Author Topic: What is the point of Ergodox EZ LED lights?  (Read 2753 times)
Offline Blue_Moon
« on: Mon, 15 October 2018, 18:25:49 »
Is it just for looks? Or can the lights change to show which profile I'm in?
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
Re: What is the point of Ergodox EZ LED lights?
« Reply #1 on: Mon, 15 October 2018, 18:56:39 »
The underglow? Or the status LEDs?
Both can be programmed, and can, indeed, show you which layer you're on, or whatever you'd like.
Offline Blue_Moon
« Reply #2 on: Mon, 15 October 2018, 20:05:59 »
Thank you. I meant the underglow. It’s an option so I’d save some money if it were just for looks. But giving me feedback on which layer I’m on sounds useful.
Offline algernon
« Reply #3 on: Tue, 16 October 2018, 05:32:15 »
FWIW, showing which layer you're on is not part of the factory firmware, you'll have to update yours to make it do that. The code required to do so is quite simple, and if you get there, I'm happy to walk you through it.
