Author Topic: [IC] THINK6.5° - PC/Alu 65% Keyboard (Brass Raffle 4/13)  (Read 321051 times)
Offline Kokaloo
  • 🤘(• ω •)🤙
Is top half Alu and bottom half PC a possible request?  :D
Offline BlankeyGotCaps
It was possible but I believe Oldcat took the option away. Its untested and PC and alu expand / shrink differently and could cause problems. Needs lengthy testing to see if its ok to do which I also believe he said he was going to do for like 6 months or something and if all goes well it might be a thing in the future.
Offline taropaste
did i miss this announcement?
Hey I think Google may have got it wrong or something. I am not very good with timezone, only aware that AZ time zone never changes. MST is 6:56PM right now?
im in the west cost and it says MST was an hour later than we currently our. so it was posted at 7:50 MST according to the google (6:50 PST)
If you're PDT (daylight savings) then it's the same as MST. PST (standard) is one hour behind MST. I had to figure it out too.
Offline oldcat
  • 65% is Life
how do you install the leds that are next to the badge?
We will provide the hotswap SIP sockets and LEDs. You will need to solder that 6 hotswap sockets, then just insert the 3 LEDs in (and out and change freely)!
All instructions will be provided.
Offline wbandit
sorry for the dumb question if it is (kinda new to this): what stabilizers should I get for this PCB/which ones do people recommend? I know that the GMK screw-in stabs are good in general, but can I get those for this PCB? thanks in advance!
Offline oldcat
  • 65% is Life
Yes, GMK screw-in PCB mount stabs are good. If you are in US, consider buying from Novelkeys!
Offline wbandit
awesome, thanks for the super fast reply! will definitely order from them. super stoked for this board!
Offline Sic_Alpha
Re: [IC] THINK6.5° - Polycarbonate 65% Keyboard (GB/Raffle details posted)
« Reply #557 on: Mon, 01 April 2019, 00:55:33 »
Zeal stabs are really good too; expensive though.
Offline arrowM
« Reply #558 on: Mon, 01 April 2019, 01:10:18 »
Any chance you'll release a sound test video for the PC prototype? Would love to have a demonstration.
Offline oldcat
  • 65% is Life
« Reply #559 on: Mon, 01 April 2019, 01:16:06 »
Yes the build stream is still on schedule to be live before the GB starts. I will share a link when it is available.
Offline Bryan
« Reply #560 on: Mon, 01 April 2019, 01:18:10 »
I have a question of detail before the GB opens up.
I noticed on renders and samples of the top case for the badge case vs non badged case there is a little divot or cut out that runs along the right side of the case and is non existent on the left side of the case.
I plan on getting the non badged case as that is my layout preference, but based on samples and renders it seems that the right side divot or cut out is not present (I prefer the right side of the case to be a straight edge as it looks more uniform to the left side of the case).
Is the cut out/right side straight on the non badged layout? If so YAY!
« Last Edit: Mon, 01 April 2019, 01:21:21 by Bryan »
Offline oldcat
  • 65% is Life
« Reply #561 on: Mon, 01 April 2019, 01:48:41 »
Hey bro, Non-badge version has no big chamfer (will have straight line)
216429-0
Offline jaredddm
    • Instagram!
« Reply #562 on: Mon, 01 April 2019, 02:26:40 »
can we get proto pics of that rose gold alu? gotta see how its gonna look before buying! ^^
Offline oldcat
  • 65% is Life
« Reply #563 on: Mon, 01 April 2019, 02:37:15 »
Yes here you go. Here is the color sample for rose gold Alu version
216431-0
Offline AlcoholEnthusiast
« Reply #564 on: Mon, 01 April 2019, 02:55:36 »
Any chance of a filled in/no badge blocker?
Offline wellbeing44
  • kebord good kebord fun yum yum
« Reply #565 on: Mon, 01 April 2019, 04:01:14 »
Or a PC badge that blends in, maybe?
Offline HAYAN
« Reply #566 on: Mon, 01 April 2019, 05:25:45 »
OH.. Gmk DMG purple color alu option is gone?
