Author Topic: E6.5 - 65% custom keyboard (GROUP BUY FINISHED )  (Read 326506 times)
Offline MatthewPham
Re: E6.5 - 65% custom keyboard
« Reply #100 on: Sat, 02 March 2019, 14:22:19 »
how does this work by the way? Will it end being a 'raffle' type if more than 100 people submitted a form?
fcfs
Offline foo4542
« Reply #101 on: Sat, 02 March 2019, 14:36:57 »
I'm in. The dark red fits my bill perfectly.
Offline Visionaire
« Reply #102 on: Sat, 02 March 2019, 14:37:59 »
Feels like this is going to be a very PC GB - and a lot of folks are going to get that first PC they've been wanting! Good stuff.
Offline Tekniqs
« Reply #103 on: Sat, 02 March 2019, 14:48:25 »
Offline Auxo
  • Formerly CJD_Anthony
« Reply #104 on: Sat, 02 March 2019, 14:48:47 »
Doubt it, itll likely be FCFS, then anyone else who fills the form after will be queued for a waiting list in case anybody drops out or is unable to pay.
Offline Tekniqs
« Reply #105 on: Sat, 02 March 2019, 14:51:37 »
btw...any one know how thick that PC plate is?
Offline Bryan
« Reply #106 on: Sat, 02 March 2019, 14:55:18 »
This the perfect 65% keyboard I've been looking for! Similar layout to my KBD67, but underglow/case supported!
Offline Hokabuki
« Reply #107 on: Sat, 02 March 2019, 15:17:15 »
Debating on whether I want the right blocker or not. Can’t decide which is the better aesthetic. Anyone going with Wingdings font?
« Last Edit: Sat, 02 March 2019, 16:02:17 by Hokabuki »
Offline oh_chesteroni
« Reply #108 on: Sat, 02 March 2019, 15:52:39 »
ordered :)
Offline eyedrop
« Reply #109 on: Sat, 02 March 2019, 16:08:58 »
What font are you guys choosing?  I want some idea.
Offline LiL_BrOwNiE247
« Reply #110 on: Sat, 02 March 2019, 16:10:39 »
I'd assume 1.5 mm unless specified otherwise.
Offline cattharsis
« Reply #111 on: Sat, 02 March 2019, 16:13:50 »
This is the font im going with: https://www.dafont.com/kiona-2.font
Something simple and clean.
Offline Tekniqs
« Reply #112 on: Sat, 02 March 2019, 16:26:52 »
OOOOF. will have to change plate material if it's 1.5mm pc
Offline darryq
« Reply #113 on: Sat, 02 March 2019, 16:28:57 »
will there be support for a split backspace?
Offline Puree
« Reply #114 on: Sat, 02 March 2019, 16:41:25 »
The supported layouts in the ic : https://i.imgur.com/c51Pa9t.jpg
 :thumb:
Offline Chimera
« Reply #115 on: Sat, 02 March 2019, 16:47:25 »
I submitted earlier today, but am having second thoughts about my plate choice. I want to make sure i'm still one of the first 100. If I want to swap from E-Black plate to PVD Rose Gold and submit a new form will my spot be pushed back, additionally, would it be easier for me to PM you for a minor change or just submit a new form? Also, is there compatibility with any other PCBs?
Offline Kevadu
« Reply #116 on: Sat, 02 March 2019, 17:03:22 »
I am incredibly uncreative and couldn't think of anything to put on the nametag so I just went with the default, but if I do change my mind later would it be possible to change that?
« Reply #117 on: Sat, 02 March 2019, 17:09:42 »
might have to go in just for that dark red
it is beautiful
« Reply #118 on: Sat, 02 March 2019, 17:10:56 »
The E6.5 uses a center port USB C pcb so it's unlikely there is any compatibility with readily available 65% pcbs
Offline Chimera
« Reply #119 on: Sat, 02 March 2019, 17:20:18 »
Good point then I'm going to keep the backup in my order then.
Still curious about the other question I had
Sent from my ONEPLUS A6003 using Tapatalk
Offline vtachkov
« Reply #120 on: Sat, 02 March 2019, 17:25:19 »
The zeal65 has a centered USB C, so I wonder if the E6.5 would be compatible with that. That might end up being really nice for the pc case.
Offline Ephemeral
« Reply #121 on: Sat, 02 March 2019, 17:26:39 »
Psyched. In for one.
Collection:
E6.5 (Lubed 50g MX Blacks) | Preonic (55g MX Clears) | CA66 (Zealios V2 65g) | budget96 (MX Red) | Infinity 60% (Zealios 78g) | Phantom TKL (Gateron Black) | MiniVan (Zealios 78g) | Helix (?)
[Incoming: Polaris (?) |  KBDFans 8X Mk II (v2 Tealios)]
Offline tipsyboo
« Reply #122 on: Sat, 02 March 2019, 17:40:04 »
I have a feeling I'm the only one going for winkey_no_blockers  :))
Offline excluisve
  • Making & Thinking.
« Reply #123 on: Sat, 02 March 2019, 17:56:41 »
Hi guys, just wake up i will post spreadsheet and reply one by one
thanks  .
Offline excluisve
« Reply #124 on: Sat, 02 March 2019, 18:05:59 »
Due to much people fill the form i will close it at  8:00pm (EST)
thanks everyone
Offline JubJubCity
« Reply #125 on: Sat, 02 March 2019, 18:08:05 »
In for a PC can't wait
Offline Sic_Alpha
« Reply #126 on: Sat, 02 March 2019, 18:10:34 »
thanks everyone
Popular!  I submitted a second to update/modify/replace my first order.  Understood that this is how you wanted us to update; just saying because it probably inflated the count a bit with others doing the same.
