Author Topic: The space bar is always the worse switch on a keyboard  (Read 3761 times)
Offline phototristan
    • https://www.youtube.com/phototristan
« on: Mon, 03 May 2010, 11:30:38 »
Doesn't it seem strange that the spacebar is just a normal switch like any letter switch, yet it gets many more presses than any other key?
I think this is why on the Model Ms, (and likely most all other boards as well), the space bar always feels a bit weak compared to other keys.
Should they have made that one switch a bit more robust than all the others?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #1 on: Mon, 03 May 2010, 11:37:14 »
Quote from: phototristan;178500
Although the spacebars on Ms generally feel different from the rest of the keys, I wouldn't say they feel weaker or more abused. I have yet to find a case of Model M spring inconsistency, in fact...just overall different feeling from board to board, no true variance within a particular keyboard except between types of keys (small vs large).
I wonder what could be accomplished by using two switches for a spacebar? Put them in parallel electrically, one at each end of the spacebar, with a stabilizer rod between them.
kishy.ca
Offline ch_123
« Reply #2 on: Mon, 03 May 2010, 11:37:22 »
Some Cherry keyboards used higher strength switches for the space bar. The Model F had a stabilizer mechanism that made it much harder to press than other keys (about 90g vs 65g)
A lot of people find such arrangements unpleasant and engage in various mods to make the space bar as light as the other switches.
Offline Nonmouse
« Reply #3 on: Mon, 03 May 2010, 11:45:04 »
Quote from: ch_123;178506
Not to mention a stabilizer bar.  The spacebar on most of my keyboards is noticeably stiffer than the other keys.  Of course, since I'm thwapping it with my thumb, I don't notice the additional force when I'm typing.
Offline itlnstln
« Reply #4 on: Mon, 03 May 2010, 13:07:09 »
I hate when Cherry does this.  The first thing I do is swap the spacebar switch with Scroll Lock.
Offline JBert
« Reply #5 on: Mon, 03 May 2010, 15:02:27 »
Quote from: ripster;178504
[strike]If you want stiff get a Model F AT.[/strike]
If you want a decent spacebar get a model F AT.
There, fixed that for you.
Mine is no NIB but it works perfectly fine, thank you very much.
Also, webwit can prove that you don't need a spacebar. Just watch.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ricercar
  • mostly abides
« Reply #6 on: Mon, 03 May 2010, 16:29:34 »
Quote from: webwit;178596
Youdon'tneedaspacebar.
But then how will I scroll down in my browser?
Offline audioave10
« Reply #7 on: Sat, 15 May 2010, 10:06:11 »
It seems there is a better chance to hit the space-bar at a non-optimum angle.
I'm suprised they last as long as they do. As a gamer, my "W" key gets more abuse.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
new: MechanicalEagle Z77 RGB/Blues
