Author Topic: Pemdas' 3d printed stuff - updated Artisan Box to parametric design  (Read 9707 times)
Offline Pemdas
Parametric Artisan Drawer
Stumbled upon a video about parametric design and took the day to redesign my artisan drawer with parameters!
Here are the share links for the Fusion 360 files.
Parametric Drawer: https://a360.co/2NPGQvA
Parametric Box: https://a360.co/36FvaEw
________
-The xCell/yCell parameters control the array of slots. X is the across and Y is depth.
_____
-Get the length and width of the drawer.
_____
-Insert length/width numbers into "drawerWidth" & "drawerLength"
-drawerNumber parameter controls number of drawers...
_____
-Go crazy if you have a big printer!
_____
Artisan Drawer
Was tired of having my artisan caps just lying about on my desk so designed a quick box to house them.
Warning it takes a stupid long time to print. ~29 hours for the outside box, ~6 hours for each drawer, and ~3 hours for the inserts.
Still need to print the second box for the rest of the colors but waiting on a filament shipment before starting that.
https://www.thingiverse.com/thing:3341471
_________________________
Trophy mount for switches.
MX and Alps versions available. Hole in the back for 6x3 magnet
https://www.thingiverse.com/thing:3532650
_______________________________________
« Last Edit: Wed, 06 November 2019, 03:00:56 by Pemdas »
Offline hayt
Re: Artisan Drawer
« Reply #1 on: Tue, 08 January 2019, 00:03:26 »
Very cool bro, I dig this. Now you’re gonna have to fill em all up :P
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: Artisan Drawer
« Reply #2 on: Tue, 08 January 2019, 06:12:14 »
Here's the thingiverse link if anyone wants to print one
Very cool project! Do wish I had more deskspace but this is quite a nifty way to get things stacked up and organized.
Offline ArchDill
Re: Artisan Drawer
« Reply #3 on: Tue, 08 January 2019, 06:52:19 »
This is pretty rad, great job!
Offline dodung.breakwood
Re: Artisan Drawer
« Reply #4 on: Sat, 19 January 2019, 08:04:54 »
Your work is awesome
Offline sublyme
  • sublyme_keys
Re: Artisan Drawer
« Reply #5 on: Sun, 03 February 2019, 12:42:41 »
This looks fantastic. I really need to pickup a 3D printer!
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: Artisan Drawer
« Reply #6 on: Sun, 03 February 2019, 13:39:22 »
Dang that's pretty slick, wonder if you could make a clear one.
Offline brianjking
  • always carry a towel.
    • @brianjking
Re: Artisan Drawer
« Reply #7 on: Sun, 03 February 2019, 14:46:13 »
Might have to try to shrink this down as my print bed is too small. Great work either way and thanks for sharing!
Offline Pemdas
Re: Artisan Drawer
« Reply #8 on: Wed, 06 November 2019, 03:00:21 »
Well it's almost a year later but I came back to my box and made it parametric! If you still need it shrunk super easy to do now if you have fusion 360 :)
Offline outterspacetits
Re: Pemdas' 3d printed stuff - updated Artisan Box to parametric design
« Reply #9 on: Sun, 07 June 2020, 02:25:17 »
Hello!
I was reaching out to you because I have a strong interest in running a small group buy.
Given I have several machines that can work day and night, I can probably put out about 70 in a month. I can run quality check and finish them accordingly.
I was trying to contact you to receive permission to do this after I created an initial interest check and drummed up prices.
I don't know if there are cheaper alternatives to this so I'm also open to your input on the matter.
And considering this is my first time attempting this, I'm printing out some copies of it to share (both the two drawer and four drawer). I can play around with the design a bit to make the printer eat less material to make it less costly.
So if it's okay with you, I would like to give this an honest shot.
Offline Freznel
« Reply #10 on: Wed, 16 June 2021, 05:03:44 »
How can I download the file from the public link and open it in Fusion360?
