Author Topic: MEM 3d printed modular ergonomic mouse, teensy 2.0 and pmw3360 sensor  (Read 94952 times)
Offline praxis87
Yep, that's the spot.  The wires soldered to the end pins on the teensy prevent the catch from seating fully.
Ohh... Never seen round body tac switches before.
Dactyl-Manuform 5x6 | 1984 IBM Model M | Anne Pro 2 | Sweet16 | MEM-AR v9
Offline iso
I found the round switches when I took apart an old display to salvage the electronics, of course I had to order 100 of them.
@praxis87 - Does your teensy have headers ? I added some pins and I can see why wire management is a bit of a problem.
@nevin - Order the electronics and other piece of hardware you`ll need to assemble this, by the end of the next month you`ll receive the plastics. As I remember the sensor will take minimum 2 weeks to arrive. When Im done modifying the sensor compartiment/cap I`ll message you about shipping money/location.
Offline nevin
@iso - awesome! i'll get with you in the next couple days to put a complete parts list together for myself as well as any others that decide to print/build. (looks like most of it is listed, just want to make a concise list)
what gauge wire you guys using? i just got a multicolor spool of 30awg for another project.
i did like the angled 3 button piece, reminded me of an engine block (the holes & the angle) but the revised will probably be easier to work with.
excellent work as always.
Offline iso
24 gauge/0.4mm, solid copper for teensy to the sensor connection, you can get those from LAN cables. Ads lots of stiffness to the assembly, also I added double sided sticky tape on top of the sensor`s IC, to hold the teensy as I soldered those two together.
Everything else is from old/salvaged USB/HDMI/VGA cables. I have probably over 50 colors to choose from. I dont remember ever buying cables/wired for DIY projects.
As I`m trying to create space to add more wires, the design of the sensor/teensy case will chage, aready did 3 itteration of whats in the pictures, when Im happy with the result, I`ll add the OBJ again with picture.
Offline nevin
yeah, i got a bunch of crap wire as well. but i'm working on a hand wired keyboard and didn't want to get a bad section of crap/intermittent wire. i'll have enough fun tracking down other issues, i don't want that to be one of them.
how close are those 3 buttons on the base to your thumb? reachable?
Offline iso
1. Re-did the sensor case and the cover for it. Looks... weird but now there is lots more space to work the wires out. No hole for the LED, just for the DPI/Navigation buttons.  Holes through. M3/4-40 flathead machine screws will fit.
2. Re-did the cap for the sensor. Lower profile, minimalistic, will exert little bit of pressure on the teensy IC, is designed that way.
3. No branding (for now)
@nevin , not reachable. Is difficult to model/add those next to the scroll-wheel and unless I have more options/buttons I dont dont see myself putting the time for just 2 buttons, so that bit will have to wait.
Offline nevin
nice.
i'm all for function over form. doesn't look bad at all either. reminds me of some of the battery braces from back in my R/C racing days. do you need that much pressure that a bolt & nut is necessary, or would some plastic/wood screws from the top be enough to hold down the top brace? any way to squeeze a small hole in there to access the reset button?
buttons. oh, it's no problem. was just curious.
Offline iso
Top cover is pretty thin, very little pressure but the 4-40 screws will keep it from rattling, previous model had a "snap on" kind of mechanism, would be pretty stiff at the beginning then  will get loose after removing/adding it few times, i never liked it, always felt like I have to pry it open with certain care so I dont destroy it. With the screws looks/feels better built.
For an easy payment of $99.99/month or 1000/year you can have a tiny reset hole, limited offer, act now, this wont last !.
If you take on assembling this, chances are you have a drill bit to poke a hole on a 2mm piece of plastic :)
Offline nevin
lol. no problem. i know from other projects the community would make noise anytime the reset button was not easily accessible.
Offline nevin
Lots of digging/research into the firmware stuff....
Actually, after initially programmed, you can hold one of the mouse buttons when plugging in to invoke the bootloader, so really, no need to get to button on teensy after 1st flash.
Offline iso
I guess if the firmware gets ported into Arduino, all other options will be lots easier to implement, mainly because even beginners can throw some non-sense in there and upload the code and find what they actually want as extra button/functionality.
Unless someone else is faster than me and create the model, the extra buttons will have to wait.