Offline oldcat
  • 65% is Life
« Reply #127 on: Sat, 02 March 2019, 18:57:52 »
thanks everyone
Congrats! I really love those e-coat ones.
Offline soveryscary
« Reply #128 on: Sat, 02 March 2019, 19:05:13 »
Is there any way to edit my form? I submitted it too early, meant to hit back.
All the lights went out
Offline Tekniqs
« Reply #129 on: Sat, 02 March 2019, 19:05:37 »
thanks everyone
same...i had to submit a second form to modify the original form.
Offline MTXjunkie
« Reply #130 on: Sat, 02 March 2019, 19:09:56 »
I’m sad I didn’t see the closing and I’m happy I didn’t see the closing. I probably would have put in a second order if I would have gotten in under the deadline
Sent from my iPhone using Tapatalk Pro
Offline Oakelfire
« Reply #131 on: Sat, 02 March 2019, 19:19:41 »
Absolutely in for two. Folks, don’t snooze on this one. I’ve been along for every Exclusive run and dude does it all right. Get in early and often! I have a hunch spots are going to fill quickly (<24 hours?) for this one.
We didn't even make it 12 hours! ;D
Lots of people picking up 2 as well - probably hit the limit real quick!
Offline JubJubCity
« Reply #132 on: Sat, 02 March 2019, 19:27:38 »
Hoping I made it in time!!
Offline click clack jack
« Reply #133 on: Sat, 02 March 2019, 19:49:00 »
I ordered red for a Jamon build. PC plate. Black name badge for pata negra. And sandblast A weight with black B weight  ;D
Offline nickaster1
« Reply #134 on: Sat, 02 March 2019, 19:51:00 »
I just went with E white and rose gold badge/weight. Actually have second thought about changing to Grey or MAO so it doesn’t overshadow my Tulip set
Offline foo4542
« Reply #135 on: Sat, 02 March 2019, 20:33:16 »
thanks everyone
Lucky all of a sudden I woke up in the middle of the night and submitted an entry.
Offline excluisve
« Reply #136 on: Sat, 02 March 2019, 20:47:37 »
I am sort the spreadsheet cancel the repeat one
plz be patient wait me to post when done
Offline nickaster1
« Reply #137 on: Sat, 02 March 2019, 21:03:59 »
Yeah I also made second form on top of the first one since I couldn’t decide
Offline Oakelfire
« Reply #138 on: Sat, 02 March 2019, 21:08:38 »
If you have any questions - send me a PM! I ordered 2 boards - don't want to have one canceled. :)
Offline geistmate
« Reply #139 on: Sat, 02 March 2019, 21:09:53 »
Where are those pink keycaps from?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #140 on: Sat, 02 March 2019, 21:13:51 »
thanks everyone
Wow, that went super quick, congrats man! Glad I didn't wait to fill the form out, here I thought I was all super early since the GB was stated to run till the 9th. :)) Now I got my fingers crossed I actually got in before 100 orders were submitted & I can get one! :blank:
Offline wt5now
« Reply #141 on: Sat, 02 March 2019, 21:15:30 »
See the PM plz.
Offline nickaster1
« Reply #142 on: Sat, 02 March 2019, 21:19:00 »
thanks everyone
I think this GB is among one of the faster ones that he’s done over time. E7 didn’t all fly out like this if I remember correctly
Offline Starius
« Reply #143 on: Sat, 02 March 2019, 21:30:01 »
I am in the same situation.
Due to how exclusive and desirable these boards are, I would feel lucky to get just one.
But I've tried for a 2nd board as a gift for someone who has had rotten luck with keyboards for years and has never known the high end customizable keyboard community existed until just recently.  I thought this might be the key for him to step into a whole new world...  ;)
Offline eyedrop
« Reply #144 on: Sat, 02 March 2019, 21:45:42 »
You're a good friend, hope you will get the second order.
Offline vtachkov
« Reply #145 on: Sat, 02 March 2019, 21:50:32 »
I'm in for two as well. Couldn't keep my hands off em. Love that e-white and RGB polycarbonate.
Offline oldcat
  • 65% is Life
« Reply #146 on: Sat, 02 March 2019, 21:59:06 »
Good choice!
Offline excluisve
« Reply #147 on: Sat, 02 March 2019, 22:03:24 »
Orders check
https://docs.google.com/spreadsheets/d/1IwRaVVonheMmkqS1j02I3lflphKK55sutiRbX7XznwE/edit?
usp=sharing
I havent edit the spreadsheet just cancel the repeat one ,i will check each message and edit it
There have been almost 300 forms submitted. Several are likely duplicates, but we have far exceeded the 100 I intended. I am honor all who are in. Your support is awesome and I don’t want anyone who has submitted to miss out. This means the later orders may be slightly behind the others in shipping, but I will fulfill all orders.
thanks everyone who submitted! :thumb:
Offline JubJubCity
« Reply #148 on: Sat, 02 March 2019, 22:06:11 »
Orders check
usp=sharing
You are amazing, thank you for honoring all who have submitted. I can't wait to pay!!!! :thumb:
Offline Oakelfire
« Reply #149 on: Sat, 02 March 2019, 22:09:46 »
Orders check
usp=sharing
Awesome, thanks excluisve!
