Author Topic: [IC] Dimple - a 40% layout keyboard (Final Update:kit assembling video)  (Read 53924 times)
Offline Tommicorn
Re: [IC] Dimple - a 40% layout keyboard
« Reply #50 on: Tue, 26 February 2019, 09:25:14 »
This looks great! I really love my THE50 and I will definitively try and get one if this goes to group buy.
Offline trabbit
« Reply #51 on: Tue, 26 February 2019, 19:33:49 »
Thanks man. I really appreciate that.
Offline trabbit
Re: [IC] Dimple - a 40% layout keyboard (update CNC sample)
« Reply #52 on: Fri, 29 March 2019, 00:47:20 »
Updating
Offline Baron
  • oops its me
« Reply #53 on: Fri, 29 March 2019, 10:36:26 »
WOW that looks really nice
Offline dr_unconscionable
    • [sqeleton]
« Reply #54 on: Fri, 29 March 2019, 11:16:59 »
The sample looks great! I'd love to grab one -- hopefully timing/finances will work out :)
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #55 on: Fri, 29 March 2019, 15:30:25 »
Looks great. Nice layout and excellent price.
Is there any chance at all of making a non-hotswap PCB?
Offline meidodoragon
  • ren, they/them
« Reply #56 on: Fri, 29 March 2019, 21:54:30 »
Oooh. nice! Still interested in this GB, as I like the layout and design. Especially if it'll be under $200. It'll be nice to have another hot-swap in the rotation for trying switches as well.
Offline trabbit
« Reply #57 on: Sat, 30 March 2019, 00:49:12 »
$200? OH MAN! I think I offered a way too low price of $140-150
Offline trabbit
« Reply #58 on: Sat, 30 March 2019, 00:51:17 »
All PCB will have hot swap this time. Sorry about that.
  • ren, they/them
« Reply #59 on: Sat, 30 March 2019, 03:09:24 »
Haha, I'm assuming that it will be about 200 after shipping, that's why. I've already made that mistake in mechmarket. XD
Sent from my Pixel 3 using Tapatalk
Offline TuCZnak
« Reply #60 on: Sat, 30 March 2019, 05:10:25 »
That's a pretty dope layout you got there
Offline trabbit
« Reply #61 on: Sat, 30 March 2019, 08:34:51 »
Oh, I see. Now it's about $170 after shipping.
  • ren, they/them
« Reply #62 on: Sat, 30 March 2019, 11:47:20 »
Oh, good to know. Thank you!
Offline Baron
  • oops its me
« Reply #63 on: Sat, 30 March 2019, 12:47:02 »
thats still really great
Offline Visionaire
« Reply #64 on: Sat, 30 March 2019, 13:43:11 »
What a great value at that price point!
Offline Baron
  • oops its me
« Reply #65 on: Tue, 02 April 2019, 12:29:56 »
what colors do you think you'd be offering?
Offline trabbit
« Reply #66 on: Tue, 02 April 2019, 22:15:03 »
Black/Gray/Silver/Blue Gray are sure.
Updated a new pink color, I think it's doable
Offline 94smart
Re: [IC] Dimple - a 40% layout keyboard (update new color sample)
« Reply #67 on: Wed, 03 April 2019, 04:33:06 »
so nice
Offline calveeen
« Reply #68 on: Wed, 03 April 2019, 05:54:00 »
This is awesome - will definitely jump in on this!
Offline Baron
  • oops its me
« Reply #69 on: Wed, 03 April 2019, 08:39:15 »
this is looking absolutely phenomenal
Offline pixelpusher
« Reply #70 on: Wed, 03 April 2019, 09:14:09 »
I like this design a lot.  I wish there was some way to move the screws that hold the PCB into the case.  They seem to primarily be in spots that you will always see from a typing position.  Maybe we can get brass screws to match the plate?
Offline trabbit
« Reply #71 on: Wed, 03 April 2019, 20:25:28 »
Are you serious? You can see that through keycaps in the picture?
Offline Jaxxstatic
  • Haptic Recon
« Reply #72 on: Wed, 03 April 2019, 22:39:32 »
With cherry keycaps, yes, you’d be able to see. DSA has a tighter gap right? But you placed the screws close to corners and the bottom row, so they might not be visible even with cherry or oem
Offline trabbit
« Reply #73 on: Thu, 04 April 2019, 01:16:01 »
Yes, just two screws on the upside of the interior are between two keycaps, others are basically all under keycaps.
But it have to be close enough to see. With normal typing gesture and also in the photo, it won't be noticeable.
Offline Baron
  • oops its me
« Reply #74 on: Thu, 04 April 2019, 18:44:27 »
would you be interested in color matching the pink color with the pink color code for DSA Hana?
Offline regionfree
« Reply #75 on: Thu, 04 April 2019, 20:06:07 »
yes.
Offline byoliven
« Reply #76 on: Thu, 04 April 2019, 21:48:48 »
Would like to join if deep purple could be a choice.
Which should look amazing for all my keycaps with GMK DY color!
Offline rowie
« Reply #77 on: Thu, 04 April 2019, 22:01:10 »
Hope this makes it to the groupbuy stage. I would love to get one in white like in your renders if possible.  :thumb:
Offline BserLarry
« Reply #78 on: Tue, 09 April 2019, 09:56:50 »
I like the 40% layout but may I suggesting the addition of a “? /“ key in the standard layout?
It’s such a commonly used key that I think it warrants being in the standard layout beside the “ > .” Key:-)
Other than that, I’m happy with it!
Offline pixelpusher
« Reply #79 on: Tue, 09 April 2019, 11:14:16 »
I believe the idea is you just use QMK for tap key on that one.  Tap for Question mark, hold for shift.   The 2u shift looks nice and I doubt you'd notice the difference in touch typing.
I'd personally not use the arrow cluster there, b/c I'm too used to the minivan arrows in the JKL; position.  But you can use those bottom keys for all kinds of handy things like layer toggles.
Offline BserLarry
« Reply #80 on: Tue, 09 April 2019, 12:36:51 »
Good idea  :thumb:
Offline 19MODL
« Reply #81 on: Tue, 09 April 2019, 14:03:50 »
Super cool! I'm hooked to my arrow keys but love 40%s. I know the images are simply renders but some of those colors look extremely promising. Plus, HHKB is almost unheard of in the 40% world. Sign me up!
iGK64 - Kailh Speed Bronze - GMK Laser
Pok3r - MX Red - GMK Red Samurai
NIU Mini - Tealio - DSA Drifter
Incoming: Mechmini 2 - SA Night King
Offline trabbit
« Reply #82 on: Tue, 09 April 2019, 22:24:19 »
Thanks! Actually some 40% HHKB like do exist already, I just made a little small revise.
Offline nettik
« Reply #83 on: Thu, 11 April 2019, 00:31:46 »
I'm loving the pink color! HHKB with dedicated arrow cluster is fantastic, I am definitely in for when the GB starts.
Offline trabbit
« Reply #84 on: Thu, 11 April 2019, 08:44:35 »
Thanks, spots will be ready next month.
Offline PaultheSloth
  • JW Double Black
« Reply #85 on: Thu, 11 April 2019, 09:04:50 »
Will it be limited spots?
Polaris|Leaf60|QXP|DC60|Planck|SKB60|Tokyo60|UT-47|AnnePro
Offline trabbit
« Reply #86 on: Thu, 11 April 2019, 21:12:54 »
I made 100 spots, I think it's enough for 40% users. If not, I will make some more.
Offline Baron
  • oops its me
Re: [IC] Dimple - a 40% layout keyboard (update ETA)
« Reply #87 on: Thu, 11 April 2019, 21:53:52 »
do you have pictures of all the final colors?
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #88 on: Thu, 11 April 2019, 21:58:10 »
Next monthGreat, gives me some time b/c the CandyBar had me sweating bullets b/c a want a dimple too. Thanks lazydesigner!!!
Offline trabbit
« Reply #89 on: Thu, 11 April 2019, 23:22:45 »
The cases are ready this month, I will post pictures of all five colors. The PCBs will be ready next month.
Offline trabbit
« Reply #90 on: Thu, 11 April 2019, 23:35:10 »
You could do that if you like, just put the key on the first layer instead of other keys. But eventually you will give up some keys and put them to another layers. If you don't want to give up, you have to look for 45%, or 50%, or 60%, or 65% or even bigger.
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #91 on: Thu, 11 April 2019, 23:58:17 »
I heart this.
Offline nettik
« Reply #92 on: Thu, 25 April 2019, 22:21:21 »
Forgive my very newb question, but will the hotswap PCB support PCB switches - the ones with 5 prongs/pins? It looks like it can, but I want to make sure. Also, is the board USB-C, and where is the cutout located?
Offline trabbit
« Reply #93 on: Sat, 27 April 2019, 01:52:55 »
Yes, the PCB supports 5 pins switches. The USB cutout is located between the first and the second switches.
Offline Baron
  • oops its me
« Reply #94 on: Thu, 02 May 2019, 00:47:10 »
will this have QMK?
Offline Archedemus
« Reply #95 on: Fri, 03 May 2019, 01:25:54 »
We need some juicy updates plzzz... Also, how much will it weigh?
Offline yui_
« Reply #96 on: Fri, 03 May 2019, 10:26:51 »
What firmware is this pcb going to be running on?
If it isn't QMK, will the software have full linux support?
Offline Baron
  • oops its me
« Reply #97 on: Fri, 03 May 2019, 13:35:24 »
concerned about this as well
Offline trabbit
« Reply #98 on: Sat, 04 May 2019, 22:09:31 »
will this have QMK?
Yes, it will.
Offline trabbit
« Reply #99 on: Sat, 04 May 2019, 22:12:07 »
So far, all my design THE50, THE60, Dimple, THE30 are all based on QMK and will have QMK configuration supported.
