Author Topic: [IC] Omega 60 - By Windeh  (Read 68107 times)
Offline lac29
Re: [IC] Omega 60 - By Windeh
« Reply #150 on: Fri, 31 May 2019, 10:33:35 »
Where is the link to the discord channel?
Offline pheonix991
« Reply #151 on: Wed, 19 June 2019, 13:08:06 »
Any new updates?  I'd really like to not miss this.
Also, there's a discord?  Could someone send it to me?
Offline ptiede
« Reply #152 on: Wed, 19 June 2019, 14:18:16 »
I believe the discord is really only for people who were in paradox and reflex group buy for the time being.
Offline ArchDill
« Reply #153 on: Wed, 19 June 2019, 15:22:34 »
Hey windeh do you have a discord server for your projects?
I'll probably set one up soon for everyone to join. Currently there is only the one channel setup for those that paid for the Paradox / Reflex GB.
What is the height of the bezel front end?
Curious how much height does gasket add to the profile
The front edge is just under 20mm. However the keycap bottom height is recessed into the bezel by about 2mm, so the keys sit slightly lower, and you don't easily see the bottom edge of the caps, which also reduces the visual size of the bezel gap.
Cherry Side Profile:
SA:
Try looking at your keyboard at this angle for comparison:
The mounting design have no affect on the required board front bezel height. I can lower the front height to under 15mm if that was my goal...  ;)
I filled the form.  I wonder if your case is compatible with this plate:
https://kbdfans.cn/products/dz60-cnc-aluminum-plate?variant=2208864534541
it is 2u left shift brass plate, compatible with dz60 pcb and kbdfans 5 degree case
The board will only work with the included plate, as it is not a tray mount design for the plate you linked.
This thing looks so so good
Offline briano1905
« Reply #154 on: Sun, 07 July 2019, 08:00:48 »
Very unlikely but ill try anyways. Are there any available spot left?
If yes I would love to get in if not I'm waiting for R2. more info on that would also be great :)
Offline juaninamilli
« Reply #155 on: Tue, 09 July 2019, 08:45:45 »
This is an IC, not a GB. “R1” hasn’t been released yet.
Offline briano1905
« Reply #156 on: Wed, 10 July 2019, 06:17:28 »
from page 3:
There are 22 Paradox / Reflex participants that joined the discord channel, and will get first dibs.
The price will remain per the OP. It would be dumb to raise the price after going through all the effort to bring it down in the first place...
We are looking at up to 6 A-Stock, and around 10-12 total kits for sale.
looks like R1 is limited to those who got in Paradox / Reflex unless i'm missing something
Offline Windeh
  • a no name
« Reply #157 on: Wed, 10 July 2019, 08:55:43 »
Yes, most of the available kits have already been raffled off and paid for by the Paradox / Reflex participants.
Offline Nvmbra
« Reply #158 on: Fri, 06 September 2019, 14:09:52 »
I would love to see some builds and typing tests if anyone from the raffle is willing to share  :)
Is there an estimate for R2 with blockers yet?
Offline jumpmineralwater
    • jumpmineralwater IG
« Reply #159 on: Sat, 14 September 2019, 04:29:47 »
Thanks Windeh for the Omega 60 :thumb:
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #160 on: Sat, 14 September 2019, 04:32:17 »
Ugh. Me want!
Typing tests are welcome if you're willing to make one :p
Offline ramnes
  • T fou, mec?
« Reply #161 on: Sat, 14 September 2019, 05:25:03 »
Looking very good indeed, interested if the GB ever goes public.
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #162 on: Sun, 15 September 2019, 20:15:49 »
Great looking board. I'd love to see some more builds if anyone cares to post them
Offline Windeh
  • a no name
« Reply #163 on: Mon, 23 September 2019, 13:56:31 »
proboy84 just posted the buildlog and typing test of his Omega60 on /r/mk. :thumb:
https://www.reddit.com/r/MechanicalKeyboards/comments/d88qih/longawaited_omega_60_build_log_in_comment/
Offline proboy84
« Reply #164 on: Mon, 23 September 2019, 14:30:40 »
Offline avtar
« Reply #165 on: Sun, 29 December 2019, 20:35:43 »
I found this thread too late :( Is there going to be another run?
