_________________________________________________________________________________________
GROUP BUY THREAD IS UP!!!Updates:- 23rd October 2018 - Interest Check Posted
- 26th October 2018 - Placed order for Prototypes
- 11th November 2018 - Prototype Received
- 18th November 2018 - Design Finalized, Pre-GB IC Form Posted
- 23rd November 2018 - Master Sample prototype ordered, Anodizing color samples ordered
- 13th December 2018 - Received Reflex Master Sample prototype HERE.
- 16th December 2018 - Reflex Typing Test Posted HERE.
- 18th December 2018 - Received Paradox Master Sample prototype HERE.
- 19th December 2018 - Removed Blue Grey color and copper plate option. Details in THIS post.
- 20th December 2018 - Color Samples Posted HERE
- 20th December 2018 - GB Pricing announced HERE
- 24th December 2018 - GB Thread up!! HERE
__________________________________________________________________________________________
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 207387-0](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=207387;image)
Hi geekhack,
I'm Windeh, a relative new member of the community.
After a few frustrating attempts at sniper-submitting google forms & raffling GB spot from popular designers and failing, I asked myself, why not just design a keyboard myself?
I thought about what would make MY perfect keyboard? With a few ideas in mind, I set about downloading Fusion 360.
A couple of YouTube Tutorials later, shapes resembling a rectangular block started to form…
First, let me highlight some of the more unique features of my design;
Mounting.
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 206017-2](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=206018;image)
As per the title of this IC, the plate is Sandwiched between O-Rings, with no part of the plate in contact with either the casing or the screw, creating a true “Floating” design. I call this mounting method “O-ring-Sandwich-Floating mount”. You heard it here first.
Unlike traditional "Gasket" mount, where most contact between the gasket & the plate is desired together with high clamping force to dampen all vibrations, this mounting method more closely resembles a xylophone, with minimal contact surface and added isolation between the plate and the rest of the keyboard. The design when tightened, does not clamp directly onto the plate through the O-Ring, but stops when the O-Ring posts on the top & bottom of the case meet. Depending on the Durometer (hardness) of the O-Ring, the plate will experience a stronger or lighter clamping force, therefore change the way it is allowed to resonates (and to a smaller degree, feel). By simply changing the hardness of the O-Ring, you can easily tune the resonance & tone of the plate.
Why the O-Ring Cutout?
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 206589-5](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=206590;image)
Proper application of O-Rings requires that they are supported on both sides perpendicular to the force exerted. Without the support of the side wall created by the cutout, the O-Ring would be easily squashed, causing rapid deformation & deterioration of the material, while not providing enough pressure onto the plate. The O-Ring would start to harden & crack, altering the acoustics & feel of the keyboard with time, and possibly cause looseness of the plate.
There is, in my opinion, no alternative method to apply the O-Ring in this application.
Floating?![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 206591-6](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=206592;image)
There is a minimum of 0.5mm gap between the plate & any hard surface of the case.
Spacebar “MEME” cut.![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 207399-7](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=207400;image)
The first time finished building my TX60, I immediately noticed that with such a rigid sandwich mount, the spacebar makes a loud “KUNK” every time it bottoms out. I know there are mods out there that addresses this “feature”, however I wanted to try to address this from the keyboard design side, and tried to reduce the rigidity of the mounting post closest to the spacebar, to give it some “flex” where it is needed the most.
ANSI layout only.![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 207397-8](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=207398;image)
After having to deal with a wonky “\” key on an universal layout, I said “No more”.
Compatibility with existing PCBs on the market.![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 206003-9](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=206004;image)
Not gonna lie. I have no knowledge on PCB design and no friends with that skill set. I don't want to be tied to a proprietary PCB that you’re SOL when it dies down the road. I will not force RGB, Hot Swap Sockets, Bluetooth, or JigOn down your throat. You choose your poison.
Hate tall fronts?![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 206005-10](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=206006;image)
This one is under 20mm.
Two Very different chassis designs and focus, same plate & top.![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 206007-11](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=206008;image)
Because choices.
I think I have gone on long enough… Let me introduce the Reflex and Paradox 60% Keyboards;
Reflex : The name refers to the reflex port on a speaker system. I heard people in the community are big on sounds, so I took a literal approach, and thought of the PCB & Plate as the diaphragm on a loudspeaker, then proceeded to designed a reflex port for all that juicy auditory goodness to escape out the bottom of the case. And the weight. You can't forget about the weight.
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 207389-12](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=207389;image)
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 207391-13](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=207391;image)
Next up, it’s the
Paradox :
The MK Community is a hard place to be an enthusiast. You want to throw your money at something, but it is thrown back at your face in 41 seconds.
Not gonna pretend that the Paradox didn’t take inspiration from other keyboards. But with the 60% layout, plate mounting method, weight quantity & design, material and all of the above, I believe there are enough uniqueness that there is a place for the Paradox to exist in the MK community.
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 207393-14](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=207393;image)
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 207395-15](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=207395;image)
Now, some details.
- Case: Standard configuration in 6063 aluminium, optional upgrade to 7075-T6 aluminium
- Weight: Sandblasted/Polished Brass finish options. Clear coating option for sandblasted only, as coating does not adhere well to polished brass
- Screws: YFS Grade 12.9 Alloy Steel Hex Screw
- O-Rings: Will include a few different hardness/material O-Rings
- Colour: For 6063 Aluminium - Normal Anodizing in Black, Dark Grey, Deep Red, Royal Blue, Silver, Rose Gold (maybe). For 7075-T6 Aluminium - Hard Anodize in Black only. All anodizing in Matt finish only.
- Plate: Standard kit with Brass plate, optional Aluminium & Brass Plate extras, Sandblasted
- Layout: 60% ANSI WK/WKL with split right shift and optional split backspace & stepped caps lock
- Quantity: 30 total spots
- Timeline: Aiming at December / January GB
- Design: Both Paradox & Reflex will be made, 15 sets of each
GB Pricing (All pricing in USD):- NO PCB INCLUDED IN THIS GB!
- $490 for base kit includes 6063 Case Top (Standard or WKL) & Case Bottom in normal anodizing, Clear Coated / Raw Sandblasted Brass Weight and Raw Sandblasted Brass Plate
Optional extras:- $35 for upgrading to 7075-T6 Case Top & Bottom in Matt Black Hard Coat Anodizing.
- $20 for Polished Brass Weight (Polished on exterior sides only, Raw).
- Extra Plates in Raw Sandblasted Brass ($50) / Sandblasted Aluminium (Anodized Deep Red - $60)
As I said at the beginning of the GB, the keyboard is mainly designed to be MY endgame. If a group buy is happening, it will be a very small quantity to dip my toe in the water and have a feel of what I'm getting myself into.
Feel free to leave comments below, and I will reply when I can.
___________________________________________________________________________________________________________________________
![[IC] Reflex & Paradox - 60% O-Ring Mount (GB Preparation) 206327-16](https://geekhack.org/index.php?PHPSESSID=ufqire0n3u3ik2fon96rlus62a4b86hh&action=dlattach;topic=97859.0;attach=206327;image)
