Author Topic: [IC] GMK Sandstorm | GB is live!  (Read 110504 times)
Offline AlcoholEnthusiast
Re: [IC] GMK Tactical Set
« Reply #50 on: Thu, 31 January 2019, 22:46:56 »
I like the idea of 9009/muted style mods to keep it more simple. I think black would work really well.
« Last Edit: Thu, 31 January 2019, 22:51:44 by AlcoholEnthusiast »
Offline glubazoid
« Reply #51 on: Thu, 31 January 2019, 22:52:43 »
GMK nude, I like it
Offline nephlock
« Reply #52 on: Thu, 31 January 2019, 23:13:24 »
looks dope! im in!
Offline stoic-lemon
« Reply #53 on: Fri, 01 February 2019, 00:28:25 »
Five by four and locks are loaded. Two in the chamber and the safely is out. I know nothing about guns and my trigger finger is cocked like the hammer on my M-16 revolver, ready to let loose on this. Fire in my hole!!
Offline trabbit
« Reply #54 on: Fri, 01 February 2019, 03:37:27 »
Nice! Is there any chance to add some light military green novelties?
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #55 on: Sat, 02 February 2019, 03:03:45 »
Noted. I'll test it next week.
Zekkin already suggested them, they are on my list. I'll test them too but my personal preference is to go monochrome with this set.
Offline Zambumon
    • Keyset projects
« Reply #56 on: Sat, 02 February 2019, 04:08:06 »
I've asked if something like this could be done:
Offline OutragedPudding
  • Graphic Designer-ish
« Reply #57 on: Sat, 02 February 2019, 05:27:40 »
I like this! Petition to rename this IC GMK Quakemz Green though
Offline Zambumon
    • Keyset projects
« Reply #58 on: Sat, 02 February 2019, 05:44:41 »
Denied. Set worked as intended and confused Quakemz, this means we have the perfect camouflage color.
Offline juaninamilli
« Reply #59 on: Sat, 02 February 2019, 09:16:00 »
What if you put the caps on your board, and then you can't find it?
Offline Zambumon
    • Keyset projects
« Reply #60 on: Sat, 02 February 2019, 09:48:43 »
This is probably why people have suggested that bright orange cap.
Offline bobdenard
« Reply #61 on: Sat, 02 February 2019, 15:49:18 »
This looks rad! Will look even radder if you can get the neon orange color!
Offline Zambumon
    • Keyset projects
« Reply #62 on: Sat, 02 February 2019, 16:10:31 »
We should have an answer for that on Monday.
Offline IOVERCALLHISTIOCYTES
« Reply #63 on: Sat, 02 February 2019, 16:52:10 »
Orange or not, in for a base and numpad when you make it, assuming my wallet recovers from the all bacon f-row monday morning...
Offline HotRoderX
« Reply #64 on: Sat, 02 February 2019, 17:06:42 »
Just my 2 cent but this is kinda flag and generic looking, I know its harsh sorry but its a IC and better to be honest and harsh the sugar coated fluff.
What I think needs to be changed.
The tan color is amazing that is about the only amazing thing about this keyset.
Once again just my opinion but think the mods need to be another color. That way they break up the set a bit perhaps https://www.colorhexa.com/4b5320.png which is Simple OD Green.
Then instead of using white legends go black. There nothing tactical about white.
I am also going to suggest if you want to keep the sand tones then go with varying sand colors.
I am assuming you got your inspiration from firearms that have been done in Tan colors. Those work because of the varying textures, this just falls flat.
Hope you don't take my feedback as offensive. I am just being honest with out a bunch of sugar coating.
Offline Zambumon
    • Keyset projects
« Reply #65 on: Sat, 02 February 2019, 17:26:59 »
That's exactly what I wanted: Generic and monotone. I think it contrasts well with the rest of my projects.
I prefer white alphas, they are more subtle, if I wanted black legends I'd have gone with dyesub PBT and I like more the white accent than a dark one, I tested both prior to posting the set. That being said, people have suggested a couple ideas for an accent kit so I might have to include one.
