Author Topic: [IC] MAJA (Majapahit) (Group Buy Started, Moving to Group Buy Thread)  (Read 267104 times)
Offline Vulcan
The Maja
MAJA is an ergo layout keyboard design by Vulcan and KBDfans. Maja is named after Majapahit, a great empire that once rules southeast Asia. The glorious emblem of Majapahit called the Surya of Majapahit is beautifully engraved on the brass weight.
How it's Made
The Maja is made with a highly precision CNC machine from a block of high-quality aluminum and a block of brass for the weight, it is then sandblasted and anodized to give a textured smooth finish to the surface with the desired color offered.
The Maja also comes with a polycarbonate version of the case. Polycarbonate is known for a very strong and durable material.
The Features
Maja features an ergonomic layout with an 8-degree keyboard angle to give a more comfortable typing experience. The top-mounted case system combined with a brass material as the plate will give you a rigged, firm, and consistent acoustic sound when typing.
The PCB
To provide the best end-user experience available The Maja offers a soldered version of PCB with layout option and a hot-swap PCB with a full per-key RGB light with no switch soldering require to assemble the keyboard.
The Layout (For Soldered version PCB)
Specification
Case:
1. Aluminum Top Case (Sandblast, Anodized) / polycarbonate as Option
2. Aluminum Bottom Case (Sandblast, Anodized) / polycarbonate as Option
3. Brass Plate (Sandblasted)
4. Brass Weight (Sandblasted)
5. Foam between PCB & Plate
6. Foam between Bottom case & PCB
PCB :
1. Soldered/RGB Hotswap PCB
2. QMK
3. USB type C supporting C to C
4. Ergonomic Layout
Color :
To be Announce
Video
Follow Me to see my other keyboard project
Instagram
« Last Edit: Thu, 25 June 2020, 20:50:59 by Vulcan »
Offline Vulcan
Re: [IC] Majapahit Ergo Keyboard
« Reply #1 on: Wed, 30 January 2019, 10:13:24 »
reserve
Offline cijanzen
« Reply #2 on: Wed, 30 January 2019, 10:15:59 »
Very much interested. Filled the form!
My only suggestion was to have the edges curve down towards the front instead of the hard angle you currently have. The rest of the board is curvy so I think that would suit the design more.
Offline SlamMakanen
« Reply #3 on: Wed, 30 January 2019, 10:28:32 »
Please say it'll support ISO!
Offline mbsurfer
« Reply #4 on: Wed, 30 January 2019, 10:31:10 »
Interested to see this take shape. Would like to see some renders with caps as well. Looking good so far with dedicated arrow keys!
Offline t0ch
« Reply #5 on: Wed, 30 January 2019, 10:43:33 »
Couple suggestions:
Split Backspace support
Moving the right 3-key cluster a bit more right to accommodate a forth key below that fits in the space next to the up arrow key
Beautiful board, I will be stalking its progress  ;D
Offline Araex
« Reply #6 on: Wed, 30 January 2019, 10:49:33 »
As a 65%/75% split user, I'm very interested in this!  As it is now, I'm likely to pick up 2 of these.  My one suggestion is to somehow add one more key to the upper-left area, so I don't have remap ESC/` key to Capslock.
Offline MikeTheTiger
« Reply #7 on: Wed, 30 January 2019, 11:49:43 »
I'm down.
"all the numbers or none of them cmon man" -Kokaloo
Offline _ODIN_
« Reply #8 on: Wed, 30 January 2019, 11:53:49 »
ISO support would be amazing
Gesendet von meinem H8416 mit Tapatalk
Offline fireworm
« Reply #9 on: Wed, 30 January 2019, 13:08:06 »
Alps support, at least on the pcb, would be great.  Alps plates would be icing on the cake, but I see there are many issues with plates that make a universal one impossible...
Split backspace?
Offline blizzara01
« Reply #10 on: Wed, 30 January 2019, 13:38:41 »
Interested!
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #11 on: Wed, 30 January 2019, 13:57:28 »
Noice.  Gimme.
Offline sdg2416
« Reply #12 on: Wed, 30 January 2019, 14:53:58 »
So nice! This board is on the top of my wishlist!
Offline Paddel06
  • Klugscheißer
« Reply #13 on: Wed, 30 January 2019, 15:09:30 »
I will definitely keep an eye on this board.