Im done resizing the model for hand piece and finger cluster. I`ll print those tomorrow.
@nevin - does it bother you if plastics gonna be lime/gray mix ? I ran out of gray filament.
Offline nevin
Printed parts... COOL!
Colors... No, beggars can't be choosers....
Offline iso
@nevin
Lime green actually looks good with medium grey.
In reality the green is darker, not so shiny.
Offline praxis87
I'm going to have to stop printing my mouse pieces just in black.
Offline nevin
@iso - Looks fantastic! Thank You! Soooo excited! Sending pm in a min.
Offline iso
Dont you dare, you need to be known as the guy that prints black only, I`m the guy that prints on any other color  :))
Offline praxis87
@iso - Question about your experience with the magnetic quadrature.  I built the reed switch quadrature pack similar to your pictures and I made sure to orient the quadrature pack so that the rotation path of the magwheel would cross one reed switch at a time.  But, I'm getting inconsistent performance out of the wheel quadrature.  Do you have any issues with the reed switches being right next to each other?
Offline iso
@praxis87
Are you using a round magnet ? You only need 2 reeds.
Are you sure your magnet has radial polarization ? Imagine that on the GIF you have south/north as the white/black bar, the GIF has a better technical explanation of what is happening, sorry for my english.
Let say the magnets move from right to left, to synch with the GIF
1. North enters the trigger zone, reed a
2. North enters the trigger zone, reed b
 --This is how the electronics know you`re scrolling up or down, if triggers a first, goes up, if triggers b first, goes down.
3. South enters the trigger zone, reed a
--Here is telling direction, N N S > UP
4. North leaves the trigger zone, reed a
/LOOP/
If you`re using tiny flat magnets, those need to face the reed switches S N S N S N S N S N S N, you cannot randomly position those
You can have as little as 2 magnets per wheel and you`ll only scroll what is considered one line per revolution.
Takes very fine adjustments to find the sweet spot, half mm can be the area where the right sequence is happening, depending on the size of the magnet/reeds, the smaller the harder is to find it
To simplify this  process, add long wires to begin with for the reed switches.
Clamp down the scroll assembly, make sure the thumb wheel moves freely and you have access to the plastic bridge that faces the exposed magnets.
Open a tall webpage where you have to scroll alot or a very large text file.
Position the mouse cursor over it.
Center the scrollbar to the middle of the page/window.
Hold the reed assembly with one hand and get it close to the plastic bridge, with the other hand slowly start moving/rotating the scroll assembly/magnet.
Touch the plastic bridge over exposed magnet with the reed assembly, while the wheel assembly is rotating, move the reeds up/down the bridge, pay attention to the page/text file window
As you slowly move it back or forward you will notice that the page will start scrolling up/down.
After you find where will move in one direction, reverse thumb/magnet rotation. Move the magnet up/down the bridge till the page moves the other way.
Do this and you`ll find the spot where moving the wheel up/down, the page will scroll up/down. Sometimes is reversed, desolder the other 2 wires, not the ground, switch position.
Since the area where the right sequence is happening is so small, you`ll have trouble attaching the reeds to the bridge right where needs to be.
First, take a mental note on how far/close  is the reed asembly from the edge
Add a very tiny drop of superglue to the bridge, while moving the scroll with one hand, with the reeds on the other hand, get close enough to the bridge wthout touching the glue but close enough to find the spot again, then push down on superglue.
Most likely you will fail few times but you`ll get it, its important you dont use lots of superglue to begin with, after is glued in position you can add more.
Do not use hot glue unless you really know what you`re doing, reeds will demagnetise/damage at 180F
Reed switches need to be next to each other, yes
If you still have problems let me know, I can make a short video, or for $99.99/month you can join my club, named "I can superglue random stuff"  and I`ll teach you in person :))
Offline praxis87
I'd totally join that club.
Thanks for the writeup.  I'm using 8x round magnets arranged in a NSNSNSNS configuration.  I re-modeled the finger switch holder and a more traditional mouse wheel to carry the magnets.  I'll post pix in a couple of days.
Short version is it was working correctly while it was briefly in the sweet spot... Now that I know how small that sweet spot is, I just need to re-find it (and figure out if I destroyed the reed switches when I hot glued/heat shrunk them).
Offline nevin
Yes, all excellent info. Answered a couple questions i knew i would have. Thanks.
