Author Topic: [IC] Zambumon Verne: Custom TKL  (Read 84397 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« on: Fri, 19 October 2018, 10:03:06 »
READ THE OP.
Interest Check Form
Verne is a custom mechanical keyboard with an elegant and uncluttered design, from the internal
components to the case itself.
Powered by a custom WT80-A PCB designed by Wilba, with a beautiful dark blue solder mask
and artwork from the GMK Nautilus keycap set, Verne is fully programmable via QMK and VIA
Configurator. In addition to the WT80-A, Verne has an USB-C extension PCB that allow better
placement of the USB-C connector by mounting it low, in parallel with your desk surface.
The keyboard has a top-mounted brass plate with a fixed TKL layout, where 0.25U gaps separate
the function row and navigation cluster from the 60% area. Having a fixed plate grants a tight fit on
all switches and a clean look when the switches are in place, as all of the exposed plate holes are used.
Once assembled, Verne weighs around 2.5 kg (5.3 lbs), a perfect spot where it is hefty
enough that moving it by accident is hard, but you can still pick it up and adjust its position easily.
Supported Layouts
Two layout configurations will be available:
Verne Modern: the standard American layout, with a 6.25U spacebar and seven 1.25U modifier
keys on its bottom row.
Verne Classic: a symmetric bottom row, with a 7.00U spacebar and two 1.50U modifiers and
a 1.00U modifier on each side; as well as a stepped Caps Lock key.
Color Options
Oblivion Grey
An elegant all purpose dark grey case, perfect for keycap sets such as Carbon, Chocolatier, Oblivion,
OG Cherry Sets, or Serika.
Nautilus Blue
Designed for blue sets such as Calm Depths, Laser, Nautilus, Penumbra, Samurai Blue, Space Cadet,
Solarized Dark, or Yuri.
Jamón Red
A vibrant, striking red that will bring sets like Jamón, Led Zep, Burgundy, or Metaverse to the next level.
Technical Specs
  • 6 degree slope.
  • Top mounted sand-blasted brass plate. Fixed layout.
  • WT80-A Verne and WT-USB-C extension PCBs designed by Wilba. Programmable via QMK and
VIA Configurator.
  • Weight: 2.5 kg (5.3 lbs).
Included With Verne:
  • Top Piece.
  • Bottom Piece.
  • Sandblasted brass plate.
  • WT80-A Verne PCB.
  • WT-USB-C Verne PCB.
  • WT80-A to WT-USB-C cable.
  • Screws and bumpons.
Note: this is a DIY kit. Assembly, keycaps, switches, stabilizers and USB-C cable are not included.
Pricing, Available Units, and Shipping
  • Pricing: to be announced. Between $380 and $420. EU members VAT DISCLAIMER: Spain has a 21% VAT, $380 are around 330€, with 21% is around 400€.
  • Available Units: between 30 and 35. Raffle sale.
  • Shipping: keyboards will be shipped from Spain. Tracked and insured.
  • Estimate shipping time: none, or maybe  a week, whenever I can ship them.
Links of Interest
LEARN MORE ABOUT WILBA: wilba.tech
WEB: zambumon.com
INSTAGRAM: @Zambumon
REDDIT: /u/zambumon
CHOCOLATIER: GH Thread
« Last Edit: Thu, 07 February 2019, 13:53:44 by Zambumon »
Offline Rubbermilitia
Re: [IC] Zambumon Verne: Custom TKL
« Reply #1 on: Fri, 19 October 2018, 10:05:06 »
Good name. That is a heavy damn board right there
Offline cijanzen
« Reply #2 on: Fri, 19 October 2018, 10:07:35 »
Sign me up!
Offline SolidCactus
« Reply #3 on: Fri, 19 October 2018, 10:15:57 »
Yes please! I hope I get lucky on this one.
Offline itskuroi
« Reply #4 on: Fri, 19 October 2018, 10:18:56 »
exciteddddd
Offline Zambumon
    • Keyset projects
« Reply #5 on: Fri, 19 October 2018, 10:29:59 »
Prototypes Gallery
Offline Koojahyung
  • 안녕하세요.
« Reply #6 on: Fri, 19 October 2018, 10:36:57 »
wah....
