Author Topic: [IC] Metal and Wood Cherry profile keycaps.  (Read 4116 times)
Offline saint emerald
« on: Thu, 18 October 2018, 01:49:14 »
Hey guys!
I've started to work with one of my colleagues on some Cherry profile keycaps.
The materials available are Aluminum, Stainless Steel, and Black Walnut. Stainless Steel will start at $30. Black Walnut and Aluminum are +$5
MOQ for this is 25 for each material.
Renders are being worked on right now.
https://goo.gl/forms/T0cMOfOIhTYkZJJU2 Please fill the form out here.
The Jian, also known as “the bird that shares wings,” only possesses one wing. Unless a male and female pair lean on each other and act as one, they’re incapable of flight. They’re imperfect, incomplete creatures, but for some reason, their way of life struck me as profoundly beautiful.
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] Metal and Wood Cherry profile keycaps.
« Reply #1 on: Thu, 18 October 2018, 09:03:13 »
Will you be doing all rows in Cherry profile? R1-R5?
Offline Corgiattackkk
« Reply #2 on: Thu, 18 October 2018, 12:50:03 »
Interested in black walnut. Filled out the IC, interested in seeing renders when they come up!
Offline lazyfart
« Reply #3 on: Thu, 18 October 2018, 14:34:58 »
Will the GB be closed once moq is hit? Thinking of buying a set of alphas.
Sent from my SM-N920I using Tapatalk
« Reply #4 on: Thu, 18 October 2018, 19:16:48 »
Yes.
« Reply #5 on: Thu, 18 October 2018, 19:17:28 »
Also, note. This is per individual keycap.
« Reply #6 on: Sun, 21 October 2018, 01:14:20 »
How many caps will you be buying? The prices are per cap, by the way.
Offline voight-kampff
« Reply #7 on: Sun, 21 October 2018, 06:55:31 »
Stainless Steel keycap is $30 and alu is $30 + $5
So aluminium keycap costs more then stainless?
I would be in for a 60% keyset in walnut, but not for $35 / keycap
« Last Edit: Sun, 21 October 2018, 06:57:08 by voight-kampff »
« Reply #8 on: Mon, 29 October 2018, 08:08:04 »
bump
