Author Topic: Replacement for halo clears  (Read 2879 times)
Offline HotRoderX
« on: Mon, 22 October 2018, 13:57:25 »
I got a Espectro keyboard coming in and looking to do something unique with the switches. I was thinking of using Halo Clear's cause I love these switches. I like how they have that nice tactile feel. Then they rebound pretty hard on bottom out. Its just a nice typing experience. My hang up on clear's is the fact you can't use LED's with the housing, I know I could replace the housing but was wondering if anyone could suggest perhaps another switch that give a similar feel.
I have also entertained the idea of just not using LED's in the build. I have read a lot of people forgo led's which might not be a bad idea since the board I plan to build not sure if LED's would compliment it or take away.
Build is as follows
Emerald Green Espectro
GMK Terminal
Brass Plate
Unknown Switch
