Author Topic: Keycap profile clerification  (Read 9592 times)
Offline YouKnowHens
« on: Wed, 30 January 2019, 09:23:40 »
Hi.
Im kind of new on this keyboard comunity and have reed a lot about diffrent keycap profiles. One thing that I can't get the hang of is the OEM profile. Please correct me if I'm wrong but is OEM the most common keycap profile of all and that it's the one that both Razer and Corsair uses. One other thing that I'm wondering is if filco is just an other word for OEM. If not then what is it.
Please help. Thanks!
Re: Keycap profile clerification
« Reply #1 on: Wed, 30 January 2019, 10:15:48 »
See if this helps clarify your question about profiles
https://deskthority.net/wiki/Keyboard_profile
Many times people say OEM profile to mean a generic profile that isn't aftermarket or specialized.
And Filco is a brand/company, a part of diatec.
https://deskthority.net/wiki/Filco
Offline seville57
« Reply #2 on: Thu, 31 January 2019, 07:42:18 »
Hi.
 The problem with corsair (k95 and more) and razor (blackwidow and more) is that they don't have a standard bottom row size, see link: http://www.maxkeyboard.com/mechanical-keycap-layout-and-size-chart.html
So, let's say  in a Ducky keycaps set Ctrl, Win, FN/Menu and the Spacebar won't fit on a corsair k95 keyboard botten row.
Ducky, Das (in the link) have a standard bottom row size. Ctrl, Win Alt and FN/Menu = 1x1.25 and the Spaceber = 1x6.25.
Most of the Cherry MX keycaps sets won't fit on corsair k70 and more and razor blackwidow + more. You have to read the text when buyin keycaps sets.
This set (not a good one) will fit on corsair and razor but you have select the right size before ordering: http://www.maxkeyboard.com/ansi-layout-custom-backlight-cherry-mx-keycap-set-top-print.html
My Ducky One RGB YOTG with Jukebox SA keycaps.
Standard bottom row size.
« Last Edit: Thu, 31 January 2019, 09:05:08 by seville57 »
Offline Wood_Cables
    • Wood/Cables
« Reply #3 on: Wed, 06 February 2019, 09:29:09 »
I've always thought XDA is the best profile to type on comfortably. SA is my personal favorite.
Offline Lucien Midnight
  • Ridkey Studio Keycaps
    • Ridkey Studio Order Form
« Reply #4 on: Tue, 12 February 2019, 09:20:55 »
There are so many profiles now... can be hard to track. MDA (a.k.a. MIX) is new and cool, and MT3 looks really great. Would love to get my hand on some MDA blanks and any MT3 set...
Offline Timbersawdust
  • aka snorlax
« Reply #5 on: Tue, 12 February 2019, 14:19:12 »
OEM is original equipment manufacturer. Basically it means the manufacturer has a proprietary keycap profile. Each OEM profile is a non-standard profile created by the manufacturer and not based on any existing keycap. This isn't to say that it isn't similar to a profile.
« Reply #6 on: Tue, 12 February 2019, 19:53:24 »
Although in practice most OEM sets are similar profile to Cherry but slightly taller keycaps.
« Reply #7 on: Wed, 13 February 2019, 21:02:47 »
ye pretty much this
there's not a standard but they're all pretty similar
Offline melgeek
  • MelGeek-Keyboards and Peripherals Manufacture
    • MelGeek
« Reply #8 on: Wed, 07 August 2019, 02:19:57 »
MDA profile
www.melgeek.com
MelGeek- aim to bring the joy of using a mechanical keyboard to everyone.
Offline monkeycap198
    • Moonkey
« Reply #9 on: Thu, 08 August 2019, 08:40:09 »
ye pretty much this
Thanks! Im also new to this
Offline melgeek
    • MelGeek
« Reply #10 on: Mon, 12 August 2019, 21:45:54 »
ye pretty much this
that's it , agree  :thumb:
