Author Topic: Starcraft 1/2 with Cherry Blacks  (Read 2173 times)
Offline Asp
« on: Fri, 14 May 2010, 23:33:16 »
Has anyone had any experience with RTS gaming on Cherry Blacks?
I've tried out blues for a while with a friend's keyboard and it was pretty good, so I was thinking about getting a Filco with blues. However after all the furious circlejerking over Blacks about gaming I was wondering if anyone had any experience with them specifically with SC.  The actuation and bottom-out force is pretty high with the Blacks so my main concern is if it will tire out fingers bottoming the keys out so much. SC is a little different from FPS gaming, nobody hovers with the keys slightly depressed, it's more like typing frantically.
So, any experience/theories?
Offline zeph
« Reply #1 on: Fri, 14 May 2010, 23:45:54 »
I've been playing Starcraft 2 and Heroes of Newerth with Cherry blues for the past couple of days and they're great. I've tried Cherry blacks on the Steelseries 7G, and although I can see why they'd be great for playing Q3/CS/insert new FPS of your choice I can't imagine why they'd offer any significant advantage over blues/browns for RTSs.
Offline elbowglue
« Reply #2 on: Sat, 15 May 2010, 00:02:19 »
For games like starcraft 2, blues are better than blacks.  For first person shooters black are better than blues.
The audible click confirmation of hitting a key is useful to know you hit the key successfully.
Welcome to geekhack!
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline Viett
« Reply #3 on: Sat, 15 May 2010, 00:13:48 »
Quote from: zeph;182506
Same here. Blues work great for SC 1 / 2 and HoN. All you need is a press -- no precision is necessary -- which makes Blues perfect.
Honestly, I'm against the entire notion of "Blacks are good for gaming." Many FPS require hovering and bottoming out to actuate, which eliminates all Cherries and Topres from the viable keyboard pool, as their actuation point is mid-keypress.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
