Author Topic: cant find  (Read 2669 times)
Offline proxy0
cant find
« on: Sun, 03 February 2019, 14:55:15 »
I seriously cannot find pbt OEM blank R1 1.75u shift and a R2 1.75u capslock. Any help would be appreciated!
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: cant find
« Reply #1 on: Sun, 03 February 2019, 15:00:25 »
Hmm that's a tough one, OEM isn't usually used with those keys since it's usually on standard ANSI boards.
kbdfans and kprepublic have a lot of sets you could check there.
Good luck with the search.
Offline proxy0
Re: cant find
« Reply #2 on: Sun, 03 February 2019, 15:38:33 »
at this point id probably take any of them as long as I can get both keys separate and in PBT