Trying to emulate camouflage patterns with varying tones won't be as nice and clean as a monotone set. I'll test some darker modifiers, but just so people could see them. Ideally I want the set to be just one shade.
^Keyboard goals (disregard that it is painted with whole different color to the one I'm using for the renders)
« Last Edit: Sat, 02 February 2019, 17:30:29 by Zambumon »
Offline ArchDill
« Reply #66 on: Sat, 02 February 2019, 20:45:30 »
I just got a board cerakoted Olive Drab... I知 flattered that you made this set for me!  :thumb:
Fro real though... this is pretty rad and would look great.
« Last Edit: Sat, 02 February 2019, 20:54:44 by ArchDill »
Offline Arithmetics
« Reply #67 on: Sat, 02 February 2019, 22:12:39 »
this is so understated its amazing
Offline navy2x
« Reply #68 on: Sat, 02 February 2019, 22:29:58 »
I could see this being really nice in certain boards of mine
Offline pixelpusher
« Reply #69 on: Sat, 02 February 2019, 22:38:57 »
I really like the mono color a lot.  I think it helps to unify the keyboard and highlight the surrounding case.  I知 interested in darker mods only if they are an addon
Offline fireworm
« Reply #70 on: Sun, 03 February 2019, 01:20:23 »
Imo, "tactical" would be with black legends in that airbrushed stencil font. (Literally the truck you showed), with white accents.
Military seems to be about most obvious legibility and production effeciency.
Offline stoic-lemon
« Reply #71 on: Sun, 03 February 2019, 06:38:38 »
There have already been a couple of rounds of a military themed set with a stenciled font in SA profile. It had guns and skulls and stars. This is something different, which I like.
Offline Zambumon
    • Keyset projects
« Reply #72 on: Sun, 03 February 2019, 06:40:14 »
And if I wanted that, there are a handful of dyesub options that would be a better fit for this purpose.
Offline bobdenard
« Reply #73 on: Sun, 03 February 2019, 07:49:02 »
I like the more subdued design, really classier than a camo/stenciled look imho.
Offline Zambumon
    • Keyset projects
« Reply #74 on: Sun, 03 February 2019, 13:53:05 »
That's a good description of what I want with the set. Obviously, I'll have to be careful when sampling the colors to guarantee that legends are readable.
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #75 on: Sun, 03 February 2019, 19:51:36 »
YES YES YES YES YES YES.
Offline typischt
« Reply #76 on: Mon, 04 February 2019, 01:02:13 »
Like the color scheme of the set and wouldn奏 mind, if it stayed mono colored. Though I wouldn奏 necessarily skip the set if the mods would have different colors.
I僧 really not interested in any military themed novelties since I僧 not really feeling this kinda thing. Ofc, this always depends on what they look like.
Offline Zambumon
    • Keyset projects
« Reply #77 on: Tue, 05 February 2019, 10:19:24 »
I'm not sure if I'd even make novelties for this set. While they can be cool, I think the barebones aspect that a monochrome set is interesting.
Offline TeeAreEffedUp
« Reply #78 on: Tue, 05 February 2019, 19:08:20 »
The set looks pretty good, the white legends reminds me of the old Desert Battle Dress uniform that the US used from the 80's- mid 90's. I think a light brown accent key in place of the current white offerings to really emulate that pattern would make the set just a bit better IMO. Regardless, at this point I'd consider picking up a set if the price was reasonable.
Offline Zambumon
    • Keyset projects
« Reply #79 on: Wed, 06 February 2019, 11:14:34 »
Maybe for the novelties we could have a couple extra accent keys and just one novelty.
Offline Jkush463
« Reply #80 on: Wed, 06 February 2019, 12:36:43 »
mm this is nice.
Offline laserbeamspewpew
« Reply #81 on: Thu, 07 February 2019, 15:06:22 »
This would pair great with a beige cerakote Modern M0110. Can you do a render of that?
Offline Zambumon
    • Keyset projects
« Reply #82 on: Thu, 07 February 2019, 15:10:50 »
No. Right now my top priority for rendering should be (the set formerly known as) GMK Samurai Blue.