Offline nevin
Last of the parts should be here in a few days. Going to mock it up so i can play with firmware until the printed parts are ready. (again, no rush, seriously)
From what i've researched, there's at least 2 revisions to the firmware, newer than what we've been playing with. Also, looks like there will be a way to add keyboard codes to the firmware.
@praxis87 - There's also a user working on getting the code for the sensor into arduino (i remember you mentioning that's something you would like) Last i checked, he has the sensor & some buttons working, wheel code still needs added (going to use buxtronix's example).
That's all i have for now.
Offline praxis87
Scroll wheel is successfully implemented on my setup.
I completely re-modeled the switch holder in Fusion 360 and adjusted it for the wheel.  I wasn't sure I was going to like the split setup for the middle button/wheel, but so far I'm actually really happy with it.
Offline iso
Loking good @praxis87, thanks for the pictures
Glad you`ve got the reeds working
I couldn`t live with having to hold down the mid-button and scroll with the same finger.
I have in the works a lighter mouse-base and more support for the hand piece, uploading models soon, most lilely next Monday.
Offline nevin
@praxis87 - nice work, looks good
Offline iso
Updated:
1. Base - Only poked few holes, uses less plastic, little ligter, reduce printing time
2. Finger cluster has a straigt down support/ball joint instead of angled. Added larger finger separator, those are handy while lifting the mouse off the table.
3. Hand piece, added cable routing hole, extended finger support, removed some of the pinky support, now its easier to lift it off the table without clawing it too hard.
« Last Edit: Mon, 08 April 2019, 23:28:43 by iso »
Offline nevin
Speed Holes! NO WAY! it's got to be a fast mouse now.... lol
looks great iso.
Offline iso
Its all in the DPI :)
Thinking about making a 3d printed trackball too.
Same sensor, same teensy, different firmware, the axis need to be flipped because the sensor is gonna be almost upside-down, I ordered a stainless steel 50mm ball to test with and made a little imprint to get a better idea on how big is gonna be and overal hand position
@nevin, have you received the sensor for the mouse thats on its way to you ? If you could help with the firmware, flip axis, would be amazing but without a sensor to test with, gonna be lots of back and forth with me/others testing it
Its hard to see but there is a  hand imprint
« Last Edit: Wed, 10 April 2019, 12:35:11 by iso »
Offline nevin
yeah, all parts are here. the only questionable part is the bearing, which, hopefully i have one that fits (lots of R/C stuff). didn't want to order a box of that size for just one bearing.
the material of the ball may be an issue, we'll see. as far as trackballs go, the kensington expert mouse is fantastic (don't know that there's much to improve on)
some image captures from this sensor on various surfaces (from another thread)
SQUAL (=surface quality, higher is better)
Logitech G440 Mousepad
Anodized Aluminum (=Apple MacBook Retina 2013)
Fabric (a t-shirt)
A4 print paper
Printed character (by a laser printer) on A4 paper
Office desk (white)
Leather
Offline nevin
Re: MEM 3d printed modular ergonomic mouse, teensy 2.0 and pmw3360 sensor
« Reply #128 on: Wed, 10 April 2019, 14:36:44 »
the expert mouse is an optical trackball, and the ball itself looks like candy metallic paint form a car.
i have one of the older beige kensington orbit trackballs which is mechanical not optical.
the ball supports (what the ball sits on) are small plastic or glass balls like tiny clear ball bearings. i'll take a bunch of pics & send later.
« Last Edit: Wed, 10 April 2019, 14:44:56 by nevin »
Offline iso
« Reply #129 on: Thu, 11 April 2019, 10:09:28 »
@nevin You should have told me that you need a bearing, I would have left in there for you. I`ve got a trackball that I took apart, there is plenty that can be improved upon :)
Offline nevin
« Reply #130 on: Thu, 11 April 2019, 10:30:43 »
@iso - Bearing - It's fine. I should have some   .....somewhere.
Got the prints, looks fantastic! Thanks for the nameplate, nice touch. The larger of the two main skeletal pieces is perfect. Can't wait for the day to be over to start building!
THANK YOU!
What make/model trackball gave it's life to science?
« Last Edit: Thu, 11 April 2019, 10:40:14 by nevin »
Offline iso
« Reply #131 on: Thu, 11 April 2019, 11:34:58 »
You welcome.