Sad X(
Offline Marutks
« Reply #567 on: Mon, 01 April 2019, 05:47:10 »
That cutout around enter key is huge.   Does it not affect switch stability (enter and pipe) ?
I want to use ANSI Enter with "compatible" plate because of split backspace.
Offline kolyz
No chance of having the sip sockets soldered at the manufacturing level? Opting for the hotswap pcb (for solderless build) and having to solder 6 sockets kind of defeats the purpose.
Offline oldcat
  • 65% is Life
More costs. But I will make it happen for you buddy.
Thanks for the feedback. Let me know what else can be improved.
Offline kolyz
OOF! You're the best oldcat, thank you so much! <3 so excited to join this GB when it goes live.
Offline yur1orlov
« Reply #571 on: Mon, 01 April 2019, 10:42:34 »
Pretty excited.. might get two, too many choices
Keycult no1rev1 | Keycult no2rev1 | Jane v2 Blue Grey | Kyuu x2 | QXP | Rukia
Offline oldcat
  • 65% is Life
« Reply #572 on: Mon, 01 April 2019, 12:03:57 »
Just confirmed that both gf-enhanced black and regular clear (both frosted) PC will be made available without additional costs.
2 of the PC Prototypes will be shipped to me tomorrow or Wednesday. And potter will do a build stream and some typing tests on  Sunday.
216455-0
216457-1
Black one has not been polished or crystal blasted
Offline Sic_Alpha
« Reply #573 on: Mon, 01 April 2019, 12:30:46 »
Is the black opaque after polishing/blasting?  I kind of like the transparent clear :)
I'm sure we'll get examples of all before having to decide and pull the trigger.
Offline oldcat
  • 65% is Life
« Reply #574 on: Mon, 01 April 2019, 12:41:28 »
Right we will take some high resolution pictures before GB starts. From what I can see it is not translucent. I will see for sure when I get them.
Offline ninjacore
« Reply #575 on: Mon, 01 April 2019, 12:57:38 »
Will airpotter be doing alu and pc builds? I'd love to hear the difference between the two.
Offline oldcat
  • 65% is Life
« Reply #576 on: Mon, 01 April 2019, 15:49:51 »
Only PC build for the 6.5, he will also be building a Space65, which is top_mount alu board.
Offline daviddoi
« Reply #577 on: Mon, 01 April 2019, 17:08:36 »
very interested. cant wait for gb, i wish there was a white for this
Offline oldcat
  • 65% is Life
« Reply #578 on: Mon, 01 April 2019, 19:04:01 »
Thanks! Unfortunately, there is no anodization white. Hope the frosted PC will satisfy your needs for a bright white-ish color!
Offline joelmats3
« Reply #579 on: Tue, 02 April 2019, 01:02:45 »
Just looked at the details and wondering if there is an option to choose the color of the weight/badge? It says gold pvd so wasn't sure. Thanks!
Offline Moridin
    • Infinite Diaries
« Reply #580 on: Tue, 02 April 2019, 01:27:13 »
Oldcat, when (approximately) will the GB start?
Offline oldcat
  • 65% is Life
« Reply #581 on: Tue, 02 April 2019, 13:33:40 »
Hey Moridin, brass starts 4/13, PC/alu start at 4/14, details are here: https://geekhack.org/index.php?topic=99634.msg2742332#msg2742332
Offline ninjacore
« Reply #582 on: Tue, 02 April 2019, 14:21:21 »
You should really just add this to the OP.  I know it's linked there, but still...
Offline Moridin
    • Infinite Diaries
« Reply #583 on: Tue, 02 April 2019, 15:36:04 »
Thanks.
Offline R0N1N
« Reply #584 on: Tue, 02 April 2019, 16:39:35 »
Oldcat, which color case is the one in the gmk vaporwave render?
Sent from my SM-N950F using Tapatalk
Offline oldcat
  • 65% is Life
« Reply #585 on: Tue, 02 April 2019, 17:19:25 »
Thanks! Doing it now.
Offline oldcat
  • 65% is Life
« Reply #586 on: Tue, 02 April 2019, 17:20:53 »
It's the good old gray color.
