Author Topic: My First Artisan Sculpt  (Read 7599 times)
Offline Hisui
  • Team Yeen
« on: Fri, 01 February 2019, 00:22:40 »
Hello! This is my first try at sculpting with monster clay! I have sculpted with sculpey and mud clay before, but nothing this tiny! I wasnt sure I could do it! My sculpts have always been large, but Im pretty happy with how this one turned out!
Please allow me to introduce my crazy-eyed turtle/lizard/dinosaur guy :p!
please excuse the lighting, it was taken at night in my bf's work room.
211903-0211905-1211907-2
if anyone has any advice for me, any and all are appreciated!
Offline nevin
Re: My First Artisan Sculpt
« Reply #1 on: Fri, 01 February 2019, 03:36:23 »
looks great. love the differences in texture. i see influences from a couple lizards.
not sure how familiar you are with the artisan keycap making stuff, but there's a jig called :~$ynth that makes the whole process of making a usable keycap a lot easier.
thread: https://geekhack.org/index.php?topic=78551.0
available at: https://techkeys.us/collections/accessories/products/synth
but you could just as easily add one of the lego stems from shapeways to your sculpt (definitely a lot cheaper than :~$ynth)
https://www.shapeways.com/product/XPK4SPGSC/2x2-building-block-cherry-mx-key-cap
anyway, congrats. looks great!
Offline theoriginal123123
« Reply #2 on: Fri, 01 February 2019, 03:43:35 »
It looks good! One thing I would say to be aware of is the height of the keycap, with so many Cherry profile sets out there, it'd be nice if the keycap wasn't too tall.
Offline Hisui
  • Team Yeen
« Reply #3 on: Fri, 01 February 2019, 12:01:18 »
yeah! I used my bf's esc key from hydro for comparison. His nose just barely goes past. I did make him a little too small in the base though so ill be keeping that in mind when I try a new design :)
Offline Hisui
  • Team Yeen
« Reply #4 on: Fri, 01 February 2019, 12:03:23 »
Thanks! and I bought the l2k but it didnt come in the mail before leaving to see  my bf, but yeah! I also want to try out the synth as well! Ive been dabbling in research on and off for a few months.
Offline nevin
« Reply #5 on: Fri, 01 February 2019, 13:34:55 »
l2k, yeah, saw that too after i submitted my reply. very versatile little buggers.
Offline Hisui
  • Team Yeen
« Reply #6 on: Fri, 01 February 2019, 13:45:31 »
Right?! I was about to spend 165USD, now I only need the base :3
Offline sunnytime
  • :B
« Reply #7 on: Fri, 01 February 2019, 13:56:33 »
awesome work! ever think about putting something along the eyes like a gem or some sort of different color?
Offline Hisui
  • Team Yeen
« Reply #8 on: Fri, 01 February 2019, 14:03:08 »
ah I didnt! thats a nifty idea! ill try it out when i go home and have the l2k for better size refference
Offline nevin
« Reply #9 on: Fri, 01 February 2019, 14:46:17 »
just take an mx switch and superglue the stem (in the up position) so it doesn't move. there's your base.
Offline Hisui
  • Team Yeen
« Reply #10 on: Fri, 01 February 2019, 16:04:37 »
Oh true, true!
Offline BreakWoodVN
« Reply #11 on: Sat, 02 February 2019, 01:02:21 »
It looks great, maybe it will shine in the mouth?
Offline Hisui
  • Team Yeen
« Reply #12 on: Sat, 02 February 2019, 01:14:29 »
Yeah! Id like to try that once I bulk out the neck to fit the key foot print!
Offline gr4v3m4n
    • my store
« Reply #13 on: Mon, 04 February 2019, 10:22:36 »
If you have access to 3d printer why dont you give a try zbutt.
https://github.com/imyownyear/Z-Butt
Its open source. And probably a lot cheaper than buying an already made system.
Oh, join the discord too. Theres a lot of talented makers there.
Sent from my SM-G935F using Tapatalk
Offline Hisui
  • Team Yeen
« Reply #14 on: Mon, 04 February 2019, 14:18:09 »
Thanks! I joined the discord! I dont have a 3d printer, but I do want to get one eventually!
Offline rachel
« Reply #15 on: Tue, 05 February 2019, 19:30:52 »
Pretty neat! Always remember to keep check on the size of your sculpt. Synth is a very useful tool so make sure you get it! Your sculpt is good. It has the details. Look forward to see more progress from you!
Offline Hisui
  • Team Yeen
« Reply #16 on: Tue, 05 February 2019, 23:51:28 »
Thank you! :D Im busy with a few things at the moment, but I plan to do more sculpting when I free up some time!
Offline TheGlyph
« Reply #17 on: Wed, 13 February 2019, 17:18:16 »
I like that skin texture!
An easy trick for sculpting on the L2K is to put a stock keycap on and then trace the outline with an xacto knife. Then you can remove the cap and  be sure to stay inside that outline to guarantee there won't be any clearance issues with neighboring keys.
« Last Edit: Wed, 13 February 2019, 17:20:47 by TheGlyph »
Instagram @GlennTheBlack
Discord TheGlyph#8458
Offline Hisui
  • Team Yeen
« Reply #18 on: Mon, 18 February 2019, 23:36:52 »
Thanks for the tip! ;D
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #19 on: Fri, 22 February 2019, 06:29:36 »
Waaaaaaaaaaaaaaay too tall.
Offline Hisui
  • Team Yeen
« Reply #20 on: Thu, 14 March 2019, 19:19:40 »
He's actually not that tall. It's just a hair higher than the escape key on my bf's hydro set.
« Reply #21 on: Thu, 14 March 2019, 19:22:11 »
Your boyfriend has perfect taste.
« Reply #22 on: Thu, 14 March 2019, 19:22:50 »
I disagree. It's not green at all.
Offline Hisui
  • Team Yeen
« Reply #23 on: Thu, 14 March 2019, 19:27:30 »
