Author Topic: [IC] Stemshaver - a tool to fix BOX switches  (Read 76459 times)
Offline 82d28a
Re: [IC] Stemshaver - a tool to fix BOX switches
« Reply #150 on: Wed, 09 January 2019, 16:43:49 »
Any updates? Thanks
Offline apossardt
« Reply #151 on: Thu, 10 January 2019, 00:07:02 »
+1 for getting one even considering any minor issues. Really itching to fix some of my switches
Offline 82d28a
« Reply #152 on: Mon, 14 January 2019, 16:08:43 »
Any updates?
Offline gutsack
« Reply #153 on: Thu, 17 January 2019, 21:42:50 »
Registering very late interest.
Offline thearctican
« Reply #154 on: Fri, 18 January 2019, 09:33:00 »
Has this died?
Offline Techno Trousers
  • ʘ_ಠ
« Reply #155 on: Fri, 18 January 2019, 21:26:06 »
Has this died?
Death by a thousand stem shavings.
I hope it's just bring perfected and still going forward.
Offline lutchbu
« Reply #156 on: Sun, 20 January 2019, 14:53:57 »
Has this died?
Not dead yet, just put a bit on the backburner over the holidays.
There will be an update soonish.
Offline GigaFlop
« Reply #157 on: Mon, 21 January 2019, 18:51:16 »
Has this died?
Looking forward to the update. My Mitolet set has been waiting to be used safely <3
Oh god why did my wallet get so thin
Offline roostrc0gburn
  • its just plastic
« Reply #158 on: Mon, 21 January 2019, 21:28:04 »
Has this died?
same. been waiting for this to put box royals in my purple ares... if anyone has one of the prototype shavers pls contact me!
Offline Kavik
« Reply #159 on: Thu, 24 January 2019, 19:49:48 »
Has this died?
An IC for a competing product is now on Reddit and Keebtalk. Looks like a race to GB now.
Offline Geroximo
« Reply #160 on: Sat, 26 January 2019, 13:26:16 »
The demand is high. I can't wait to actually put keycaps on my BOX blacks again.
Offline GigaFlop
« Reply #161 on: Tue, 29 January 2019, 18:02:00 »
Has this died?
Can you link or PM me the reddit post?
Offline ideus
  • Björkö.
« Reply #162 on: Wed, 30 January 2019, 10:24:47 »
Has this died?
Would like to get the link as well.
Offline euphxenos
« Reply #163 on: Wed, 30 January 2019, 12:42:37 »
Offline ChitownM2
« Reply #164 on: Wed, 30 January 2019, 14:32:09 »
Definitely interested in this
Offline ideus
  • Björkö.
« Reply #165 on: Wed, 30 January 2019, 17:46:15 »
Definitely interested in a tool like this or the other fellow's. Some healthy competition does not hurt for a solution that allows the use of the nice box switches. Thank you.
Offline Starius
« Reply #166 on: Thu, 28 February 2019, 21:23:50 »
Any news on this project?
Offline Bleddyn
« Reply #167 on: Fri, 01 March 2019, 11:55:18 »
would be in for one, i have one board with box royals and another with box yellows.
Offline lutchbu
Re: [IC] Stemshaver - a tool to fix BOX switches - Update 3
« Reply #168 on: Thu, 21 March 2019, 11:14:28 »
UPDATE 3
(finally)
OVERVIEW
testresults, i've been takling to a cnc shop and decided to drop the artisan idea
TESTRESULTS
  • design: Material will be steel and the stemshaver does not need a bevel. No bevel would cut costs by ~25% but means that there might be a slightly higher force required to operate
  • function: Prototypes produced the desired results but had to be applied a second time rotated 180°. This is due to my milling setup and should not be an issue with the ones produced by the cnc shop.
  • durability: Prototypes were tested on up to 200 switches with minimal to no wear observed
PRICE
Current estimate is 10-18 USD for the regular version, depending on quantity.
and now?
I'm not quite sure how to proceed from here to be honest. Ideally, I would want to send out a batch of prototypes made by the cnc shop to test them out. However I do not have the means to finance a small prototype run.
So... any advice?
Offline dyrdevil
« Reply #169 on: Thu, 21 March 2019, 11:32:36 »
set up a GB? then you don't have to finance it yourself.
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #170 on: Thu, 21 March 2019, 11:50:00 »
Honestly you are at the point of either running the GB right away or just stopping the project if you feel you aren't ready(there are 2 others trying to do the same thing). I don't mean you have to rush, just need to figure out what you want to do sooner rather than later.
If the CNC shop can make the shavers better than the original prototypes were done, you will have a great product on hand. Also do not remove the bevel/chamfer as that actually helps as it makes it a blade rather than a cold extrusion(pushing a material through a form to reshape whilst at room temp). Blades are way more effective at shaving given the fact the form would more than likely deform if there was no bevel/chamfer and cut much wider than desired, while blades won't.
  • its just plastic
« Reply #171 on: Thu, 21 March 2019, 12:25:19 »
send me one of the prototypes for testing
Offline ChitownM2
« Reply #172 on: Fri, 22 March 2019, 21:55:47 »
I'm still interested in getting one of these.
At $10-15 I'm definitely in for being a part of a small group of guinea pigs to try it out and see if there are any issues if you want to go that route before launching a large GB order.
Offline bunanapeel
« Reply #173 on: Sat, 23 March 2019, 10:42:55 »
Well I'm ready to buy it, sounds like having a bevel is a better bet than without.
Offline ideus
  • Björkö.
