Author Topic: My Old Atari 800 Keyboard Build  (Read 2060 times)
Offline Sdfg2345
« on: Tue, 15 January 2019, 17:27:14 »
Okay! So what we're dealing with here is a pc build I'm trying to do. Essentially the goal is to fit a modern gaming PC into and old Atari 800 case, but what's the point if I can't get the Atari's keyboard to work too, right?
So basically I have absolutely everything in the old board's matrix wired up to a teensy 2.0...
Here's the matrix:
210649-1
210651-2
I've been attempting to use KBFirmware and then QMK Toolbox to get it all working in the Teensy, but for the love of me I just can't get it...
It's a bit much to ask, but I will attatch the files for KBFirmware and if anyone could take a quick look it'd be much appreciated as I've reached a dead end.
* keyboard-layout (1).json (1.07 kB - downloaded 297 times.)
Also on the teensy the keyboard is plugged in to pins 0-17
 Thank you!
Offline Sdfg2345
Re: My Old Atari 800 Keyboard Build
« Reply #1 on: Tue, 15 January 2019, 17:28:40 »
BTW, If absolutely any other images or information is needed just let me know!
