Author Topic: Petition: Add Colemak as a pre-installed keyboard layout to Microsoft Windows  (Read 9970 times)
Offline NottNott
The Petition
It is encouraged to both sign this and then leave a link to the petition on Windows' Feedback Hub application by pressing Windows+F on Windows 10 - that's all!
« Last Edit: Sat, 27 October 2018, 07:36:38 by NottNott »
Offline RominRonin
It would be a step forward, but mod-dh should be the standard colemak layout imo, and that should also be supported.
Sent from my Moto G (5) Plus using Tapatalk
Offline Chekonjak
There's a post in the Feedback Hub already! I wish OS developers would just leapfrog all these concerns and release a well-supported low-level keyboard layout creator. It would also help if laptop manufacturers would help out rearranging keycaps - looking at you Microsoft Store!
Offline ala
On windows platform the software was there for years, "Microsoft Keyboard Layout creator". The issue is however that you need to install the new layout everywhere before you can use it. Windows is the last OS which doesn't have colemak built in - it's a shame Microsoft!
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Ok I signed it!
Happy typing!
Just my thoughts
