Author Topic: [IC] Turkeeb v1 Custom %60 Keyboard  (Read 10332 times)
Offline Penumbra
« on: Fri, 19 October 2018, 07:15:22 »
Hello Geekhack Family,
First of all let me introduce myself. I'm Mert from Turkey and I'm in love with custom keyboards  :-* But sadly, Turkey haven't got any regular keyboard making company or custom ones. So I decided to make my own mechanical keyboard case (CNC prices are really cheap here too) and I can crate my own PCB within the next project with new budget. Then I can be the guy who started this hobby in Turkey.
Please know that this is my first project and I never had a custom keyboard before so I'm open to any suggestions!
Let's see my first project;
This keyboard will be anodized aluminum and brass backplate. Price will be around 200~250 $ for every color. We can also make a custom image, sign etc. to the backplate for every customer.
« Last Edit: Sat, 20 October 2018, 06:25:00 by Penumbra »
Offline Myoth
Re: [IC] Turkeeb v1 Custom Tenkeyless Keyboard
« Reply #1 on: Fri, 19 October 2018, 08:43:08 »
looks good, one or two questions though :
-whats the front height of the keyboard ? it looks kind of high and I've heard a keyboard is almost unusable if it's too high
-is it top mounted ? bottom mounted ? tray mounted ?
Offline dantambok
« Reply #2 on: Fri, 19 October 2018, 08:50:03 »
uhhh looks like the front is really really high
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline Penumbra
« Reply #3 on: Fri, 19 October 2018, 12:34:33 »
Thanks for the reply!
Yeah I was getting worried about front height and I think its true. It's too high (25mm) and its gonna be a problem just like Time TKL (24mm) project.
And yes its tray mounted.
Whats the most favorite height for all other custom keyboards, 15~16?
Offline M
« Reply #4 on: Fri, 19 October 2018, 12:39:48 »
Angle? Connection type? Alps support?
Offline Penumbra
« Reply #5 on: Fri, 19 October 2018, 12:50:25 »
5 degree, connection type of choose.
I didn't think about the ALPS support but if alps support means different switch plate, then we can do it.
Offline mkarlsson
« Reply #6 on: Fri, 19 October 2018, 13:52:46 »
I don't think I've seen a front height that low, if you can do 15~16 would be great probably. I think most of the customs are around 19mm. From my point of view going over 20mm would be a bit too much.
Offline Hokabuki
« Reply #7 on: Fri, 19 October 2018, 15:15:40 »
You call it a tenkeyless but looks like a standard 60% ANSI layout and plate, correct?
Offline Penumbra
« Reply #8 on: Sat, 20 October 2018, 06:24:24 »
Correct, I changed the title.
Offline DJSwayde
Re: [IC] Turkeeb v1 Custom %60 Keyboard
« Reply #9 on: Wed, 24 October 2018, 15:06:59 »
Judging from the USB port placement, this won't take universal PCBs?
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Sage (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Offline jihadu
« Reply #10 on: Fri, 26 October 2018, 08:23:36 »
2018 is turning out to be the year of the one layout plate boards
Offline equalunique
« Reply #11 on: Mon, 15 July 2019, 14:52:31 »
Any update?
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline Penumbra
« Reply #12 on: Mon, 12 August 2019, 16:00:35 »
Any update?
We are currently working on another project since this project doesn't get very interest. Thank you for your attention.
Offline vaughno
« Reply #13 on: Tue, 13 August 2019, 21:45:16 »
Since this project is over, do you think you can message me? I have a question.
Unikorn | Orion v3 | GSKT-00
Offline EMC Labs
« Reply #14 on: Tue, 13 August 2019, 23:03:27 »
"Project is over"? This is an interest check.
Offline KingOfMemes
« Reply #15 on: Tue, 13 August 2019, 23:08:04 »
HHKB option?
