Author Topic: [GB] SPACE65 (100% shipped, Completed)  (Read 307965 times)
Offline linkian209
Re: [GB] SPACE65 | 65% Custom Keyboard
« Reply #100 on: Fri, 04 January 2019, 10:51:17 »
My first group buy using geekhack. Do people recommend buying a second PCB?
Offline beekey
« Reply #101 on: Fri, 04 January 2019, 10:54:45 »
I would always do it for custom PCBs. Otherwise you might and with just a case. Accidents happen. Also resale is easier as people might want a untouched PCB.
Offline oldcat
  • 65% is Life
« Reply #102 on: Fri, 04 January 2019, 11:33:43 »
I'd always do it, get a second plate too, so you can build two basically (e.g., 1 linear board and 1 tactile board). I am going for CF default for holy pandas and brass for a good linear (tealios or tangerines).
Offline maximize
« Reply #103 on: Fri, 04 January 2019, 14:43:13 »
Will the badges say "Voyager 1" or "SPACE65"? Seems that the newest prototypes all say "Voyager 1", but if you could confirm, I'd appreciate it!
Offline oldcat
  • 65% is Life
« Reply #104 on: Fri, 04 January 2019, 18:26:39 »
Discussion in discord shows it has changed to “voyager 1”
Offline ConfuseBill
« Reply #105 on: Sat, 05 January 2019, 06:24:38 »
So, this is the latest render for the plate, meaning the bottom part, not only supported by 3 screws, but also the plate get sandwich between the aluminum top & Bottom cover.
This looks better than previous render as attached.
One more question, how big is the gap between the lowest part of PCB bottom with the highest part of Bottom Alum cover.
Thanks.
Offline oldcat
  • 65% is Life
« Reply #106 on: Sat, 05 January 2019, 10:31:23 »
Thanks.
Potter said clearance is 0.8mm between switch pin head and alu bottom covef
Offline ConfuseBill
« Reply #107 on: Sat, 05 January 2019, 20:21:11 »
Thanks.
Great, it is a tight gap, so in case the plate got Flimsy. Can just add something underneath to fill the gap. Thanks @oldcat.
Offline oldcat
  • 65% is Life
« Reply #108 on: Sat, 05 January 2019, 23:10:31 »
Thanks.
NP, hope this helps. I haven’t used mill-max myself (not a big hotswap person), may try at some point :)
Offline AIRPOTTER
  • Owner of Gray Studio
« Reply #109 on: Sun, 06 January 2019, 04:59:32 »
Yes... indeed, now it's Voyager 1.
I cancelled the sign next to the side LED,and moved it to the nameplate. :)
Offline beekey
« Reply #110 on: Sun, 06 January 2019, 12:37:00 »
All nameplates will be engraved? Any chance to get them without it? I like the clean look from the prototypes.
Offline famguy07
« Reply #111 on: Sun, 06 January 2019, 22:11:20 »
I am in the group buy under Reddit name famguy07. I would like to add a brass badge to my order. I have a message to you on Reddit saying the same thing. I don't want to pay the invoice until I get this sorted out.
Offline AIRPOTTER
« Reply #112 on: Mon, 07 January 2019, 03:17:39 »
Sorry, I'm late.
Invoice has been updated for you. :)
Thank you for choosing SPACE65.
Offline mkarlsson
« Reply #113 on: Mon, 07 January 2019, 05:08:07 »
Invoiced and paid.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #114 on: Mon, 07 January 2019, 05:52:18 »
Sorry, I'm late.
Need to update my order. Send you a pm on discord :)!
Offline oldcat
  • 65% is Life
« Reply #115 on: Mon, 07 January 2019, 19:49:11 »
Hey, get in discord and send a PM to Potter!
Offline koduh
« Reply #116 on: Mon, 07 January 2019, 22:21:49 »
All paid up, looks like I am going to Space!
