Author Topic: [IC] Zambumon Verne: Custom TKL  (Read 84400 times)
Offline anon23
Re: [IC] Zambumon Verne: Custom TKL
« Reply #50 on: Wed, 24 October 2018, 02:06:08 »
I've already addressed why the quantities are limited.
Yeah, and I've read it loud and clear that you designed it for yourself and you can do whatever you please. I understand and respect that.
But still, I simply wished to point out that it is sad to see such a great board being limited then. No matter what the reasons are. I'm also waiting to see the price as I may not even be able to afford it anyway if price goes sky high.
Anyway, best of luck mate. It is truly a beautiful board. Though I doubt you need people to tell you that.
Offline vpr
« Reply #51 on: Wed, 24 October 2018, 16:09:42 »
So will the limited edition of a Nautilus Nightmares themed Verne be a seperate buy? Assuming it'll also be a raffle with limited spots (since 'limited edition' is in the title of it)? Will pricing be similar between the two versions?
Offline ipley
« Reply #52 on: Thu, 25 October 2018, 00:51:01 »
did not White Color option?
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #53 on: Thu, 25 October 2018, 06:14:32 »
Yes, it's an extra to the GMK set. It will only be made if the set gets picked up by Massdrop, so people that join the group buy could have matching keyboard and keycaps otherwise it won't be done. It's too early to discuss about it, let's go step by step and just focus on the 3 color options I'll offer.
That was a powder coat prototype, it would be extremly problematic for me to offer them because most units would be rejected.
Offline jihadu
« Reply #54 on: Fri, 26 October 2018, 08:34:06 »
Great looking board. Sad that single layout plates are starting to regain popularity outside the hotswap crowd.
Probably one of the best looking boards out there, though there is no way i'll be able to afford it.
Good luck with the buy sir.
Offline Maxusy
« Reply #55 on: Sat, 27 October 2018, 07:32:11 »
can't you just add the hotswap sockets yourself? I don't see the issue.
b.face x2
« Reply #56 on: Sat, 27 October 2018, 12:00:15 »
people don't wanna put in effort
and they're asking about kailh hotswap sockets, not holtites or whatever other solution
single layout plates make for a better sound and typing experience since it allows the designer to put in more specialized relief cuts and keeps the switches from twisting too much (which happens if you're using plate mount switches with a swiss cheese plate)
Offline Maxusy
« Reply #57 on: Sat, 27 October 2018, 18:00:07 »
never used those but it looks like you can also install those yourself.. just takes a bit of soldering work, no? If anyone cares enough about the design, such a small thing really shouldn't be a big reason to not-buy it imo
b.face x2
Offline catamscott
« Reply #58 on: Sat, 27 October 2018, 18:30:22 »
pcb's have to be explicitly designed to utilize the kailh hotswap sockets. spare hotswap sockets would only be useful if you're replacing one that broke off or something, but you can't just solder them to your average pcb and get hotswap capability
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #59 on: Sat, 27 October 2018, 23:25:06 »
I like the roundness of this :cool:
Offline OracleKev
« Reply #60 on: Sun, 28 October 2018, 00:07:22 »
I want the Classic bottom row layout (winkeyless) with regular (versus stepped) Caps Lock.
IMO, Caps Lock position should be flexible for both layouts.  Bottom row fixed I get it, but Caps Lock fixed only has downside.
« Last Edit: Sun, 28 October 2018, 00:10:05 by OracleKev »
Offline Zambumon
    • Keyset projects
« Reply #61 on: Sun, 28 October 2018, 12:34:59 »
A wild Jamón Red Verne has appeared!
Looks great with Chocolatier too.
Offline cijanzen
« Reply #62 on: Sun, 28 October 2018, 13:49:09 »
So gorgeous!
Offline _rubik
« Reply #63 on: Sun, 28 October 2018, 14:52:34 »
I'm in (price dependent of course).
Offline Starston3
« Reply #64 on: Sun, 28 October 2018, 15:19:30 »
Ooo. Nioce.
Debating between trying to get into this buy or wait/hope Nautilus Nightmare comes true.
Offline Zambumon
    • Keyset projects
« Reply #65 on: Sun, 28 October 2018, 16:17:33 »
Ooo. Nioce.
I wouldn't wait for Nautilus Nightmares, for that set it will probably take a year or more to get done, if it gets done.
Offline Zambumon
    • Keyset projects
« Reply #66 on: Wed, 31 October 2018, 07:41:04 »
To those attending Mechanicon this Saturday: I will be bringing this prototype so you can try the board.  :p
Offline cijanzen
« Reply #67 on: Wed, 31 October 2018, 07:45:23 »
Wish I could be there just to experience Verne! Have fun!
Offline Zambumon
    • Keyset projects
« Reply #68 on: Wed, 31 October 2018, 07:53:07 »
There's the posibility that one of the prototypes will be at the Bay Area meetup, on November 10th.
Offline mrpetrov
« Reply #69 on: Thu, 01 November 2018, 13:29:42 »
Very interested. It's right down the middle of the fairway for what I'm looking for.
Offline cijanzen
« Reply #70 on: Thu, 01 November 2018, 13:31:01 »
Want to come to Canada?
Offline Zambumon
    • Keyset projects
« Reply #71 on: Thu, 01 November 2018, 14:40:33 »
I'm not the one going to the US.  :))
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #72 on: Tue, 06 November 2018, 15:59:00 »
Received mine on Saturday, delivery guy was an odd fella. Thanks for the smooth GB!