This is a signature.
Offline PikaJoyce
« Reply #14 on: Wed, 30 January 2019, 16:32:05 »
Amazing. Was in for the Fusion 60 and I'm interested in this as well. Filled out form!
Offline Sylanthra
« Reply #15 on: Wed, 30 January 2019, 17:17:15 »
Either of the other two designs would have been way better. This is too close to Alice.
Offline BundleOfJoysticks
« Reply #16 on: Wed, 30 January 2019, 18:47:51 »
The tilt negates any ergonomic gains from the keys being angled.
Make the case tilt the other way and I'd be interested.
Offline yuppie
« Reply #17 on: Wed, 30 January 2019, 19:07:08 »
Interested to see gasket mount / half plate / polycarb half plate
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline Nigolski
« Reply #18 on: Wed, 30 January 2019, 19:08:42 »
gimme gimme
Offline airyimbin
« Reply #19 on: Wed, 30 January 2019, 19:51:16 »
Would love to get this.
Is this going to have a max order like the Fusion?
Offline Vulcan
« Reply #20 on: Wed, 30 January 2019, 19:59:40 »
there is no max order for this one.. Fusion60 only have max order for the first round, the second round of fusion60 will not.
Offline airyimbin
« Reply #21 on: Wed, 30 January 2019, 20:07:07 »
That's awesome! I am so in for this keyboard.
Offline ullr
« Reply #22 on: Wed, 30 January 2019, 20:52:38 »
Looks good, just wish it had a key to the left of the arrow keys for symmetry
Offline OracleKev
« Reply #23 on: Wed, 30 January 2019, 23:37:55 »
macro column (s) on the left would be perfect.
Offline teamrushpntball
« Reply #24 on: Thu, 31 January 2019, 06:58:26 »
Even just a single column on the left would be great.
Offline _ODIN_
« Reply #25 on: Thu, 31 January 2019, 11:56:18 »
I would like to see an added key on the right bottom row to balance out the WKL blocker
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #26 on: Fri, 01 February 2019, 06:13:22 »
I'm an ISO guy, but for once I do not agree with people wanting ISO on this; it just wouldn't look good imho because of the case design (that sort of step cutout for each row).
I, however, agree with ODIN's comment, I would like one more key on the right bottom row.
I'll probably get one anyway, missed the Alice and that is going for way too much right now. Do you have a price estimate on this? even something really vague would do :)
Offline Vulcan
« Reply #27 on: Fri, 01 February 2019, 07:31:12 »
Thank you very much for your inputs and suggestion, from what i got so far i made some adjustment to the design.. what do you think?
You mean like this?
Offline krey
« Reply #28 on: Fri, 01 February 2019, 07:34:31 »
I love this and I hope to get one. all the best. :)
usb-c too pls!
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline _ODIN_
« Reply #29 on: Fri, 01 February 2019, 07:44:39 »
You mean like this?
yes :thumb:
Offline OracleKev
« Reply #30 on: Fri, 01 February 2019, 07:54:25 »
You mean like this?
yes :thumb:
uh, would it be better if the added key size is 1.5u?
Offline _ODIN_
« Reply #31 on: Fri, 01 February 2019, 07:57:26 »
[/quote]
I think that the blocker would be very small
Offline OracleKev
« Reply #32 on: Fri, 01 February 2019, 08:02:54 »
[/quote]
I'd argue that 1u key is pretty hard to use.  I'd prefer 1.5u even if the blocker is small.  My 2 cents.
Offline _ODIN_
« Reply #33 on: Fri, 01 February 2019, 12:00:10 »
please add stepped caps lock support
Offline oh_chesteroni
« Reply #34 on: Fri, 01 February 2019, 21:08:28 »
I agree that the newly added 1u key is too small and would likely be of no use, to me anyways. But I also would dislike how small the blocker would become if the 1u key was made bigger. I say stick with the original layout you had in mind, Vulcan.
Offline p_blaze
« Reply #35 on: Fri, 01 February 2019, 22:36:13 »
Any chance for a negative angle instead of a positive one? The reason I usually avoid ergos like this is because they are not really ergonomic - you still are forced to kink your hands upwards and pinch the nerves and tendons in your wrist. A negative angle would make this a much more attractive board, and not a budget Alice.