Offline happycamper87
« Reply #117 on: Tue, 08 January 2019, 05:41:45 »
Invoiced and paid! Now the waiting game begins...
Offline vewy_nice
« Reply #118 on: Tue, 08 January 2019, 05:49:23 »
Are invoices rolling out over time? I still haven't gotten one.
I REALLY don't want to miss out on this! So I just want to make doubly sure I get my invoice ;)
PLEASE take my money!
« Reply #119 on: Tue, 08 January 2019, 09:56:30 »
Took a bit over a week to get mine if that makes you feel any better. :D
Offline oldcat
  • 65% is Life
« Reply #120 on: Tue, 08 January 2019, 23:17:37 »
Potter is sending out invoices everyday!
Offline beekey
« Reply #121 on: Wed, 09 January 2019, 00:15:41 »
Can one upgrade to brass plate? W/o getting a carbon fiber one also?
Can one upgrade to a brass badge? (W/o getting the included aluminum one also?)
Asking to keep price down since I wouldn't want carbon fiber or aluminum badge.
(Also asked on Reddit)
Second these questions.
Anybody knows this?
Offline AIRPOTTER
« Reply #122 on: Wed, 09 January 2019, 02:40:28 »
Anybody knows this?
Sorry, my network has been out of order these days.
Brass parts can only be purchased extra. Doesn't appear as an upgrade.
Sorry again.
Offline AIRPOTTER
« Reply #123 on: Wed, 09 January 2019, 02:43:21 »
Sorry, my friends.
As a novice, I can only issue about 20 invoices a day (only more than 10 invoices a few days ago), so that you have been waiting for a long time, I'm really sorry.
Offline AIRPOTTER
« Reply #124 on: Wed, 09 January 2019, 02:46:48 »
Thks much.Please enjoy SPACE65!
Offline F2F4
« Reply #125 on: Wed, 09 January 2019, 05:29:09 »
What is the badge color option?
Offline FSund
« Reply #126 on: Wed, 09 January 2019, 06:00:03 »
Anybody knows this?
Sorry again.
Don't worry my dude, it's fine. I fully understand the extra bookkeeping needed to do upgrades like these.
I ordered 2 red/red boards today. One for me, and one for a friend. Can't wait!
I'm thinking GMK Jamón might go well with the red case.
Join the Mechanical Keyboards Norway Discord server
Offline click clack jack
« Reply #127 on: Wed, 09 January 2019, 18:34:42 »
I've joined! So excited! I went grey and planning on DSA Milkshakes!
Now to decide switches 🤔🤔
Offline ConfuseBill
« Reply #128 on: Wed, 09 January 2019, 19:02:56 »
@airpotter can i suggest one more design alteration. The bottom rubber feet. Since this is custom, and we're gonna open and close this baby a lot. Is it possible that the rubber feet has it's own seat, rather than covering the screw holes. Believe the rubber feet will loose it's sticky/ glue if we open it alot.
 Thank you.
Offline Jaxxstatic
  • Haptic Recon
« Reply #129 on: Wed, 09 January 2019, 22:14:24 »
 Thank you.
This. Yes. The rubber feet should not cover the screw holes, please.
Invoice paid, btw.
Offline oldcat
  • 65% is Life
« Reply #130 on: Thu, 10 January 2019, 00:04:54 »
DSA+ holy panda will sound real nice
« Reply #131 on: Thu, 10 January 2019, 00:08:15 »
Thanks for the suggestion my friend. I missed the massdrop GB, any place I can find those?
Offline cijanzen
« Reply #132 on: Thu, 10 January 2019, 10:50:55 »
Please correct me if I'm wrong but I think I spotted an error in the hydrogen atom icon. Isn't the right side of the icon supposed to show the electron spinning in the opposition direction? As it is currently, the icon shows only one state instead of two states like the Voyager record cover.
