Author Topic: IBM Wheelwriter 1500 mod  (Read 3111 times)
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
« on: Sun, 25 November 2018, 10:13:59 »
Tomorrow I shall be the owner of an IBM Wheelwriter 1500 typewriter. :thumb: The previous owner said it doesn't work but that's ok since I'm mainly interested in the keyboard. And if the kb is busted I can simply harvest the caps for my Model Ms.
Does anyone know a hack for getting the kb to work with a desktop computer? I'm not much of a techie so I'm not sure what I'm capable of achieving on my own. I can refurbish but when the trouble is in the electronics I seize up and get the sweats.
207721-0" alt="" class="bbc_img" />
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
Re: IBM Wheelwriter 1500 mod
« Reply #1 on: Sun, 25 November 2018, 10:40:04 »
I am pretty sure that there is at least one thread here detailing how to do that. Look back maybe 2-3 years?
edit - does this help?
https://geekhack.org/index.php?topic=55676.msg2016762#msg2016762
« Last Edit: Sun, 25 November 2018, 10:42:38 by fohat.digs »
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Offline invariance
  • ...here with all the other boson's
« Reply #2 on: Sun, 25 November 2018, 16:17:24 »
Keep the Wheelwriter as a whole, don’t split the keyboard out, ‘cause it’s heavier than any Korean custom will be
« Last Edit: Sun, 25 November 2018, 21:55:54 by invariance »
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline smarmar
« Reply #3 on: Mon, 26 November 2018, 11:32:16 »
HA! That's actually not a bad idea. I can use the body as a spacious kb tray or make a terrarium!  :thumb:
These will definitely help. Thanks. I just don't know if I'm able to do a full conversion by my lonesome. YIKES!