« Reply #174 on: Sat, 23 March 2019, 11:06:36 »
Can use 100 light blues box SW for testing your device. Offer a well documented report.
  • its just plastic
« Reply #175 on: Sun, 24 March 2019, 00:18:46 »
same. i have 100 box royals (old stem design). i would assume if there are multiple testers, a general form is better for everyone to share results. we could collaborate through a google doc or something similar
Offline gutsack
« Reply #176 on: Sun, 24 March 2019, 13:25:15 »
Also up for spending some money to help test. I have about 200 box whites here and plenty of box royals and jades as well.
Offline Starius
« Reply #177 on: Sun, 24 March 2019, 13:36:26 »
215913-0
I have all these, and then some!
Get me a Stemshaver, STAT!
 :thumb:
Offline voight-kampff
« Reply #178 on: Sun, 24 March 2019, 14:21:51 »
Yeah, I want one too
Sent from my MIX using Tapatalk
Offline ideus
  • Björkö.
« Reply #179 on: Sun, 24 March 2019, 21:13:53 »
Excellent idea. Having the same report makes results comparable.
  • its just plastic
« Reply #180 on: Sun, 24 March 2019, 23:39:24 »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #181 on: Mon, 25 March 2019, 02:00:56 »
I have hundreds of box switches just sitting in a corner. Hopefully this will make me love them again!
Offline jobicoppola
« Reply #182 on: Wed, 27 March 2019, 06:48:35 »
also have bunch of box switches just sitting around waiting to be shaved, would def be in for this
Offline lutchbu
« Reply #183 on: Fri, 29 March 2019, 11:40:14 »
...Also do not remove the bevel/chamfer as that actually helps as it makes it a blade rather than a cold extrusion(pushing a material through a form to reshape whilst at room temp). Blades are way more effective at shaving given the fact the form would more than likely deform if there was no bevel/chamfer and cut much wider than desired, while blades won't.
You are right, a bevel would be more efficient. Hence why the flat version requires a bit more force to operate. But the test results indicate that both versions are equally effective and produce the desired results.
There are several reasons why I think the flat version would be good enough or maybe even better:
  • With a flat top it is less likely to shave off too much if the stemshaver is not used perfectly straight as the edges can't dig in as easily
  • The flat version should be more durable than the beveled version since there is more material to support the cutting edge
  • A flat top is easier to manufacture and therefore less expensive
Offline ideus
  • Björkö.
« Reply #184 on: Fri, 29 March 2019, 14:25:07 »
The reasoning given is sound. Being a manufacturing engineer I can confirm the logic.
Offline fireworm
« Reply #185 on: Fri, 29 March 2019, 22:17:00 »
Anyone with a prototype that wants make $10 doing some shaving, pm me.
  • ʘ_ಠ
« Reply #186 on: Thu, 04 April 2019, 23:27:54 »
I say go ahead with the full GB. If it's like $20-25 shipped in the U.S., that's not going to bankrupt anyone. And if it turns out there are any unforeseen issues, I'll bet enough people would be in to buy a corrected CNC version in a second round.
Offline mmd1990
« Reply #187 on: Mon, 08 April 2019, 04:54:11 »
I could also use one (EU)
Got 200 switches
Offline binxberry
« Reply #188 on: Wed, 10 April 2019, 13:16:40 »
I’ve got a bunch of jades I need to shave down so I’d be in for one!
Offline Allo
« Reply #189 on: Sun, 05 May 2019, 18:28:47 »
Any update on this?
Offline crzone
« Reply #190 on: Mon, 06 May 2019, 14:10:43 »
Sorry, I have been watching this for a while but I decided to go with the Cruciformer project.
Offline sevenseacat
« Reply #191 on: Tue, 07 May 2019, 01:13:12 »
I've bought a Cruciformer as well. Been waiting for this for way too long.
Offline Starius
« Reply #192 on: Tue, 07 May 2019, 07:10:20 »
Have you gotten yours yet? I don't know if I ever saw when they were expected to be due.
Offline crzone
« Reply #193 on: Tue, 07 May 2019, 11:04:04 »
They haven't shipped yet.
According to a post by rudbear dated May 4th, if all goes well it should ship next week. I assume that proxies will need additional time, so one extra week on top of the initial ship date maybe.
A quote from a post made yesterday on reddit:
"I'm working with a tentative shipping date of May 18th as we've got bubble mailers, labels, materials, and all that sorted out, I think."
« Last Edit: Tue, 07 May 2019, 11:06:40 by crzone »
Offline Starius
« Reply #194 on: Tue, 07 May 2019, 14:50:48 »
Ah cool, thanks for sharing the update! 👍
Offline victorpre
« Reply #195 on: Tue, 14 May 2019, 07:13:04 »
Run a group by, I'm definitely interested
  • its just plastic
« Reply #196 on: Tue, 01 October 2019, 10:04:11 »
this dead?
Offline heavyheaded
« Reply #197 on: Tue, 01 October 2019, 11:08:53 »
this dead?
Seems to be. The cruciformer did get produced and I have some, but I'm not sure what the status of this pre-order is on their page. https://rudbeardesign.myshopify.com/
Offline mmd1990
« Reply #198 on: Wed, 13 November 2019, 15:43:30 »
I am interested and also in EU.
If anyone has a prototype they no longer use and want to sell it?
Offline d.caminero
« Reply #199 on: Fri, 15 November 2019, 04:13:34 »
mechboards UK recently received their order. ask mike for extras, I think he should have plenty