Another idea would be a split&tent with the ergo style intact, which would be pretty cool and solve the issue ergonomics.
Offline OracleKev
« Reply #36 on: Fri, 01 February 2019, 22:45:42 »
BTW, just realized the bottom right row (N, M, , .) is shifted by one key.
That's no go for me...  :-[
[EDIT] maybe the layout is wrong?  it doesn't seem to agree with the plate in the rendering.
« Last Edit: Fri, 01 February 2019, 22:48:50 by OracleKev »
Offline Vulcan
« Reply #37 on: Sat, 02 February 2019, 16:56:51 »
Negative angle? I dont understand, can you give me picture or drawing?
Yea a split would be nice hmm.. I ll try.. thank you very much for your advice
Sent from my SM-G610F using Tapatalk
Offline Vulcan
« Reply #38 on: Sat, 02 February 2019, 17:01:05 »
But isnt that the default layout for HHKB and other 60% keyboard? If the FN are in the left side of the shift wouldnt that be weird?
Offline Poesjuh
« Reply #39 on: Sat, 02 February 2019, 17:05:59 »
No, the layout is wrong. It should be;
FN - N - M - , - . - shift
Can totally undertand where OracleKev is coming from.
Offline p_blaze
« Reply #40 on: Sat, 02 February 2019, 19:33:32 »
http://ergo.human.cornell.edu/ahtutorials/typingposture.html
ideally, you want your hands facing inwards and at a negative angle like this:
http://i.imgur.com/oXvfizT.jpg
Of course, I would seek to improve upon that by adding space in the middle so your arms would be at resting position as well, hence the idea for a split ergo board. The split allows rotational tilt via tenting (VEA for example) for further improved ergonomics.
Offline OracleKev
« Reply #41 on: Sat, 02 February 2019, 21:03:00 »
Yeap.
FN N M , . / RShift
If it's not easy to understand, look at EM7 or Alice.
Strangely, the plate in the rendering looks right.
Offline ullr
« Reply #42 on: Sun, 03 February 2019, 01:04:14 »
Here's my take on the TGR Alice / EM7 inspired layout (middle omitted)
Offline airyimbin
« Reply #43 on: Sun, 03 February 2019, 14:14:36 »
Yeah I agree with the previous guys.
If you look at a normal keyboard and at the TGR Alice, the N M , . / are shifted over to the right.
Vulcan your keymap shows them shifted to the left one column.
If you swapped the Shift and FN key then it we could have the row look like FN - N - M - , - . - Shift.
This should be the correct layout for a normal keyboard and for layouts similar to the TGR Alice.
The TGR Alice has an extra key on that row but the arrow keys in the Majapahit take up the space for that FN to the right of the shift.
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #44 on: Sun, 03 February 2019, 14:20:24 »
Having a second B for ergonomic keyboards is a good feature.
Consider USB-C.
Offline ninjacore
« Reply #45 on: Mon, 04 February 2019, 11:05:37 »
I prefer this layout to the Alice.
I don't find the added R Ctrl all that useful, but :shrug:
+1 split backspace
Offline spyruf
« Reply #46 on: Mon, 04 February 2019, 12:58:10 »
I'd personally be very interested in an LZ Ergo type layout as I think that is incredibly functional and looks great too (granted that this isn't going to have an F-row / the entire right cluster).
I also agree on having the 'b' key exist on both sides and the "nm" row needs to be shifted to the right such that the 'n' falls below/between 'h' and 'j'.
I also don't think the right shift needs to be split.
« Last Edit: Mon, 04 February 2019, 13:01:28 by spyruf »
Offline WilySouser
  • I would RTFM, but I can't find the FM
« Reply #47 on: Mon, 04 February 2019, 13:24:20 »
I'm really digging this setup.  I have an LZ Ergo and think this is the perfect way to minimize it.  Alice goes too small for me.  All I use my F-row for is artisans anyways.
Offline _ODIN_
« Reply #48 on: Mon, 04 February 2019, 13:42:52 »
I prefer the b to be only on one site
Offline Lisinge
« Reply #49 on: Fri, 08 February 2019, 16:38:42 »
Filled the IC form. Really interested  :thumb:
