Author Topic: [IC]SP SA 128K (Color sample chips updated Fab.18)  (Read 128937 times)
Offline hoq
    • wolfmark.work
Re: [IC]SP SA 128K (update Dec.9)
« Reply #50 on: Sun, 10 February 2019, 09:53:31 »
Mac kit added!
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
Re: [IC]SP SA 128K (update Fab.10)
« Reply #51 on: Sun, 10 February 2019, 12:48:17 »
This has my name all over. I'm in.
Offline pixelpusher
« Reply #52 on: Sun, 10 February 2019, 13:19:16 »
Mac kit added!
I think you meant (ON) for the side print in the illustrator set, not (NO)
Offline AaronR
« Reply #53 on: Sun, 10 February 2019, 18:11:26 »
Spacebar kit has (no) listed also instead of (on) for the side printing
Offline vicissitude
« Reply #54 on: Sun, 10 February 2019, 23:19:42 »
Money is ready.
Just make the GB happen.  :p :p
Offline mimalik
« Reply #55 on: Tue, 12 February 2019, 08:07:39 »
Not sure if SP will be able to do side printing. But now more I look at it, I find that it will be much cleaner and better set w/o the side print. Again just my personal opinion, not asking that set be modified.
Offline pixelpusher
« Reply #56 on: Tue, 12 February 2019, 11:30:16 »
SP can do side printing, as stated in the Q&A of the OP.  Plus we know they can b/c of SA Retro :)
Offline hoq
    • wolfmark.work
« Reply #57 on: Tue, 12 February 2019, 11:41:34 »
OK, modified! Thanks.
Offline hoq
    • wolfmark.work
« Reply #58 on: Tue, 12 February 2019, 11:43:36 »
That's no problem, I have asked SP , they told me OK.
Just like SA Carbon and Camping, their LED windowed Capslock and Scroll Lock keys also have side print legends.  :))
Offline hoq
    • wolfmark.work
« Reply #59 on: Tue, 12 February 2019, 11:44:14 »
HH. Thanks bro.
Offline otanishock
  • ファーストラブ
« Reply #60 on: Tue, 12 February 2019, 12:34:33 »
Any updated timeline avail?
Offline Juiceion
« Reply #61 on: Thu, 14 February 2019, 20:43:42 »
How much extra would it cost to have the side print icons? I think side print is cool but wouldn't they need to make new moulds for each key?
Offline AaronR
« Reply #62 on: Thu, 14 February 2019, 21:34:22 »
I think the side printing should be removed from the Mac kit as it doesn’t match the rest of the mods as they lack the side printing
Offline hoq
    • wolfmark.work
« Reply #63 on: Fri, 15 February 2019, 06:16:49 »
Not that high with side print icons. I'm not sure if SP need made some molds, but I don't think that will far more high than the normal ones.
Offline hoq
    • wolfmark.work
« Reply #64 on: Fri, 15 February 2019, 06:18:44 »
Maybe I run this in March.  :blank:
Offline hoq
    • wolfmark.work
« Reply #65 on: Fri, 15 February 2019, 06:21:11 »
Yes, you said right. I thought people like those MAC option and command icons, so I added.
If I removed those icons, the kit should be some what cheaper I think.
Offline coffeeshopcoder
« Reply #66 on: Fri, 15 February 2019, 10:57:33 »
I personally like the mac kit with the side printing. Its unique, although not in keeping with the theme of graphics applications.
If you decide to take it off, What would be cool is if you could try the mac kit as "novelties" with the proper icons double-shot. I don't think SP has molds for the mac ctrl, opt, and the command icons, hence "novelty". This is a heavily icon focused kit, and I think it would be a awesome if the community had a proper icon mod kit for the SA profile !
Offline Cods
  • Penumbra SA Mark II please?
« Reply #67 on: Sat, 16 February 2019, 08:04:27 »
I use neither photoshop, nor illustrator.... but you had me at SP + SA + Mac.
Model M Industrial, SSK, Unicomp 104, Code TKL MX Green, FC660M MX Green + Clear + White + Grey, FC660C Topre 45g, MagicForce 68 USB and Bluetooth, Whitefox, some optical switch 65% Bluetooth split spacebar thing ... wait, I think I need an intervention. Too late, there’s a couple of new Model Fs on the way.
Too much SA is never enough.
Offline vicissitude
« Reply #68 on: Sat, 16 February 2019, 08:14:28 »
Mac kit is so nice.
Can't wait.  :D
« Reply #69 on: Sat, 16 February 2019, 23:41:53 »
Glad to see there is support for a mac kit !!! loving this !
I hope one day SP will have proper icon mod molds for mac!
Offline mudcakehoney
« Reply #70 on: Sun, 17 February 2019, 14:27:12 »
Hey hoq, any update on Mechanist :) just wondering if production has started yet
Offline JPVann
« Reply #71 on: Sun, 17 February 2019, 15:21:11 »
Love having a practical reason to justify new good looking keycaps!
Offline hoq
    • wolfmark.work
« Reply #72 on: Mon, 18 February 2019, 05:08:46 »
I haven't asked SP whether they would like to make new MAC novelties for themself yet, but it's really hard to tell.
As an additional information, the cost of mold for permanent use is not the same with one-time use mold.
If I ask to make novelties keys for myself, which will be charged 50USD for each new mold to me, which just for me for temporary use.
because I pay for them, SP will not use these molds for other designs of any other designers for universal keyset designs.
Unless SP is planning to make their onw MAC novelties, but the long-lasting mold is very high, SP may have their own decision.
Offline hoq
    • wolfmark.work
« Reply #73 on: Mon, 18 February 2019, 05:09:56 »
A production slot has been ordered.
« Last Edit: Mon, 18 February 2019, 06:11:22 by hoq »
Offline hoq
    • wolfmark.work
« Reply #74 on: Mon, 18 February 2019, 07:29:04 »
Color chips as below:
Offline RealLaugh
« Reply #75 on: Tue, 19 February 2019, 15:49:32 »
Just out of interest can you tell me how ON and OB are used in the Ai kit? I thought there was only one (ON or OB but not both).
« Reply #76 on: Tue, 19 February 2019, 19:01:40 »
Its there on the OP. Here it is again (I also thought this was hard to find on OP).
KeyColor(LegendColor)
Offline hoq
    • wolfmark.work
Re: [IC]SP SA 128K (Color sample chips updated Fab.18)
« Reply #77 on: Tue, 05 March 2019, 02:56:20 »
hi ,everyone ,
I have got the price from SP, I'm planning to run a group-buy on 5th March.
The prices are not that high except Mac kit. SP said that front-print keys are too much to get them done.
It's the first time they handle so many front-print keys.
Offline AaronR
« Reply #78 on: Tue, 05 March 2019, 03:48:23 »
I bet it’s too late to remove the side printing on the Mac kit as that price is a joke
I can’t really see selling 50 plus Mac kits to make closer to reasonable
« Last Edit: Tue, 05 March 2019, 03:51:19 by AaronR »
Offline hoq
    • wolfmark.work
« Reply #79 on: Tue, 05 March 2019, 07:48:32 »
Yes, I'm a little hesitant to remove the front-print of Mac kit to make it cheaper.
« Reply #80 on: Wed, 06 March 2019, 00:21:52 »
Is the GB starting today ? I don’t see a gb post ?
« Last Edit: Wed, 06 March 2019, 15:08:49 by coffeeshopcoder »
Offline skaloola
« Reply #81 on: Tue, 12 March 2019, 07:47:56 »
Why the "Hello" return?  why not just ditch that and offer regular return?  does anyone actually that key?  or make icon mod even
i'm considering purchasing but that key alone is aggravating to me
Offline duxbridge
« Reply #82 on: Mon, 05 August 2019, 18:33:04 »
As a Mac user, I whole-heartedly support this IC!