I`ve got 2, both work, one is wireless, I dont remember the brand, thats aready being used on a keyboard, second, wired, I kept most important bits, Kensington Orbit.
Apparently the little bearings the large ball slides on are zirconia or ceramic.
If I ever get to build one of those I`ll probably use the tungsten version with a large ball that can be repositioned from thumb to fingertips position. We shall see.
Once assembled, add some first 24h usage impresions, more than anything Im curious about how long gonna take you to re-learn the thumb scroll position.
Weirdly enough, it appears  lefties have an easier time re-learning/adjusting, my right handed friends were like "I guess I can get used to it", lefties "Duhhh, this is the way now, cant go back"
Offline nevin
« Reply #132 on: Thu, 11 April 2019, 12:13:59 »
Lefties! i know. Totally agree. Only ones in their right mind...
Tackballs. I like the scroll ring the kensington expert mouse. The buttons on all trackballs need work.
Trackball modules would be interesting for this "modular" mouse. Either for 2 axis scrolling (thumb) or tracking (ball up at fingers with a switch or two to right of ball, left click would be thumb). I find index finger on ball is more adept than thumb for fine control/accuracy.
Offline nevin
« Reply #133 on: Mon, 15 April 2019, 12:34:09 »
Finally got a working mouse together this weekend. Initial impressions are fantastic!, so many possibilities.
Because of the ergonomic gripping position (more vertical, so wrist side to side motion is now up & down), i'm going to move the sensor to the front (at least for now) to get a closer reaction of the sensor to the hand/arm movement that i'm used to with a normal mouse. Plus this will give me the most sensor movement from minimal physical movement (horizontally). This will require rotating the orientation of the sensor and rewiring it 180 deg. from it's current position (so usb connector is over the front of sensor instead of the back of the sensor). This is needed as the usb port would be facing the ball on the base. A way to avoid rewiring the sensor 180 would be to hardwire a usb cable to the teensy (not using the usb connector). Another benefit of rotating & moving the sensor to the front, the side buttons on the sensor pod are now reachable with your pinky.
Going to make some adjustments to the firmware as well:
- Increase cpi to get closer to what my current mouse is (aprox 4k).
- As well as hopefully being able to include keyboard commands & possibly support for a couple more switches. (all versions of firmware out there are up to 5 button)
Offline iso
« Reply #134 on: Mon, 15 April 2019, 12:56:16 »
Sounds awesome, please post pictures with your mods and the new HID :)
Offline iso
« Reply #135 on: Tue, 23 April 2019, 11:52:49 »
Live streaming now for the next 4hr - https://www.twitch.tv/2_am
Offline sJ1N
« Reply #136 on: Tue, 23 April 2019, 12:04:28 »
very cool ! sorry if it's been asked before but is the pcb footprint big enough to fit a g305 pcb in order to make a wireless version ? just a thought that came to my mind
Offline praxis87
« Reply #137 on: Tue, 23 April 2019, 12:23:44 »
The current electronics mount is the size of a Teensy 2 (the base will just cover my MX Master though).  You could certainly modify the base and sensor container to carry a different PCB...  you might have to "destructively rearrange" the PCB to make it fit though.  You're definitely going to have to de-solder switches and the mouse wheel also.  It looks like there is a model for a G305 board carrier on Thingiverse that might be a good starting point.  https://www.thingiverse.com/thing:3531075
« Last Edit: Tue, 23 April 2019, 13:25:57 by praxis87 »
Offline iso
« Reply #138 on: Wed, 24 April 2019, 20:25:40 »
MEM Compact.
Since I dont have the need to adjust the mouse anymore, found the perfect angles I decided to measure the distance between each bit and fuse the model to make it ocmpact.
I cut toothpicks on various height sizes and place them under the different elements, like pilars, hand piece, 3 locations, finger cluster, 2 locations, magnet flywheel, 3 locations, etc.
Took sharpies various colors and painted the toothpicks, took pictures with toothpicks in place.
Took those out and measured them one by one, went back to 3ds max and adjusted the height/angle/position as measured, then fused the model to get the compact version, I streamed the whole modelling session on Twitch.
The only thing thats still adjustable is the sensor case, can be rotated. Uses same sensor case model, same everything. Enjoy.