Offline oldcat
  • 65% is Life
Re: [IC] THINK6.5° - Polycarbonate 65% Keyboard (launching 4/13)
« Reply #587 on: Tue, 02 April 2019, 18:24:19 »
Here are some possible options (not available for all models):
PC and Alu colors: mid 5 are alu, top/bottom PC:
Badges and Weights:
Layouts:
Layout KLE:
Offline DetectiveNio
« Reply #588 on: Tue, 02 April 2019, 20:43:10 »
will there be more color choices to the PC version Mr Oldcat? Dont have a PC board yet but that rose gold is sexy
Offline Aznguyen316
« Reply #589 on: Tue, 02 April 2019, 20:50:58 »
wonder if something like the KBD67 hotswap pcb would fit into this case.  Split backspace hotswap is what I would most prefer. Sorry if it's been mentioned, but does this have a left side usb port?
https://kbdfans.cn/products/coming-soon-kbd67-mechanical-keyboard-diy-kit
Offline Bahm78
    • https://blog.naver.com/hjg7808
« Reply #590 on: Tue, 02 April 2019, 21:16:30 »
Very nice design
Offline ptiede
« Reply #591 on: Tue, 02 April 2019, 21:29:22 »
I think from the pcb renders on the first page it looks like a middle usb port.
Offline kolyz
« Reply #592 on: Tue, 02 April 2019, 22:02:28 »
oof that gray aluminum actually looks nice!
Offline ian13
« Reply #593 on: Tue, 02 April 2019, 23:53:16 »
Is it too early to ask for the shipping method/shipping company that you will be using?
I suppose this will be manufactured in China so I'm wondering if it is possible to use DHL Express Worldwide so that delivery will be straight to my door/house instead of picking it up from the local post and end-up paying more for the customs duties in my country.  :(
Offline ninjacore
« Reply #594 on: Wed, 03 April 2019, 03:56:18 »
Split backspace, hotswap, with badge would be nice. I’ll solder if I have to, but wouldn’t mind the time savings.
Offline kolyz
« Reply #595 on: Wed, 03 April 2019, 09:10:35 »
Yeah agreed!
Offline oldcat
  • 65% is Life
« Reply #596 on: Wed, 03 April 2019, 11:27:23 »
Hey, only regular frost clear and gf-enhanced black PC
Offline oldcat
  • 65% is Life
« Reply #597 on: Wed, 03 April 2019, 11:29:16 »
It's possible but I believe DHL Express is more expensive for you in terms of shipping (I could be wrong). SF is so far cheapest I believe. If in some countries DHL is cheaper yet provides a better service we can certainly consider that.
Offline Zurg Eon
« Reply #598 on: Wed, 03 April 2019, 11:36:54 »
This is looking great!
A few questions:
  • Did you decide on white-yellow PCB based on the votes in the survey? This option might have gotten the most votes simply because it's the first option and you can't skip that question if you don't have a preference.
  • I am unsure if I'd rather have a PC or alu board. What would you recommend? Pros and cons?
  • Will the alu version have the 4.5mm, perfectly-cut PC Plate? If not, then I guess I'll prefer a PC board for the sound properties as you've mentioned, even though I've never typed on an alu board.
  • Will the Wavez keycaps only be available with the dark green alu board, or can we mix board colors and keycap options as we will? I think I'd rather have a black alu or frosted PC board with the Wavez keys.
  • What switches will be available to choose from?
  • How difficult would it be to modify the PCB to support Bluetooth, if it's even possible? I might get two boards if this is doable. I've never soldered before, but I believe I could get it done with instructions at least.
Sorry if any of the questions have already been answered.
Sincerely,
A noob.
Offline Sic_Alpha
« Reply #599 on: Wed, 03 April 2019, 11:57:27 »
A few questions:
GMK Wavez keycaps are currently live here: https://geekhack.org/index.php?topic=100063.0  They are not part of this GB
Switches will be purchased separately, not part of the GB; buy what you want to install onto it ;-)
Best bet for "modifying" it to use bluetooth would be something like this: http://handheldsci.com/kb/  Though I believe I remember oldcat saying a BT PCB may be an option in the future; I think I remember reading that.
« Last Edit: Wed, 03 April 2019, 12:00:29 by Sic_Alpha »
