Author Topic: [IC] ADK64 - 3D Printed 60% case for alps64  (Read 25287 times)
Offline ReDsNoTDeAd
    • RNDKBD
Re: [IC] ADK64 - 3D Printed 60% case for alps64
« Reply #50 on: Fri, 01 February 2019, 17:14:42 »
Small update:
Belle is trying a new nozzle to get the grey to cooperate, so we have just a little more testing to do before I open the GB.
Hang in there!
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #51 on: Mon, 04 February 2019, 21:25:24 »
I've gotten a few requests in the google form to offer plates and PCBs - unfortunately I do not have anything of my own design, but I will point you to Hasu's stuff - he sells an alps PCB + plate (plate is FR4, which is a great material) that is ready for the AEK layout (and a few others) at a reasonable price. Please have a look!
https://geekhack.org/index.php?topic=69740.1200
He's getting new stock after CNY, but they will be found in this thread when he does.
Offline gbchk
« Reply #52 on: Mon, 04 February 2019, 22:24:32 »
What is FR4? Would you say it's better suited for Alps  in terms of sound/feel as opposed to stainless steel (specifically for orange Alps)?
Offline Rubbermilitia
« Reply #53 on: Mon, 04 February 2019, 23:31:15 »
I have a steel plate on my orange alps board in a wooden case. I really don't think the steel is ideal for the sound, and it's certainly more rigid than I would like. Next build going plastic case with fr4 plate.
edit: fr4 is pcb material
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #54 on: Tue, 05 February 2019, 00:34:20 »
As rubbermilitia said, fr4 is PCB material, so a light but strong plate. Hands down the best sound for orange alps.in my opinion... I use fr4 + orange Alps + ADK64 as my daily driver.
Offline gbchk
« Reply #55 on: Tue, 05 February 2019, 00:41:46 »
Awesome, sounds like it will be a great combination with this case.
Offline mog_genius88
« Reply #56 on: Tue, 05 February 2019, 16:51:24 »
Have you tried brass as well? I currently have a brass plate on my alps boards and think theyre ok. Considering switching to fr4 after reading the above comments
« Reply #57 on: Tue, 05 February 2019, 20:16:34 »
I've only used brass with linear switches, and its just too damn rigid/dense for me. YMMV
« Reply #58 on: Wed, 06 February 2019, 09:47:40 »
Eh ordered some fr4s to try. I think theyll sound better than metal
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #59 on: Thu, 07 February 2019, 00:42:09 »
So, great news for those who wanted smoother curves! Belle is trying a technique with a smaller layer height for the bezel, which makes it much smoother than it was previously hoped. Check out the pictures. The top half is the old way, and the bottom half of the bezel was printed with the smaller layer height! Mind the rest of the defects on the case, it was set to print quicker on the lower portion to get to the bezel faster, production models will be printed much slower.
« Last Edit: Thu, 07 February 2019, 00:43:56 by ReDsNoTDeAd »
Offline pixelpusher
« Reply #60 on: Thu, 07 February 2019, 00:50:35 »
Wow, that's a huge difference.  Looking good!
« Reply #61 on: Thu, 07 February 2019, 00:56:09 »
Looks great! Maybe GB in a week?  ;D
Offline pixelpusher
« Reply #62 on: Thu, 07 February 2019, 02:41:08 »
Where did you get your plates from?
Offline crd
  • Discord: crd#7617
« Reply #63 on: Thu, 07 February 2019, 08:13:13 »
Nice improvement!
« Reply #64 on: Thu, 07 February 2019, 08:22:35 »
The answer is literally on this page of the thread
Looks great! Is acetone vapor bath smoothing a viable option for this case? Has it been attempted? What about sanding? Are there any support materials used in its development like HIPS? Not very knowledgeable about 3d printing, but very curious
Offline gbchk
« Reply #65 on: Thu, 07 February 2019, 10:53:19 »
I'd be interested in the best way to get a perfectly finished (sanded, painted, whatever) product as well. If someone is experienced with finishing and is planning on doing it to their case, it would be a huge help if they did a write-up of the steps they took and the materials used.
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #66 on: Thu, 07 February 2019, 11:05:53 »
I'll ask Belle. As I've mentioned before, XTC-3D is an option if you want a glossy finish. I've used it for some models that needed to be really smooth and it did the job.
Offline Rykno
« Reply #67 on: Thu, 07 February 2019, 14:14:42 »
I think they refer to the finish texture of the plastic. 3d printing is notoriously -gritty-?
I'm curious as well. I like the idea of the glow in the dark version but I would want a smooth textured case =)
Offline sadayogi
« Reply #68 on: Sat, 09 February 2019, 17:16:15 »
Really interested in this case. However I want to use Lunar AEK PCB for the 65% layout.
I don’t really want to use Lunar metal case. I like the sound from heavy plastic more than the metal one. Is there a possibility of 65% ADK case?
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #69 on: Sat, 09 February 2019, 20:02:49 »
I'm going to run the GB for the 60% first, but it shouldn't be too hard to get a 65% made. We would need someone to be able to make an Alps plate for a 65% as well... So I can talk to some acrylic guys around here and see what's possible.
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #70 on: Sat, 09 February 2019, 20:07:45 »
UPDATE
Got some more samples. I'm going to run a space grey as well as a classic beige (in addition to the glow and translucent models). Here are some photos!
Offline EvvL
« Reply #71 on: Sat, 09 February 2019, 20:34:34 »
wow, those really look nice. Can't wait for the GB
Offline crd
  • Discord: crd#7617
« Reply #72 on: Sat, 09 February 2019, 21:43:57 »
Dang I might have to do a space Grey one. Looking good :)
Offline pixelpusher
« Reply #73 on: Sat, 09 February 2019, 21:47:44 »
Is that new prototype beige or white?  THe beige in your typing demo seems the same color as the keycap, but this one appears much lighter.
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #74 on: Sat, 09 February 2019, 21:51:30 »
The prototype from the typing test wasn't from belle, it was a 3D printer from an old job, so that color isn't available unfortunately.
Offline gbchk
« Reply #75 on: Sat, 09 February 2019, 21:51:49 »
Colors look great! I think I'll get one of each. Nice deskmat by the way, I have the same one.
« Reply #76 on: Sat, 09 February 2019, 22:57:09 »
daaaaaaaaaaaaaaaaaaaaaaamn
That gray looks so nice. Gimme.
Offline pixelpusher
« Reply #77 on: Sat, 09 February 2019, 23:08:51 »
I like the dark gray of the two color options.  Probably too late, but could we get a top down view?  Just noticing the tolerances around the caps is pretty big.  What does it look like from above?
Offline sadayogi
« Reply #78 on: Sat, 09 February 2019, 23:43:12 »
Awesome! The current case prototypes are looking great. Looking forward to 65% version GB.
Offline sam278
« Reply #79 on: Sun, 10 February 2019, 00:12:56 »
Huge fan of the dark grey. I feel a bit weird about getting the version with the apple logo cutout since I exclusively use windows, but it just looks so damn nice.
Also, just saying, I'd love for a version of this sometime in the future that has 1.5u blockers. AEK caps with hhkb blockers would look so dope :) that'd be endgame material, for me at least...
