Author Topic: Which G86 SPOS are cherry browns?  (Read 3417 times)
Offline ZeNmAc
« on: Mon, 10 May 2010, 00:40:02 »
I thought all the G86-62410EUAGSA had browns, but this one makes no mention of either mx spos or "g80" on the back sticker
Instead of
Do you think the top one has cherry browns?  It is the same model number, but the different sticker worries me as well as the current rating.  The mx spos is rated at 200mA (I've seen other ones that said 100mA), but the one I mentioned is 36mA which is about what the other rubber dome ones are.  Do you think the top pic has browns?
Offline InSanCen
« Reply #1 on: Mon, 10 May 2010, 01:40:47 »
Unlikely.
But, this is Cherry's model number scheme here, which are... fun... to decipher at times, and not always what you think.
If they are cheap enough, buy 'em and find out.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline elbowglue
« Reply #2 on: Mon, 10 May 2010, 02:31:02 »
Here you go:
http://geekhack.org/showthread.php?t=8836&highlight=omg+fake
Post #11 is the one where the facts are listed.
Here's how I figure it out:  If the seller is using a stock photo (like dell did) you have no idea what it will end up being.  If there is an actual photo, look for nubs on the F and J keys.   Nubs indicate rubber dome board.  For what it's worth, the MX version is a lot rarer imho, and there is no good source for this one didjamatic sold out of his.
Welcome to geekhack by the way!
Oh yeah the top pic is a rubber dome.
« Last Edit: Mon, 10 May 2010, 02:35:05 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline itlnstln
« Reply #3 on: Mon, 10 May 2010, 07:31:20 »
The top sticker is a rubber dome model, the bottom is the MX brown version.  See if you can figure out how to tell.  There is something on the MX version that is a dead giveaway.
Offline Nonmouse
« Reply #4 on: Mon, 10 May 2010, 08:07:31 »
Quote from: itlnstln;180661
At least three things, really...
Offline ZeNmAc
« Reply #5 on: Mon, 10 May 2010, 14:40:45 »
Quote from: elbowglue;180608
Here you go:
Ok, thanks.  Strange that they use the same model number though.
LOL the second pic is obvious, it's the first one I was asking about.
Offline itlnstln
« Reply #6 on: Mon, 10 May 2010, 15:13:22 »
The "article number" is the key.  I believe "G86" refers to custom/special layouts (whothe****knows).  The article number tells the "real" story.
Offline Nonmouse
« Reply #7 on: Fri, 14 May 2010, 10:32:53 »
Quote from: itlnstln;180792
Plus the "Model no. MX SPOS".
Offline itlnstln
« Reply #8 on: Fri, 14 May 2010, 11:14:02 »
Yeah, that would be a little more obvious.