JK, very honored to have received one of the protos. My pictures can't do it justice, but it was a pleasure to build. Fixed layout is so nice, and I really like this one being without a weight insert. Love the ano, and spot on gray color! Shame about the PCB being hidden inside the body, it's the most beautiful PCB I've seen yet (check OP for pics of it)
I'm bringing this unit to the bay area meetup on Saturday, so you can inspect it closer there if you are attending.
« Last Edit: Tue, 06 November 2018, 16:01:53 by Oblotzky »
Offline cijanzen
« Reply #73 on: Tue, 06 November 2018, 16:00:38 »
JK, very honored to have received one of the protos. My pictures can't do it justice, but it was a pleasure to build. Fixed layout is so nice, and I really like this one being without a weight insert. Love the ano, and spot on gray color! Shame about the PCB being hidden inside the body, it's the most beautiful PCB I've seen yet.
WOW
Offline ChrisSwires
« Reply #74 on: Tue, 06 November 2018, 16:24:08 »
To clarify on that, when you mention relief cuts: In what manner, and for flex only or also to improve sound? Personally I'd argue that fixed layout plates in fact for the most part sound worse (fixed spacebars for example without cuts between the stabiliser and switch in my opinion sound much worse having tried both on the same board - though sound is always subjective)
Offline Jkush463
« Reply #75 on: Tue, 06 November 2018, 16:34:43 »
ugh please just sell me one already ill pay anything.
Offline Zambumon
    • Keyset projects
« Reply #76 on: Tue, 06 November 2018, 16:36:50 »
Relief cuts on those areas that are covered by the aluminum (between the escape and F row, arrow cluster and navigation cluster... etc). These should help improving sound.
« Reply #77 on: Tue, 06 November 2018, 16:38:48 »
its definitely just for sound
more material = less flex
Offline Zambumon
    • Keyset projects
« Reply #78 on: Tue, 06 November 2018, 16:42:16 »
I don't have a Jamón Red prototype yet. It shouldn't take a lot of time to get it.
Offline ChrisSwires
« Reply #79 on: Tue, 06 November 2018, 16:42:21 »
Sorry when I mentioned flex or sound I meant the reasoning for the relief cuts, not for fixed over universal.
Sent from my Pixel using Tapatalk
« Reply #80 on: Tue, 06 November 2018, 21:56:52 »
relief cuts are a sound thing
but also they're kind of a meme, i love em but i don't think they actually do anything
Offline Zambumon
    • Keyset projects
« Reply #81 on: Tue, 13 November 2018, 06:31:57 »
Verne at the Bay Area meetup last Saturday!
Credit goes to /u/plebtheturtle
Offline Rumblehotep
« Reply #82 on: Tue, 13 November 2018, 13:25:50 »
those rounded edges  :thumb:
Offline toby
« Reply #83 on: Thu, 15 November 2018, 08:46:10 »
the blue for this is very much like the nautilus blue!
Offline Zambumon
    • Keyset projects
« Reply #84 on: Thu, 15 November 2018, 09:18:34 »
Goos observation.
Offline maximize
« Reply #85 on: Thu, 06 December 2018, 21:24:36 »
What a beautiful board. I fully plan to throw my hat in the ring! I haven't noticed any details on GB timing in the thread, though it seems like you have most details fleshed out already. What does your timeline look like, if you can share your thoughts? I understand that once you mention any dates, people will latch on to them, but I promise I won't! ;)
« Reply #86 on: Thu, 06 December 2018, 22:18:43 »
i can tell you that once it goes to gb the lead time will be very fast
so stay in the loop on this
Offline maximize
« Reply #87 on: Fri, 07 December 2018, 09:01:56 »
I certainly will! Thanks for the advice.
Offline Zambumon
    • Keyset projects
« Reply #88 on: Fri, 07 December 2018, 13:52:10 »
Please, do not forget to fill out the form!
Offline gbchk
« Reply #89 on: Sun, 16 December 2018, 11:55:35 »
Any updates?
Offline Zambumon
    • Keyset projects
« Reply #90 on: Sun, 16 December 2018, 19:44:52 »
Offline Techno Trousers
  • ʘ_ಠ
« Reply #91 on: Sun, 16 December 2018, 19:52:05 »
Smooooooth
Offline Rumblehotep
« Reply #92 on: Sun, 16 December 2018, 20:13:22 »
Hot
Offline monkt
« Reply #94 on: Tue, 18 December 2018, 11:39:43 »
Any updates?
Oh, my. That is....
Please post a photo from the front. I really need to see more of Serika with that red body. Really stunning.
Offline Zambumon
    • Keyset projects
« Reply #95 on: Tue, 18 December 2018, 13:33:33 »
Any updates?
Oh, my. That is....
I've already done that
Offline zeusinthesheets
  • I like borgers
« Reply #96 on: Tue, 18 December 2018, 13:34:11 »
Any updates?
Oh, my. That is....
That's quite beautiful!
Sent from my Moto G (5) Plus using Tapatalk
RAMA Koyu Haze | SA Laser | Holy 🅱️andas
Offline zizard
« Reply #97 on: Tue, 18 December 2018, 15:37:55 »
Bit odd to have a tight spacing between the number row and function row, with a large unused margin above the function row.
Offline Zambumon
    • Keyset projects
« Reply #98 on: Tue, 18 December 2018, 17:38:18 »
But I like it that way.
Offline Maxusy
« Reply #99 on: Tue, 18 December 2018, 18:06:09 »
I think it's nice to see you are putting so many 'unusual' features in this board that are new. It's not just some 10degree angle, few standard ano options, big brass weight and a cheesegrate plate with some ****ty logo on it.
It's got many unusual features which seem to reflect what you think of as important, such as having a fixed plate and slightly different gaps. Good stuff  :thumb:
b.face x2
