Author Topic: Weird marks on EnjoyPBT spacebar  (Read 3299 times)
Offline ixixmmx
« on: Sat, 19 January 2019, 18:32:31 »
Hello everyone,
My EnjoyPBT keyset came in today and I notice the spacebar has some molding marks on what would be the inside of the keycap. I've been experimenting with a flipped spacebar and think I like it better but when its flipped, those marks are visible and not very attractive. Is this normal for EnjoyPBT or should I ask for an exchange? I have a set of Ducky doubleshot PBT caps that don't have this issue.
Appreciate the help.
Offline ArchDill
Re: Weird marks on EnjoyPBT spacebar
« Reply #1 on: Sat, 19 January 2019, 18:34:00 »
That is from the injection molding iirc
I would say that it is normal. They will all look like this to some degree.
Offline ixixmmx
« Reply #2 on: Sat, 19 January 2019, 18:37:50 »
Thanks for the reply. I guess I will just see if I can handle seeing the marks. Otherwise I’ll have to flip the spacebar back to normal.
« Reply #3 on: Sun, 20 January 2019, 01:26:33 »
archdill is correct, those are spruemarks
every keycap has them
Offline ixixmmx
« Reply #4 on: Sun, 20 January 2019, 01:29:38 »
Thanks. This is only my second set of keycaps so I wasn’t sure. The Ducky set doesn’t seem to have those marks or if they do, they are barely noticeable. I just flipped the spacebar back to normal and called it a day. I wish there was a way to fix/cover up these spruemarks though.
« Reply #5 on: Sun, 20 January 2019, 01:30:41 »
they might be inside the cap on some of the thinner sets, since the tooling has slightly better access to that part
cheaper sets are also often coated with something, so they may be hidden
there are a few different types of markings that are a byproduct of injection molding