Offline tomu
  • hi
« Reply #7 on: Fri, 19 October 2018, 10:55:38 »
nice blue Jambumón
Sent from my LG-H871 using Tapatalk
G80-3700 | HHKB Pro 2
Offline Etherealsound
« Reply #8 on: Fri, 19 October 2018, 11:01:40 »
Absolutely gorgeous board. Unfortunately, lack of WKL means I'll be watching this one from the sidelines. Best of luck (though I doubt you'll need it XD)
Offline Techno Trousers
  • ʘ_ಠ
« Reply #9 on: Fri, 19 October 2018, 11:32:54 »
Absolutely gorgeous. This is the nicest custom I've seen in a long time.
Offline nasp
« Reply #10 on: Fri, 19 October 2018, 11:37:59 »
What material? Aluminum?
« Reply #11 on: Fri, 19 October 2018, 11:46:59 »
  • ʘ_ಠ
« Reply #12 on: Fri, 19 October 2018, 11:48:03 »
Offline ewwgin
« Reply #13 on: Fri, 19 October 2018, 11:49:48 »
So many nice TKLs this year. I’m loving it! But I probably won’t own any of the nicer ones since i’m always unlucky / too slow.
Offline Zambumon
    • Keyset projects
Offline Rumblehotep
« Reply #15 on: Fri, 19 October 2018, 13:11:20 »
My god that red is so pretty I dread getting my hopes up. Classic all day
Also @Puddsy holy ____ that profile pic
Offline zslane
« Reply #16 on: Fri, 19 October 2018, 14:24:31 »
I love the design! Unfortunately, I don't use TKL...  :p
Offline mimalik
« Reply #17 on: Fri, 19 October 2018, 14:52:06 »
Same here, wish there was full size option as well.
Offline Wetherbee
« Reply #18 on: Fri, 19 October 2018, 16:30:00 »
I would buy this if the PCB had per-key RGB and Kailh hot swap sockets installed.
It would be nice for the Verne classic to have WKL blockers as an option.
Offline catamscott
« Reply #19 on: Fri, 19 October 2018, 16:39:57 »
loving this, bet it's going to be one competitive raffle
Offline Starston3
« Reply #20 on: Fri, 19 October 2018, 16:40:56 »
Yep.
Offline Jkush463
« Reply #21 on: Fri, 19 October 2018, 16:41:22 »
excited to see this go to IC hope i manage to get a slot.
Offline Zambumon
    • Keyset projects
« Reply #22 on: Fri, 19 October 2018, 18:07:30 »
I didn't want any of those features for this board. I couldn't see myself using any of those features with this keyboard and I don't think they fit with my idea for it. And when I asked Wilba if he could design a PCB for this board I mentioned him that I wanted something uncluttered, and simple, no RGBs, no hotswaps.
« Last Edit: Fri, 19 October 2018, 18:09:22 by Zambumon »
Offline ba7777
« Reply #23 on: Fri, 19 October 2018, 22:09:14 »
 :thumb:
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #24 on: Sat, 20 October 2018, 01:36:07 »
Interested depending on timing and price.
Sent from my mobile using Tapatalk
Offline dario
  • obsessive–compulsive hardware slut
« Reply #25 on: Sat, 20 October 2018, 05:24:36 »
This may be a stupid question, but is it possible to permanently solder switches to those hot-swap sockets? Or at least remove them? Not sure how those things work.
In case all of the answers to the above questions are "no", I may actually prefer your solution.
Offline Wetherbee
« Reply #26 on: Sat, 20 October 2018, 07:35:33 »
Cool beans. Much easier on my wallet then. Zero interest.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #27 on: Sat, 20 October 2018, 08:17:57 »
Uhm... but isn't doing that kinda defeating the purpose of having a hotswap socket in the first place?
Offline Jkush463
« Reply #28 on: Sat, 20 October 2018, 10:03:37 »
couldn't agree more keep it simple all the extra junk just adds cost and is not really that desirable for most, any idea when the raffle will happen?
« Last Edit: Sat, 20 October 2018, 10:13:50 by Jkush463 »
Offline Rumblehotep
« Reply #29 on: Sat, 20 October 2018, 11:11:21 »
Bless, I kind of hate doing sip sockets & leds for boards on top of switch mods but feels like it's wasted potential when a board features it and I don't do it.
Offline dario
« Reply #30 on: Sat, 20 October 2018, 14:19:57 »
Not necessarily. You may have four or five different types of switches you want to try out, and then at the end permanently solder your favourite ones to prevent switch wobble.