Offline Mystogan
« Reply #133 on: Thu, 10 January 2019, 13:26:59 »
Nice catch! Yes, it's suppose to be like this:
Instead of what we have here:
Hopefully the engraving can still be rectified.
Offline Hedgey
« Reply #134 on: Thu, 10 January 2019, 15:40:59 »
Got my invoice last night and paid immediately.  Can't wait!!
"Resellers don't kill the community, auctioneers kill the community. Look at what happened to Diablo 3"
Offline Darknight00z
« Reply #135 on: Thu, 10 January 2019, 16:02:18 »
 Thank you.
Invoice paid, btw.
Can't believe this got overlooked during IC, I know its less pretty to show the screws, but for our tinkering sake, please move the rubber feet locations.
Offline oldcat
  • 65% is Life
« Reply #136 on: Thu, 10 January 2019, 19:24:12 »
for those of you who would like to see how it looks with GMK caps:
210333-0
210335-1
Offline ConfuseBill
« Reply #137 on: Thu, 10 January 2019, 23:51:36 »
Finally, decided to join with Red/Red/Black. Just need to wait for my Invoice.
Offline cary
  • Designer of DOLCH.CR
« Reply #138 on: Fri, 11 January 2019, 01:50:48 »
牛逼,支持!建议送我一把! ;)
Offline AIRPOTTER
« Reply #139 on: Fri, 11 January 2019, 03:14:57 »
God, I made a mistake here. Thank you very much for your carefulness. I will correct this point in the final mass production version. Again, I apologize for my carelessness. Thank you for your kind correction.
« Last Edit: Fri, 11 January 2019, 03:38:01 by AIRPOTTER »
Offline AIRPOTTER
« Reply #140 on: Fri, 11 January 2019, 03:29:29 »
 Thank you.
Invoice paid, btw.
Well, in order to ensure the aesthetic appearance of the bottom case.
I specially covered the screw holes with footpads.
At the same time, the screw hole is just at the edge of the rubber feet.
I've tested it before, so it doesn't affect the removal of the screw.
Because it's easy to twist the screw if you just move the rubber foot a little bit.
Offline AIRPOTTER
« Reply #141 on: Fri, 11 January 2019, 03:33:29 »
牛逼,支持!建议送我一把! ;)
啊哈哈哈哈,C神好,多谢大佬支持啦! :D
« Last Edit: Fri, 11 January 2019, 03:38:30 by AIRPOTTER »
Offline AIRPOTTER
« Reply #142 on: Fri, 11 January 2019, 03:39:34 »
I'm sorry that the invoices I can issue every day are very limited. But I will deal with these things as soon as possible.
Offline AIRPOTTER
« Reply #143 on: Fri, 11 January 2019, 03:43:22 »
Sorry,sir.I don't quite understand what you mean. Do you mean  there is no logo nameplate?
Offline AIRPOTTER
« Reply #144 on: Fri, 11 January 2019, 03:45:08 »
Anybody knows this?
Sorry again.
My God, I can't see this reply until now.,after discord chat😂
Offline AIRPOTTER
« Reply #145 on: Fri, 11 January 2019, 03:46:45 »
Guys,thank you very much for your support!
Offline AIRPOTTER
« Reply #146 on: Fri, 11 January 2019, 03:47:36 »
Black,gray,silver,red,and dark blue😁
Offline ConfuseBill
« Reply #147 on: Fri, 11 January 2019, 05:11:40 »
Ok, no problem. I'll wait. Thanks.
Offline oldcat
  • 65% is Life
Re: [GB] SPACE65 | 65% Custom Keyboard(last 3 days)
« Reply #148 on: Fri, 11 January 2019, 09:59:27 »
Here are some images of the Space65 with MT3:
210371-0
210373-1
Offline ccmpbll
« Reply #149 on: Fri, 11 January 2019, 10:00:42 »
I'm in! Grey on Grey with silver badge. Extra pcb, brass plate and brass badge. Can't wait! This is a great deal on a custom board!