Offline reidd
« Reply #83 on: Thu, 07 February 2019, 21:25:57 »
This was the only keycap colorway I thought didn't exist, and here it is. Nice.
Offline Zambumon
    • Keyset projects
« Reply #84 on: Fri, 08 February 2019, 09:59:31 »
maybe mixing commando SA and green screen mods you could get something similar.
Offline vicissitude
« Reply #85 on: Sat, 09 February 2019, 11:10:51 »
Any possibility to add some novelties to this set?
It would be really interesting and more attractive.
Also wonder who this color really shows.   ;) ;)
Offline Zambumon
    • Keyset projects
« Reply #86 on: Sat, 09 February 2019, 11:16:19 »
I have to think about it. I want to keep the set as cheap as possible.
Offline vicissitude
« Reply #87 on: Sat, 09 February 2019, 11:27:59 »
Yeah. That's why we love you so much.
You always consider for us.
Maybe try to make some 1u novelties would be enough.
We usually put them on esc or print,scroll,pause.
Offline vewy_nice
« Reply #88 on: Thu, 14 February 2019, 11:45:27 »
I've been tight on money lately... Been having to do a lot of "...Do I REALLY need this?"
But this is the only set I've come across that I'd buy in an instant if I could.
Definitely in if it ever goes live.
I wonder how it'd look on a polycarb board?
Offline Zambumon
    • Keyset projects
« Reply #89 on: Thu, 14 February 2019, 12:09:54 »
Probably good.
Offline pixelpusher
« Reply #90 on: Thu, 14 February 2019, 21:38:02 »
Hey Zambumon. I知 getting a case Cerakoted soon and I知 trying to choose a color.  Is there a Cerakote color you had in mind to match the set with by any chance?
Offline Zambumon
    • Keyset projects
« Reply #91 on: Fri, 15 February 2019, 05:19:13 »
Beige
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #92 on: Sun, 17 February 2019, 22:26:23 »
I love your monotone theme, and these colors specifically.  It also inspires a hunger for modern desert camo, which might make for an interesting set down the road. Especially if dyesub doubleshot caps are possible.  Something like this:
« Reply #93 on: Sun, 17 February 2019, 23:29:37 »
thanks i hate it
Offline LevelSteam
« Reply #94 on: Mon, 18 February 2019, 09:42:07 »
"Flat dark earth" would be a good match imo.
Offline Zambumon
    • Keyset projects
« Reply #95 on: Mon, 18 February 2019, 10:23:54 »
13 shades of dirt
« Reply #96 on: Fri, 15 March 2019, 20:56:23 »
I would buy this so hard.
Offline Zambumon
    • Keyset projects
« Reply #97 on: Wed, 05 June 2019, 10:16:12 »
Time to update this thread. Hopefully, today.
Offline sagadoi
« Reply #98 on: Wed, 05 June 2019, 10:55:14 »
Hello, Zambumon!
Really like the set.
Prepare to start the gb?
Matrix: 1.0 x10 | 1.2 x8 | 2.0 x20 | 2.2 x3 | 2.0 Ver Xmas x2 | Abel x12 | Abel VD x5 | Abel VC | Cain x2 | Mona x5 | Matrix Ti | ProjectFF
Percent: Canoe x6 | Skog x4 | Canoe FE x4 | Skog Lite x2
EVE: Moon x5 | Mira | Mira SE | Meteor x2
Equalz: Zero x4 | Zero.9 EE x7 | Mountain x5 | One x4 | Zero.9 Ti
FOX: Leaf TKL x2 | Time x2 | Orange TKL x2
TGR: Jane V2 | Jane V2 Ver CE    RAMA: U80A
FMJ TKL x4 | Jer80 x4 | Jermini | Camp C225 x7 | Evil80 x6 |  Evil82 x2 | Mech27 | DolchCR x2 | Triangle x2 | Square x2 | Mars TKL
Offline Zambumon
    • Keyset projects
« Reply #99 on: Wed, 05 June 2019, 11:00:15 »
Hello, Zambumon!
Not yet. Still far from that
