Author Topic: programming plum/niz keyboard  (Read 2709 times)
Offline fatum
« on: Mon, 17 December 2018, 06:59:26 »
Hi guys.
I'm trying to add macroses to my keyboard and, surprisingly, can' succeed.
I want to run operations "End" + ";" to add ";" in the end of line when I press Ctrl+;
So, what I do:
  • Switcher is set to LevelUp because I don't want to press FN
  • Select Ctrl
  • Add Combo for Activation by recording it: Ctrl + ;
  • Add Macros by recording it
But it doesn't work: as soon as i press Ctrl it adds ";" to the end of string not waiting for a combination to be pressed.
What I don't understand: I can record a few combos for activation and a few macroses to be run (for example if I want a similar behavior for Ctrl+","  , but there is no way to map them between each other.
Can anyone help me?
