Author Topic: Is it possible to mod brown switches into red/silver ones  (Read 1589 times)
Offline AJM
« on: Wed, 13 February 2019, 07:53:03 »
Hi,
I have a Vortex ViBE with MX Brown switches, but I would prefer red or silver switches.
So far I've come up with these solutions:
1. Sell board with MX Brown / buy board with MX red/silver -> difficult because there are none available (with ISO layout)
2. Trade with someone, who has a ViBE with MX red/silver and is looking for brown -> makes a lot of sense, but difficult to find
3. Buy MX red/silver switches and swap them -> a lot of soldering, which I don't have a lot of practice with
4. Maybe brilliant idea:
Is it possible to just open the switches (while they're installed) and swap the brown stem with a red/silver one?
If yes, can someone recommend a tool to open the switches, that makes it easy and save. (If I would have to expect, that every second or third switch gets damaged while doing this, it might not be such a great idea after all.)
Offline Sup
Re: Is it possible to mod brown switches into red/silver ones
« Reply #1 on: Wed, 13 February 2019, 09:34:31 »
Best way would be to desolder it and solder new switches in other then that it's the other first option you said but the chance finding someone would be slim.
current
Coming soon
Offline Sup
« Reply #2 on: Wed, 13 February 2019, 09:35:22 »
Best way would be to desolder it and solder new switches in other then that it's the other first option you said but the chance finding someone would be slim. Also i am pretty sure the plate the vortex vibe uses doesn't support top opening of mx switches.
current
Coming soon
Offline killyou
« Reply #3 on: Wed, 13 February 2019, 13:57:51 »
Either sell/exchange the keyboard OR if you are positive that's your endgame keyboard or you will be sticking with it for a long time you could desolder the switches and make it hot swappable. It's only viable if you are eager to learn soldering and you will be sticking with the board for longer.