Offline nevin
« Reply #139 on: Fri, 26 April 2019, 21:20:31 »
Still amazed.
Hopefully I'll have some time this weekend to work on mine more. ...hopefully... fingers crossed.
Offline iso
« Reply #140 on: Thu, 09 May 2019, 19:52:31 »
@praxis87 On one of the setups, I`ve got the same problem you had with mouse cursor jumping on the corner, how you solved the problem ? No matter which firmware I use, does the same.
Update:
1. Extended left support.
2. Extended center support.
3. Centered the sensor hole.
Since the hand position is not adjustable anymore/got fixed height, I decided to extend the supports, now feels like you`re wearing the device :))
Sensor rotation is still adjustable but its position is now centered, feels little better when its closer to the wrist, at least for me, plus, for whoever wants to add board/electronics from a different device but the sensor is centered, this will make it easier.
Enjoy
Offline praxis87
« Reply #141 on: Thu, 09 May 2019, 22:35:11 »
I ended up re-soldering all of the wires between the 3360 and the Teensy between having the problem and trying the new firmware that worked - so I don't have 100% confidence which actually originally fixed the issue for me.  I have used both of the firmwares in posts #60 and #63 successfully.  Maybe check that your wiring is correct (and not broken)?
Offline iso
« Reply #142 on: Sat, 11 May 2019, 15:10:57 »
No matter what I tried and I tried everything, I cant makle it work, so I ordered 2 new sensors  :thumb:
Offline nevin
« Reply #143 on: Sat, 11 May 2019, 15:52:31 »
sounds stupid but make sure the lens is fixed. either melt the posts that stick up through or glue it or something (the lens is not fixed in place when you order it, it can be easily removed). make sure there is no dirt/hair etc. in the way. had many issues like this with a laser mouse (those are even more sensitive to dirt & debris)
Offline iso
« Reply #144 on: Sat, 11 May 2019, 18:01:49 »
The lenses were hot-glued in place 30 sec after unpacking :)) those are easy to misplace.
I was replacing the wires to fit inside the 3d printed sensor case, prepping for the trackball, after re-soldering the damage was done, whatever happened, dont know
Never took the lens off and it was workign 20 min before that. Gotta wait now for the replacements
Offline iso
« Reply #145 on: Thu, 13 June 2019, 18:34:19 »
Update:
Updated the design for compact ergonomic mouse - C-EM
Changed branding for the sensor cap
Removed the back-forward (DPI) buttons from the sensor case, made the whole assembly smaller.
Added the DPI buttons next to the left mouse button.
Re-did the bearing case, I didnt like the fact that I have to screw in the magnet flywheel to the bearings and the thumb scroll piece, now I got a 3 inch stainless steel shaft that is very snug and nothing needs to be screwed it.
In preparation for when I can add extra buttons, I created the space for additional buttons for the thumb.
Reed switches/rotary encoder hole is part of the thumb assembly, makes it easier to position/glue.
Re-designed thumb piece
Re-designed flywheel
221035-0
Offline iso
« Reply #146 on: Sun, 23 June 2019, 04:42:21 »
@nevin  - Any news on the firmware update that`s supposed to have extra buttons/functionality ?
Offline nevin
« Reply #147 on: Tue, 25 June 2019, 10:09:12 »
Apologies for the delay, should have an update in the next day or two.
Offline praxis87
« Reply #148 on: Fri, 19 July 2019, 13:54:08 »
Sorry I've been out of the picture...  Had a rough couple of months due to an injury and unexpected hand surgery.
I'm putting out my current draft of parts in case anyone is interested.  I have NOT been able to print and test fit most of this - so print at your own risk.  The only parts that I know for sure work are the finger cluster / scroll wheel / original base / ball head coming off the base.  The thumb buttons, stalk, and accessory ball mounts were what I was working on getting to fit when I got hurt and are not done and the slot in the hand piece was (messily) modified to accommodate the dual-bolt design of the new stalk I was working on.
« Last Edit: Fri, 19 July 2019, 14:01:58 by praxis87 »
Offline iso
« Reply #149 on: Sat, 20 July 2019, 18:54:49 »
Welcome back, speedy recovery @   praxis87
« Last Edit: Sat, 20 July 2019, 19:01:27 by iso »
