Author Topic: PS2 to USB 1.0 (not 1.1 or 2.0) adapter?  (Read 2566 times)
Offline IBM Portable PC
« on: Wed, 13 February 2019, 18:45:21 »
I have a system which will only work with USB 1.0 keyboards. I’ve tried several PS2 to USB 1.1 and 2 adapters without success, does anyone have any suggestions?
Amongst those I’ve tried are the; so called Bluebox, Aten, Belkin, Insteon, DeLock and Lindy adapters.
I’m considering the ConnectPro and KingWin adapters...
« Last Edit: Wed, 13 February 2019, 21:42:07 by IBM Portable PC »
Offline hasu
  • @tmk
Re: PS2 to USB 1.0 (not 1.1 or 2.0) adapter?
« Reply #1 on: Thu, 14 February 2019, 00:19:03 »
what's  the system actually if I may ask? And which os do you use on it and what does the os say anything in log file?
Assuming that you have "USB 1.0 keyboard" to test the USB ports on the system, can I ask model number of the keyboard? I'm so curious because I never seen keyboard like that.
« Reply #2 on: Thu, 14 February 2019, 00:56:47 »
A Raspberry Pi when setting kernel parameter dwc_otg.speed=1, which limits the USB ports to 12MbS. This helps some USB sound cards work correctly. The only USB keyboard I’ve found that will then work, and many have tried to find others, is an old Ortek Eagle Touch which I suspect is USB 1.0.
« Last Edit: Thu, 14 February 2019, 03:09:51 by IBM Portable PC »
« Reply #3 on: Thu, 14 February 2019, 06:43:43 »
Maybe you could build your own, with the open-source TMK firmware  and hack it, just downgrading the USB version in the device descriptor.
That firmware I linked is for the ATmega32u4 microcontroller, which is found in the Teensy 2.0 and Arduino Pro Micro.
There should be no difference between USB 1.1 and later protocols when it comes to the HID class protocol, which is used for keyboards.
However, I have not been able to find any good description of what the differences are between USB 1.0 and USB 1.1, or if there are any versions of HID below 1.11 but the latter might not matter.
I suspect that the 1.1 revision could be mostly about compliance to a better defined set of the same specifications.  I have found conflicting information about the highest speed of USB 1.0: if it supports "Full Speed" (12 Mb/s) or not. Maybe "Full Speed" was considered an extension in USB 1.0 and compulsory in 1.1.
I think the firmware I linked to does not support anything else than Full Speed but I know the microcontroller itself supports low speed, so maybe that could be hacked as well but I think it is plausible that that is not necessary.
« Last Edit: Thu, 14 February 2019, 06:59:14 by Findecanor »
« Reply #4 on: Fri, 15 February 2019, 02:25:05 »
Interesting, however, I don’t have that much time to invest in this. I’m trying a few more active PS2 to USB adapters......
« Reply #5 on: Sat, 16 February 2019, 03:04:00 »
Can anyone suggest the brand/model etc of any PS2 to USB adapters which have been on the market since USB first appeared?
Offline ramon0xff
« Reply #6 on: Tue, 26 February 2019, 06:52:53 »
Have you considered PS/2 to Bluetooth (I think the Pi > 3B supports it)?
Or even *this*: https://hackaday.io/project/9922-ps2pi
« Last Edit: Tue, 26 February 2019, 06:59:53 by ramon0xff »
