Author Topic: [GB] SPACE65 (100% shipped, Completed)  (Read 305024 times)
Offline maximize
Re: [GB] SPACE65 | 65% Custom Keyboard(last 3 days)
« Reply #150 on: Fri, 11 January 2019, 10:05:57 »
Here are some images of the Space65 with MT3:
Would you be willing to post a picture where we can see the side profile of the /dev/tty caps with the board?
Offline oldcat
  • 65% is Life
« Reply #151 on: Fri, 11 January 2019, 13:30:16 »
Hi,
Is this a Top Cover mount PCB Plate? Is it enough screw holes on the Plate?
Cause from what i see, the screw holes are only located on the left, right and bottom of the Plate.
Will the number row have enough support, since there is no screws to hold on to.
I love to join, but need to know if the keyboard will hold strong, without flimsy feel when bottom out.
Thanks.
It is top mount yes, And the revised plate has holes in the middle as well. Actually even with the middle screws it is very firm, not flimsy at all. But I will take a picture of the new plate soon (or Potter may be able to share soon).
Offline factoryofidols
« Reply #152 on: Fri, 11 January 2019, 17:44:45 »
Finally decided on color and got a gray on gray with blue badge, extra brass badge, brass plate and extra PCB. My first group buy outside of massdrop so I'm pretty excited!
Offline ConfuseBill
« Reply #153 on: Fri, 11 January 2019, 19:38:58 »
Hi,
Thanks.
Yes, good to hear for revision. Look forward for the new plate design. Thks.
Offline oldcat
  • 65% is Life
« Reply #154 on: Fri, 11 January 2019, 20:36:26 »
Hi,
Thanks.
Here you go, thanks bro.
210394-0
Offline pixelpusher
Re: [GB] SPACE65 | 65% Custom Keyboard(last 2 days)
« Reply #155 on: Sat, 12 January 2019, 01:29:44 »
Is there any way we can see what percentage of people have ordered each color?  Just curious.
Offline PhreshPrinceOfChinaTown
  • /u/PPoCT on Reddit.
    • MechWiki
« Reply #156 on: Sat, 12 January 2019, 04:03:52 »
312 Total Units!
Black (115 Units) - 37%
Blue (57 Units) - 18%
Gray   (55 Units) - 18%
Silver (32 Units) - 10%
Red (12 Units) - 4%
Other (41 Units) - 13%
Other accounts for all the mismatched Tops and Bases.
Here is some more detail on Badge and case colour combos:
Other accounts for mismatches again.
Other - 41
Black Top, Black Base, Red Badge - 32
Black Top, Black Base, Silver Badge - 32
Blue Top, Blue Base, Silver Badge - 25
Blue Top, Blue Base, Gray Badge - 22
Black Top, Black Base, Black Badge - 21
Black Top, Black Base, Gray Badge - 21
Gray Top, Gray Base, Blue Badge   - 19
Gray Top, Gray Base, Silver Badge - 17
Silver Top, Silver Base, Black Badge - 10
Black Top, Black Base, Blue Badge - 9
Red Top, Red Base, Black Badge - 9
Gray Top, Gray Base, Red Badge - 8
Gray Top, Gray Base, Black Badge - 7
Silver Top, Silver Base, Gray Badge - 7
Blue Top, Blue Base, Black Badge - 5
Silver Top, Silver Base, Blue Badge - 5
Silver Top, Silver Base, Red Badge - 5
Silver Top, Silver Base, Silver Badge - 4
Blue Top, Blue Base, Red Badge - 3
Gray Top, Gray Base, Gray Badge - 3
Blue Top, Blue Base, Blue Badge - 2
Silver Top, Silver Base, Nothing? - 1
Gray Top, Gray Base, Nothing? - 1
Red Top, Red Base, Blue Badge - 1
Red Top, Red Base, Silver Badge - 1
Red Top, Red Base, Gray Badge - 1
Data from around (9:30pm GMT+10) I'll adjust data at form close
« Last Edit: Wed, 16 January 2019, 06:53:02 by Phresh Prince of ChinaTow »
M65-A | Canoe | EM7 | X3 Renova | JER Mini | LZ CLS ms | No. 1/65 | TGR 910ce | CA66 | EXENT | E6.5 | Volcano 660 | Zephyr | Space 65 | Koyu | TX65 | Think 6.5 | Dolphin Linger | EXT65 | S7 Elephant | Key 65 | Alice | Singa | Aegis | HB85 |
Offline oldcat
  • 65% is Life
« Reply #157 on: Sat, 12 January 2019, 09:56:02 »
Black (84 Units) - 39%
Dark Blue (53 Units) - 24%
Gray (44 Units) - 20%
Red (8 Units) - 4%
Silver (28 Units) - 13%
Red is not getting so much love! Guess not many are planning for Jamon?
