Author Topic: [IC] Doyu Studio Chiwi60 round 2  (Read 21590 times)
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
Re: [IC] Doyu Studio Chiwi60 round 2
« Reply #50 on: Wed, 06 February 2019, 20:08:56 »
Very interested in a WKL kit for an ED white w/ 7 degree case!
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #51 on: Wed, 06 February 2019, 20:25:56 »
Consider me tentatively "in" as long as the angle is 7 degrees or lower (5-6 would be ideal but I know some people really like their steep boards).
But I would want to see (and hear) the solid polycarb bottom, as well as see what the finalized layout options are.
« Reply #52 on: Wed, 06 February 2019, 21:35:45 »
a little split space goodness is always a plus
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #53 on: Sat, 09 February 2019, 08:19:23 »
Any timeline on the GB launch? :) the DLC saveup has started 🎩
Offline sennin32
    • Doyu Studio
« Reply #54 on: Fri, 15 February 2019, 11:04:59 »
You can check it here :)
https://trello.com/c/zmal8bhR
Offline RETURNISO
« Reply #55 on: Fri, 15 February 2019, 15:58:42 »
So.. if I am reading this correctly, you will open up for orders on the 22th this month :eek:
Offline kimwonsik
« Reply #56 on: Sun, 17 February 2019, 11:01:47 »
I'm so looking forward to it.
I hope it's going to go fast!!
Offline menuhin
« Reply #57 on: Sun, 17 February 2019, 14:21:33 »
Can it starts towards the end of March? It is kind of too sudden for me to prepare...
I really want to join!
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline tadityar
« Reply #58 on: Mon, 18 February 2019, 07:38:26 »
Is there a prototype of the stainless steel version?
Offline sennin32
    • Doyu Studio
« Reply #59 on: Mon, 18 February 2019, 11:19:20 »
No.
We made prototype with brass, but there's some tiny spot, I can't show the issue through pics, sorry.
Been told it is because of brass is harder to control, they get impure spot easily.
I asked several manufacturers, most of them suggest me switch to stainless to solve the issue.
Might able to push the end date a little.
We've arrange most of things with manufacturer before lunar new year @@
You might also consider get it later.
We have to make much more than people ordered this time because of MoQ and high fail rate in R1.
SHould be
yes @@
Offline KaosJ
« Reply #60 on: Mon, 18 February 2019, 15:11:55 »
No.
SHould be
yes @@
Why are we using Trello now?
Offline sennin32
    • Doyu Studio
« Reply #61 on: Thu, 21 February 2019, 02:06:50 »
Find a tool to remind me 0.0
Or missing things often
Offline kimwonsik
« Reply #62 on: Sat, 23 February 2019, 00:45:02 »
This photo option is "Stainless steel /w Sandblast Surface"
Is that right?
Offline sennin32
    • Doyu Studio
« Reply #63 on: Sat, 23 February 2019, 00:47:10 »
Is that right?
This is black DLC.
You can see the fiber reflection on the side.
Offline NimbleTortoise
« Reply #64 on: Sat, 23 February 2019, 01:26:21 »
Forgive my ignorance, is the Chiwi60 a bottom mount case? It doesn't look like a tray mount.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #65 on: Sat, 23 February 2019, 02:10:12 »
It's top mounted.
Offline heavyheaded
« Reply #66 on: Sun, 24 February 2019, 00:03:56 »
Interested!
Would there be an option of the kit without the PCB? I have enough 60% PCBs of my own already!
You will need the DO60 PCB. I thought I could use my own PCB in round 1 and none that I tried (dz60, zeal60) had a USB port that extended far enough to be functional through the case (had both kinds of USB cutout cases as well).
Offline osamine
« Reply #67 on: Sat, 23 March 2019, 15:34:06 »
Interested!
About how far would you day the usb c connector on the pcb is from the case?
