Author Topic: good or bad find?  (Read 2596 times)
Offline boaby
good or bad find?
« on: Fri, 07 May 2010, 09:30:48 »
A local gumtree seller is selling some old ibm gear. I phoned up about the keyboard and she said its an  InfoWindow 3153 with a part number 8131277. Struggling to find any good info on the keyboard though - is it worth chasing up?
Also, whats a good resource cross-referencing ibm part numbers?
« Last Edit: Fri, 07 May 2010, 10:15:28 by boaby »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
good or bad find?
« Reply #1 on: Fri, 07 May 2010, 12:34:23 »
InfoWindow is a type of IBM dumb terminal. 3153 will be able to be cable swapped like my signature links explain.
Conversion techniques exist. It is not natively PS/2 or anything truly usable, yet.
kishy.ca
Offline EverythingIBM
good or bad find?
« Reply #2 on: Fri, 07 May 2010, 15:09:28 »
Quote from: boaby;179779
Just take all of the IBM equipment. That's what I would do.
Offline boaby
good or bad find?
« Reply #3 on: Fri, 07 May 2010, 19:14:18 »
cheers kishy, think i'll be leaving her to it.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
good or bad find?
« Reply #4 on: Sat, 08 May 2010, 11:14:53 »
Quote from: EverythingIBM;179969
I'd do it if it was free.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
good or bad find?
« Reply #5 on: Sat, 08 May 2010, 12:27:27 »
Quote from: boaby;180055
If she's going to junk it, I'd at least take the keyboard for parting out here (keycaps are mostly normal Model M compatible assuming it's a Model M type keyboard rather than F)
Other than that, little use unless you're into hardware hacking on any level.
kishy.ca
Offline ch_123
good or bad find?
« Reply #6 on: Sat, 08 May 2010, 12:51:54 »
A 3151 is a Model M. It's one of those 101-keys where each F key has two  numbers on it (i.e. - F1 F13, F2 F14 etc)
In fact, it might be one of those terminal minis...
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
good or bad find?
« Reply #7 on: Sat, 08 May 2010, 13:26:50 »
Quote from: ch_123;180212
So when I finally decide to tell people there's nothing special about a terminal keyboard, I potentially advise someone away from a terminal mini?
FML.
kishy.ca