Offline Darknight00z
« Reply #158 on: Sat, 12 January 2019, 13:38:01 »
Red (8 Units) - 4%
I think Jamon looks better on black :P
Offline oldcat
  • 65% is Life
« Reply #159 on: Sat, 12 January 2019, 18:01:29 »
Red (8 Units) - 4%
Black -red is a classic combo :)
Offline Jaxxstatic
  • Haptic Recon
« Reply #160 on: Sat, 12 January 2019, 18:05:33 »
Here’s my plan/order:
Black top
Red bottom
Silver badge
GMK Jamon (would do GMK Burgundy if I had more than just the Hangul alphas)
Offline oldcat
  • 65% is Life
« Reply #161 on: Sat, 12 January 2019, 20:50:39 »
I was able to weigh a prototype built with everything default (cf plate, Alu badge):
It’s 1309 grams (in reference, Whitefox is ~800grams)
210441-0
Offline Poblopuablo
« Reply #162 on: Sat, 12 January 2019, 22:26:24 »
@AIRPOTTER
I sent a message on Reddit. :) Please respond. :)
Offline Poblopuablo
« Reply #163 on: Sat, 12 January 2019, 22:31:05 »
That's actually quite light. (I take it thats with the carbon fiber plate tho?) I imagine a brass plate/badge will increase it a smidge. :)
Offline oldcat
  • 65% is Life
« Reply #164 on: Sat, 12 January 2019, 22:33:40 »
It actually doesn’t feel light, probably similar as a Canoe.
I have a few Alf boards those were super heavy haha.
Yes adding brass plate and possibly brass badge will increase weight a lot. Carbon fiber is lightest material on keyboard  even lighter than PC I think
Offline OmegaZero55
« Reply #165 on: Sat, 12 January 2019, 22:35:28 »
Just got my invoice, awesome! The only thing is I requested an extra PCB and not the brass badge. Can you fix invoice 0126? Thanks!
Offline oldcat
  • 65% is Life
« Reply #166 on: Sat, 12 January 2019, 22:46:15 »
Reference with massdrop laser alt
210467-0
210470-1
« Last Edit: Sat, 12 January 2019, 22:52:06 by oldcat »
Offline oldcat
  • 65% is Life
« Reply #167 on: Sat, 12 January 2019, 22:52:44 »
Send airporter a pm or a dm in discord is eaiser
Offline AIRPOTTER
  • Owner of Gray Studio
« Reply #168 on: Sun, 13 January 2019, 03:10:29 »
I just updated the invoice to you. Sorry for the mistake.
Offline AIRPOTTER
« Reply #169 on: Sun, 13 January 2019, 03:13:05 »
@AIRPOTTER
I didn't see this message (there was no official prompt).
 Can you send me a PM in GH or Discord?
Offline FSund
« Reply #170 on: Sun, 13 January 2019, 06:28:40 »
Red (8 Units) - 4%
Honestly, after seeing this image, I think my red case will go well with pretty much anything.
You can say I'm pretty hyped for SPACE65!
From Zambumon's recent post on reddit.
Join the Mechanical Keyboards Norway Discord server
Offline konart
« Reply #171 on: Sun, 13 January 2019, 07:25:10 »
Somehow I've missed the IC and notice the GC only by accident D:
Joined.
Offline oldcat
  • 65% is Life
« Reply #172 on: Sun, 13 January 2019, 13:04:34 »
Red (8 Units) - 4%
I love red/black/gold combo
Maybe that’s why GMK Red Samurai is my all time favorite set (so far)
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #173 on: Sun, 13 January 2019, 13:41:00 »
I went silver on silver with blue and brass badge, but I still don't know if black looks better than silver...
I have some enjoyPBT Hiragana Sushi to put on the silver, but none would match the black case...
Should I change for black ?...
Aaaaa
French keyboard streamer
Offline Poblopuablo
« Reply #174 on: Sun, 13 January 2019, 15:01:43 »
for those of you who would like to see how it looks with GMK caps:
It looks as if your flipped spacebar might hit the bezel, does it?
Offline oldcat
  • 65% is Life
« Reply #175 on: Sun, 13 January 2019, 15:27:02 »
Flipped for fun :) either way it won’t hit the bezel :)
Offline Zyrophr
    • zyrophr.com
« Reply #176 on: Sun, 13 January 2019, 16:04:35 »
is there a way to have few more pics of the silver with different keycaps set? owo
Offline oldcat
  • 65% is Life
« Reply #177 on: Sun, 13 January 2019, 16:07:48 »
I think there is a pic of silver with mt3 dev/tty
210510-0
Offline Zyrophr
    • zyrophr.com
« Reply #178 on: Sun, 13 January 2019, 16:10:52 »
damn it looks well. Thanks!
