders this time round.
Offline the_high_5
« Reply #23 on: Fri, 12 October 2018, 03:03:32 »
Have a rough estimate on price? With that kind of compatibility, I'm most likely in.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #24 on: Fri, 12 October 2018, 03:11:59 »
Hard to say since the biggest unknown is sourcing the reversed dyesub accent keys.
Aside from those, I'd say it would be around the 90-100 USD mark including shipping for the base set, same as epbt BoW since it has a similar number of keys.
Offline _ODIN_
« Reply #25 on: Fri, 12 October 2018, 05:06:46 »
Would be in with the inclusion of an international kit
Offline mkarlsson
« Reply #26 on: Fri, 12 October 2018, 06:47:32 »
This. Or having at least the full uk iso kit in the base kit? Right now is half way there...
« Reply #27 on: Fri, 12 October 2018, 09:51:09 »
I would like some slightly warm white, but not on the yellowish or beige side
What do you have in mind regarding the white color?
Sent from my MIX using Tapatalk
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #28 on: Fri, 12 October 2018, 13:07:56 »
My aim is to match the ED coated cases but without seeing those, my gut feel would be some similar to GMK WS1.
The original black on white was more like something between WS2 and GR1.
  • sleever supreme
  • greyhat co-leader
« Reply #29 on: Fri, 12 October 2018, 15:08:29 »
Oh my b, I think they're shop links.
They still don't work for me but I was able to find them on kbdfans.
I think it's the %27 in front of the links that's killin it.
I think light gray might look kinda nice actually.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #30 on: Fri, 12 October 2018, 16:36:47 »
Ah thanks for clarifying. Those links should be fixed now.
Offline megaforce
« Reply #31 on: Fri, 12 October 2018, 16:52:08 »
i like it
10/10 would buy if ~$100
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline KorbenDallas
« Reply #32 on: Fri, 12 October 2018, 22:50:30 »
Out of all the epbt sets coming up this now has my interest the most. I like it as is with a more true white color code as well as an attempt at reverse dye sub for the accent keys. Interested to see what you will do with the Japanese mod kit, will keep my eyes peeled on this IC!
Offline Mcnos
    • GMK Fuyu
« Reply #33 on: Sat, 13 October 2018, 01:16:51 »
I like it, and I want it.
Offline jebbra
  • jebbra.net
« Reply #34 on: Sat, 13 October 2018, 12:16:15 »
With 9009 style mod I believe 1 line tab icon will be a more perfect choice. But, I really like this already :thumb:
Offline coffeeshopcoder
« Reply #35 on: Sat, 13 October 2018, 15:01:28 »
Why are the row numbers inverted on the kit image ? is this an epbt thing ?
Love the set, would love an accent kit - black or red or grey , and sub legends in a more subtle color like grey to make it look a bit less busy.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #36 on: Sat, 13 October 2018, 17:40:56 »
Yup. It is an epbt thing. I'm going to try grey sublegends but I prefer black and which is also part of the theme for the set.
Offline digid3ar
« Reply #37 on: Sun, 14 October 2018, 01:41:42 »
pls let this set like it is, im loooking foward to a Patlabor thematic. and this is so perfect for the idea :eek:
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #38 on: Sun, 14 October 2018, 04:55:56 »
Here is a peek at what I've been working on for the Japanese modifiers kit:
Please note that it hasn't been finalised yet and the above only shows part of the kit.
Offline _ODIN_
« Reply #39 on: Sun, 14 October 2018, 05:51:05 »
:thumb:
Offline lazyfart
« Reply #40 on: Sun, 14 October 2018, 12:48:30 »
I'd like to put the banner in my signature, do you have the info for it?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #41 on: Sun, 14 October 2018, 13:08:07 »
Code: [Select]
[url=https://geekhack.org/index.php?topic=97699.0][img width=400 height=100]https://i.imgur.com/deArKdq.jpg][/img][/url]
I didn't realise that there was a standard size so I'll modify the banner and the code later today.
« Last Edit: Sun, 14 October 2018, 15:20:44 by gok101 »
Offline Rumai
« Reply #42 on: Sun, 14 October 2018, 13:46:34 »
Would definitely support this, assuming all HHKB keys/mods match up properly w/ the theme.
Offline lazyfart
« Reply #43 on: Sun, 14 October 2018, 13:50:10 »
Code: [Select]
[url=https://geekhack.org/index.php?topic=97699.0][img width=300 height=90]https://i.imgur.com/rfgFrNJ.jpg][/img][/url]
Awesome, thanks!
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #44 on: Sun, 14 October 2018, 15:22:03 »
Code: [Select]
Awesome, thanks!
Updated!
Offline appaboy
« Reply #45 on: Sun, 14 October 2018, 16:22:12 »
im interested! There needs to be more epbt gbs  :p
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #46 on: Sun, 14 October 2018, 16:27:16 »
looks so very awesome! I know its a far far away wish, but please consider a international kit.  :-X
Offline tunadesu
« Reply #47 on: Sun, 14 October 2018, 17:05:02 »
uhmm...yes plz
Offline ojrask
  • juuh elikkäs
« Reply #48 on: Sun, 14 October 2018, 17:23:25 »
Interested! I rarely like black on white but this looks great.
Current:
Coming up:
IC/GB:
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #49 on: Sun, 14 October 2018, 18:35:33 »
Yes, that will be something that I will look at as well as well as 40% ortho compatibility. I've mentioned this elsewhere before but the tricky thing would be in dealing with the ISO keys that already have sub legends. In the end, it won't be a 'proper' Japanese layout but I should be able to get it to cover the full hiragana alphabet and punctuation keys.
