Author Topic: [IC] Jian: an ergo 40% split keyboard  (Read 6127 times)
Offline KgOfHedgehogs
« on: Mon, 11 February 2019, 06:50:07 »
Hi! This is interest check for keyboard I designed. Here is the link:
https://docs.google.com/forms/d/e/1FAIpQLSdwGvwtzIbPnHGXDWHnTBHZ2Rppxo7zm2IfQFo6qOxk6CD4sg/viewform
IC will be open for a month and right after I'll start groupbuy if results are good
More photos: https://imgur.com/a/AG5OFt5
Information on default layout:
http://www.keyboard-layout-editor.com/#/gists/4b6c2af67148f58ddd6c6b2976c4370f
Information on pcb for each half:
• QMK firmware powered
• Works on pro micro or clones
• Has header for RGB ws2812b strip for underglow
• Supports 1 color in switch led backlight
• Supports num lock, caps lock, scroll lock led indication
• Has 22 keys
• Supports 6 dip switch
• Halves work via serial or i2c
• Can work standalone
• (maybe) 2 outer columns are breakaway
« Last Edit: Mon, 11 February 2019, 07:15:10 by KgOfHedgehogs »
Offline astronavy
Re: [IC] Jian: an ergo 40% split keyboard
« Reply #1 on: Wed, 23 October 2019, 20:02:22 »
any news?