Definitively going for silver then, even tho if I had money I would have bought a black one too because it looks sooo nice imo
Offline ConfuseBill
« Reply #179 on: Sun, 13 January 2019, 19:07:16 »
Hi,
Thanks.
Looks very good on the bottom plate design, there is more area to support and contact with top cover.
However, for the left and right sides, can the design be alter to be similar to the bottom, or at least having wider area surrounding the screw hole, to assure more support and contact area with the top cover.
Thank you
Offline oldcat
  • 65% is Life
« Reply #180 on: Sun, 13 January 2019, 19:15:17 »
Hi,
Thanks.
Thank you
Should be pretty easy to implement I think? Let’s talk to Potter in discord about this potential improvement
Offline cijanzen
« Reply #181 on: Sun, 13 January 2019, 20:21:09 »
Hi,
Thanks.
Thank you
Personally I think the less support the better for some extra flex but that’s just my opinion.
Offline mrpetrov
« Reply #182 on: Sun, 13 January 2019, 23:43:06 »
In, can't wait.
Offline oldcat
  • 65% is Life
« Reply #183 on: Mon, 14 January 2019, 02:01:42 »
Let’s be vigilant against potential scammers impersonating Potter. If anything, Graystudio will not dm you in discord and ask you to send money to a PayPal account. He will send an invoice. If you are unsure feel free to dm him before paying.
Here is a screenshot, I hope it’s just a normal user, but it’s suspicious
210542-0
Offline oldcat
  • 65% is Life
Re: [GB] SPACE65 | 65% Custom Keyboard(last day)
« Reply #184 on: Mon, 14 January 2019, 09:43:43 »
Last day of the GB!
Potter said invoices may go out a little later, for those joined most recently
Offline maximize
« Reply #185 on: Mon, 14 January 2019, 11:29:53 »
Is there a specific time (and time zone) that the GB ends?
Offline oldcat
  • 65% is Life
« Reply #186 on: Mon, 14 January 2019, 14:27:13 »
End of day 14th PST?
Offline gutsack
« Reply #187 on: Mon, 14 January 2019, 14:28:22 »
Joined!
Offline konart
« Reply #188 on: Mon, 14 January 2019, 16:00:05 »
By the way, can Zeal PCB screw-in stabs be used here?
Offline oldcat
  • 65% is Life
« Reply #189 on: Mon, 14 January 2019, 16:15:50 »
Pretty sure it shouldn't be a problem. GMK screw-in has been tested, maybe we can ask Potter to test the transparent screw-in stabs which should be identical as the zeal one?
Offline YisSerL
« Reply #190 on: Mon, 14 January 2019, 17:05:06 »
Airpotter, send you a PM to update my invoice.  Thanks!
Offline oldcat
  • 65% is Life
« Reply #191 on: Mon, 14 January 2019, 21:14:05 »
Probably still sleeping. Don’t worry he is very focused on this GB :)
Offline AIRPOTTER
« Reply #192 on: Tue, 15 January 2019, 00:59:18 »
I've updated it and I've seen you pay for it. Thank you very much for your love of space65
Offline AIRPOTTER
« Reply #193 on: Tue, 15 January 2019, 01:00:36 »
Thanks,my man... Words can't express my gratitude anymore.
Offline oldcat
  • 65% is Life
« Reply #194 on: Tue, 15 January 2019, 09:31:31 »
Hey man you are doing a great job. Always happy that designer tries his best to lower cost for buyers (in other words, not charging crazy premiums for limited slots.)
Now hopefully you can deliver the spaceships on schedule without errors :) I’m sure it will take a lot of effort
Offline crzone
Re: [GB] SPACE65 | 65% Custom Keyboard(invoicing)
« Reply #195 on: Wed, 16 January 2019, 01:55:48 »
And now we wait...
Out of curiosity, anybody has an idea who handles this SF Express shipping in Europe? Is it regular post, EMS post or some other courier?
    • MechWiki
« Reply #196 on: Wed, 16 January 2019, 05:46:39 »
Since the GB is winding down (form not closed yet?), I've Updated my 'Colour Data' Post above.
Offline moltenmuffins
« Reply #197 on: Wed, 16 January 2019, 08:50:26 »
Glad to see the project do so well. Can't wait for the boards to ship!
Offline anon23
« Reply #198 on: Wed, 16 January 2019, 13:00:49 »
I have only one experience with SF Express, but my packet went to Netherlands first using PostNL when it entered Europe (I am in France) and then it was my local regular postal service.
But for me it is taxed for sure anyway. EMS, local post, UPS or whatever. It is really rare I don't get taxed no matter who it is.
Offline crzone
« Reply #199 on: Wed, 16 January 2019, 14:38:12 »
Thanks, if it's the regular post then it depends on the value that was declared and on luck. Worst case is 19% VAT on the full value. Anyway, if this KB turns out as awesome as the pictures suggest it will be worth it.
