Author Topic: Best Lubricant for linear switch  (Read 18420 times)
Offline sl70309
« on: Tue, 22 January 2019, 21:14:50 »
Hello everyone,
Please recommend a Best Lubricant for linear switch.
Thank you
Offline ArchDill
Re: Best Lubricant for linear switch
« Reply #1 on: Tue, 22 January 2019, 21:18:58 »
I just used 3203 on my last round. I do a thin layer. You can get it here:
https://www.1upkeyboards.com/shop/parts-and-tools/tribosys-3203-switch-lubricant-2ml/
Offline vegs
« Reply #2 on: Wed, 23 January 2019, 01:47:25 »
+1 on Tribosys 3203.
There are various popular lubes for linears.
Krytox 205g0: very popular grease, I find it a bit too thick.
Tribosys 3204: also a very popular grease, a bit thinner than 205g0.
Krytox 104: thin-ish oil. Used to be my go-to lube for linears, still one of my favs.
If you want something super thin, you can check out Superlube PTFE oil or RO59.
hhkb 4 life
buy less
Offline sl70309
« Reply #3 on: Wed, 23 January 2019, 13:59:14 »
for tribosys 3203, the product description says "Recommended for tactile switches", does it work well with gateron linear switches? thanks
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #4 on: Wed, 23 January 2019, 15:11:30 »
My unscientific rule of thumb from lots of trial and error is:
a) if the switch housing is matte, like a milky or black, use a grease like Krytox 205
b) if the switch housing is glossy or smooth (like a clear housing) use an oil like Krytox 105 or 106
c) if it’s a Kailh linear box switch go with a grease regardless of the switch housing material
Also I tend to put a very light dab of Krytox grease on the spring on each end because there’s no chance of it migrating like oil might.
Offline vegs
« Reply #5 on: Thu, 24 January 2019, 00:56:05 »
Yes, 3203 works great with linear switches. I prefer it over 3204.
hhkb 4 life
buy less
