Author Topic: Zenith Z-150 F7 Key Not Working  (Read 1486 times)
Offline postanthony3000
« on: Sat, 19 January 2019, 00:18:33 »
So I have a Zenith Z-150 where the F7 key will beep when pressed but not register on the computer. All other keys register fine. I checked the traces which seemed fine. Does anyone have an idea of how to fix it?
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
Re: Zenith Z-150 F7 Key Not Working
« Reply #1 on: Sat, 19 January 2019, 00:30:31 »
Did you check to make sure the switch actually closes when you press it(and consistently at that)? If switch is good there may be a cracked trace even, my omnikey had a few traces that had hairline fractures and would prevent some switches from working but others were fine, but on visual inspection nothing looked off until the board was slightly flexed.
« Reply #2 on: Sat, 19 January 2019, 01:08:20 »
Yes, the circuit closes when I press it. I checked that with a multi-meter and the fact that it beeps told me that the switch was working.
