Author Topic: Keyboard not recognized in OSX?  (Read 3956 times)
Offline erricrice
« on: Mon, 10 May 2010, 08:10:25 »
So I'm trying to connect a G81-7000 to an iMac through a PS/2 to USB adapter and it won't recognize the keyboard.  It shows the popup window where it asks me to press the key to the right of the shift and all that but never gets past that screen.  Any ideas?
Adapter works fine with XP with this keyboard.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline erricrice
« Reply #1 on: Mon, 10 May 2010, 10:05:47 »
Also works just fine on a Vista laptop so it's not something to do with power....
Logitech G5[/FONT]
Offline kriminal
« Reply #2 on: Mon, 10 May 2010, 10:10:21 »
not familiar with imac's, im guessing they dont have ps-2 ports?
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline erricrice
« Reply #3 on: Mon, 10 May 2010, 10:16:11 »
nope, of course not, that would make things soooo much easier....
Logitech G5[/FONT]
Offline DrunkenDonut
« Reply #4 on: Mon, 10 May 2010, 12:07:11 »
It doesn't respond in the setup screen? You can simply close the window if you want too. It's just an easy way for the OS to detect what kind of layout you have.
Does the keyboard work at all? For example, just open textedit or any text app and start typing. Does the PS/2-USB adapter work for other keyboards on the iMac?
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #5 on: Mon, 10 May 2010, 12:38:42 »
I'm getting ready to spam all these threads with "USB TO PS/2" in giant red text...
When adapting a computer BUS to something else, it is the BUS name that goes first.
kishy.ca
Offline erricrice
« Reply #6 on: Mon, 10 May 2010, 12:38:48 »
No, it's not responding at all, I think the adapter just doesn't like OSX.  I don't have any other keyboards at work here to try it with any others.  Funny cause the advertisement specifically said works with osx....geh
Logitech G5[/FONT]
Offline erricrice
« Reply #7 on: Mon, 10 May 2010, 12:40:09 »
Quote from: kishy;180738
It just depends on which direction you are looking at the flow...
Logitech G5[/FONT]
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #8 on: Mon, 10 May 2010, 12:48:45 »
Quote from: erricrice;180742
Is an AGP video card a VGA to AGP? I think not.
kishy.ca
Offline erricrice
« Reply #9 on: Mon, 10 May 2010, 12:50:42 »
Quote from: kishy;180748
But neither is it AGP to VGA.
I don't understand what you're trying to say.
Logitech G5[/FONT]
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #10 on: Mon, 10 May 2010, 13:02:12 »
Quote from: erricrice;180749
Yes, it is an AGP to VGA card.
All expansion cards adapt the bus they connect to (be it ISA, PCI, AGP, PCIe, whatever) to the function of the card. USB is one such bus. When adapting a bus to another purpose, the function of the device doing the adapting is turning the bus into the other function...not the other way around.
kishy.ca
Offline erricrice
« Reply #11 on: Mon, 10 May 2010, 13:14:30 »
Quote from: kishy;180756
Ok that makes sense, I've just never looked into it.
What of the adapters that everyone calls USB to PS/2 (usb being the female, PS2 being the male)   is that just a misnomer as well?
Logitech G5[/FONT]
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #12 on: Mon, 10 May 2010, 13:15:03 »
And that's how we ended up here lol.
It's the same thing, unfortunately...
My arguments are useless because despite making a valid point, if we actually used that terminology, we'd confuse everyone to death.
kishy.ca
Offline Viett
« Reply #13 on: Mon, 10 May 2010, 13:28:24 »
It does not recognize the keyboard on boot? I have an eMac and also have this problem with adapters. It has to be a power issue, because a regular USB keyboard works fine.
Last time I checked, an adapted PS/2 keyboard is indistinguishable from a USB one other than the amount of power used.
Once you're booted up, the adapted keyboard should work fine.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #14 on: Mon, 10 May 2010, 13:38:29 »
Quote from: ripster;180768
How about if we just call it a dongle?  I still say USB to PS/2 cause that's the way the signal goes.
Lego don't have  dongles.  Sad.
Quoting in agreeance.
kishy.ca
Offline erricrice
« Reply #15 on: Mon, 10 May 2010, 13:55:36 »
Quote from: kishy;180761
Lol absolutely....I hate how the world is dictated by the stupid ones, and the smart ones always suffer only because there are less of them....
Logitech G5[/FONT]
Offline erricrice
« Reply #16 on: Mon, 10 May 2010, 14:12:59 »
Quote from: Viett;180766
I'm gonna go ahead and call myself a retard on this one so you guys don't have to.
Restarted with it connected and it works just fine.
Thanks man
Logitech G5[/FONT]