« Reply #31 on: Sat, 20 October 2018, 21:07:43 »
im sure you mean well but i have literally never heard of anyone doing that before i saw this post
hotswap sockets tend to be unreliable (in my personal experience) and per key rgb is cool but otherwise not that important
per key rgb is a giant pain in the ass to put on a PCB though, since it requires a lot more design work and costs a lot of money
« Last Edit: Sat, 20 October 2018, 21:09:58 by Puddsy »
Offline Prelim
« Reply #32 on: Mon, 22 October 2018, 05:22:31 »
comes from Spain and no ISO support? :(
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Zambumon
    • Keyset projects
« Reply #33 on: Mon, 22 October 2018, 05:42:03 »
Correct. I didn't need ISO, as US International has all the keys I need, and this is a keyboard for myself.
Offline Wetherbee
« Reply #34 on: Mon, 22 October 2018, 06:05:45 »
lolwut.
Never had any issue with factory installed Kailh hot swap sockets. It is a total game changer.
I don't really understand why someone wouldn't want them. Takes less than a few minutes to change every switch on my board. No reliability issues, and no wobble for fixed layout platemount boards.
Any skepticism disappears the first time you do a switch swap without pulling out the soldering iron.
Is it more expensive? Yes, it increases the price of the PCB slightly and the platemount solution needs to be just right.
Offline Zambumon
    • Keyset projects
« Reply #36 on: Mon, 22 October 2018, 06:51:52 »
If this keyboard was designed for a general public I'd had considered them, but that wasn't the case.
I designed the board for myself, and that gives me the liberty of doing exactly what I want. Because I wasn't going to use them and I actually enjoy spending a weekend's afternoon building a keyboard, I just didn't want to add them.
I am aware that some of my choices (fixed layout, no blockers, no RBG, no hotswaps...) limit how many people are interested about this board, and I'm OK with that, I want people interested on this board to really like it because of how it is right now.
Offline Okonomiyaki#2832
  • Eating Okonomiyaki
« Reply #37 on: Mon, 22 October 2018, 07:12:56 »
Agreed, even if you added all the requested features there is no promise they would buy it lol.
Offline Windeh
  • a no name
« Reply #38 on: Mon, 22 October 2018, 08:15:07 »
There are already plenty of built by committee boards on the market, pretty sure the chances of winning the raffle is already slim as it is...   :p
Offline Jkush463
« Reply #39 on: Mon, 22 October 2018, 19:38:03 »
i dont think people quite understand if you dont like the board as it is you need to find another board because, its perfect how it is lol. just my perspective.
Offline anon23
« Reply #40 on: Tue, 23 October 2018, 03:34:27 »
I really like how simple and perfect it looks. Fixed layout is great, no RGB is totally fine, no hotswap is perfect. The only problem (outside of price possibly) is this part:
This makes me sad, but it looks like an awesome keyboard to build. Will most likely try my luck if I can afford it.
Offline Zambumon
    • Keyset projects
« Reply #41 on: Tue, 23 October 2018, 05:21:24 »
The alternative to a raffle sale is FCFS and the spots would be gone in minutes. FCFS many times only benefits those that are on a convenient timezone. If it was a FCFS some people would miss the buy just because they are sleeping because they have to wake up early, at work, in a meeting, having dinner with their SO... I don't care, they are unable to fill up the form at a extremely specific moment of their day and miss the buy.
Offline dantambok
« Reply #42 on: Tue, 23 October 2018, 06:23:02 »
really sad not seeing WKL blockers  :(
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline bthezebra
« Reply #43 on: Tue, 23 October 2018, 07:31:32 »
He is looking to use them for future iterations.
Offline anon23
« Reply #44 on: Tue, 23 October 2018, 09:03:19 »
Ah that's not exactly what I meant here. Maybe I should have highlighted the whole limited supply then? Because to me, the alternative to raffle is a regular GB where everyone can submit their order, pay and get in.
But I agree, if I had to pick between between the two (raffle and FCFS), raffle is the least worst indeed.
Offline Zambumon
    • Keyset projects
« Reply #45 on: Tue, 23 October 2018, 09:19:54 »
I've already addressed why the quantities are limited.
Offline Nzo
  • wish I was back in CA
« Reply #46 on: Tue, 23 October 2018, 22:52:23 »
No hot swap sockets on the PCB?
« Reply #47 on: Tue, 23 October 2018, 23:11:34 »
scroll up
Offline Nzo
« Reply #48 on: Tue, 23 October 2018, 23:29:40 »
scroll up
Thanks. Ctrl+F failed me the first time :(
That's a pass for me. It's a shame because there isn't very many good looking custom TKLs like this one. I don't need fancy RGBs and other things. But two things I require nowadays on customs is USC-C and hotswaps.
« Reply #49 on: Tue, 23 October 2018, 23:47:16 »
scroll up
i think the k type is the only one
