Author Topic: E6.5 - 65% custom keyboard (GROUP BUY FINISHED )  (Read 330174 times)
Offline nephlock
Re: E6.5 - 65% custom keyboard
« Reply #50 on: Sat, 02 March 2019, 10:34:56 »
It’s my birthday today and I think this will make a fine present :P. Hopefully we can edit the form later... picking a name tag font is gonna take a bit! I’m in!
Offline donut_sauce
« Reply #51 on: Sat, 02 March 2019, 10:37:57 »
in for a poylcard wkl. went in for a gold weight but curious if e-white would look good. what color weights are y'all polycarb folks choosing?
Offline MTXjunkie
« Reply #52 on: Sat, 02 March 2019, 10:39:20 »
I went e-white all the way around and a second PCB with poly plate.
Sent from my iPhone using Tapatalk Pro
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #53 on: Sat, 02 March 2019, 10:40:43 »
Same as others - I would love a chance to update the badge font / text.
Confirmed- can edit text/ font after submitting. He’ll just do that by PMs.
Offline justjimmeh
    • Reddit Profile
« Reply #54 on: Sat, 02 March 2019, 10:40:54 »
Thanks for the help all, went for e-white :)
Offline Oakelfire
« Reply #55 on: Sat, 02 March 2019, 10:42:07 »
Awesome. I got my second one squared away but need to update the first one.
Offline ChrisSwires
« Reply #56 on: Sat, 02 March 2019, 10:42:09 »
Could someone explain that gasket to me? The board is top mount (?) but the gasket is underneath the plate? So is it top and sandwich or is the gasket not compressed and it's just chilling between the plate and PCB for... Reasons?
Sent from my Pixel 3 using Tapatalk
Offline wellbeing44
  • kebord good kebord fun yum yum
« Reply #57 on: Sat, 02 March 2019, 10:46:31 »
You're pressing down on the gasket when you type.
Offline ChrisSwires
« Reply #58 on: Sat, 02 March 2019, 10:47:19 »
It's top mount, so not really unless you half tighten the screws?
Offline taropaste
« Reply #59 on: Sat, 02 March 2019, 10:55:39 »
He clarified in the IC thread. It can be either normal top mount or gasket mount. He indicated he designed the gakset implementation to be identical to the 356mini.
Offline Morgan3Wheeler
« Reply #60 on: Sat, 02 March 2019, 10:55:50 »
Just submitted my order!!!!!!!!!!!!!!
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline ChrisSwires
« Reply #61 on: Sat, 02 March 2019, 10:58:59 »
Ok so I guess in order to build it gasket you simply don't use the top mount screws, and the top mount wings serve as the sandwich to compress the gasket against those square standoffs. Or you leave it out and just top mount.
That makes sense, thanks, distinct lack of info on the construction above!
Offline AgonizedFish
« Reply #62 on: Sat, 02 March 2019, 11:00:56 »
Just submitted my form! I would love to be able to see the final form to make sure I got everything right, and possibly edit my nametags if I decide to change the ones I've chosen!
Offline taropaste
« Reply #63 on: Sat, 02 March 2019, 11:15:03 »
Hi Exclusive. Can we buy extra gaskets with our order?
Offline Sic_Alpha
« Reply #64 on: Sat, 02 March 2019, 11:16:33 »
Concur with wanting the ability to see final submission to ensure I got everything correct.  Thanks!
Offline oldcat
  • 65% is Life
« Reply #65 on: Sat, 02 March 2019, 11:19:05 »
Pretty sure it will be posted later
Offline excluisve
  • Making & Thinking.
« Reply #66 on: Sat, 02 March 2019, 11:19:27 »
just prepare the font links and letters
i will change one by one tomorrow 10:00am (GMT+8) just leave me message will reply when wake up (sorry too later now )
if you want change you orders just fill  again and leave is final
thanks all
Offline nickaster1
« Reply #67 on: Sat, 02 March 2019, 11:27:39 »
Do normal colors like wathet and dark red feel the same as e white or e black? Dunno if I should go Grey + rose gold or Black + rose gold
Offline Oakelfire
« Reply #68 on: Sat, 02 March 2019, 11:31:32 »
thanks all
Would love to see an order summary too so we can make sure we got everything correct!
Thanks exclusive!
Offline excluisve
« Reply #69 on: Sat, 02 March 2019, 11:42:59 »
thanks all
Thanks exclusive!
Sure tomorrow morning I will post spreadsheet then orders can check .
Offline tipsyboo
« Reply #70 on: Sat, 02 March 2019, 11:44:15 »
thanks all
Thanks exclusive!
same
Offline Visionaire
« Reply #71 on: Sat, 02 March 2019, 11:45:51 »
First PC custom for me!
Offline cattharsis
« Reply #72 on: Sat, 02 March 2019, 11:46:07 »
Can't wait for this to arrive!
Offline yur1orlov
« Reply #73 on: Sat, 02 March 2019, 11:50:49 »
Nice, first PC board for me
Keycult no1rev1 | Keycult no2rev1 | Jane v2 Blue Grey | Kyuu x2 | QXP | Rukia
Offline ContaxS2
« Reply #74 on: Sat, 02 March 2019, 11:51:06 »
Submitted for 2, PC and Grey!!!!
Offline Sic_Alpha
« Reply #75 on: Sat, 02 March 2019, 11:52:08 »
Looks like I'll be joining the group wanting to update/modify my order...  Funny how the more I look at the options, the more I want to change it  :p
Offline ContaxS2
« Reply #76 on: Sat, 02 March 2019, 11:58:33 »
everyone seems to have just blew through the form to get a spot and didnt take time to think about options all that much, cant really blame you guys though this one is awesome
Offline donut_sauce
« Reply #77 on: Sat, 02 March 2019, 12:10:50 »
All e-white is a good move. any keyset will look awesome on that
Offline Aox
« Reply #78 on: Sat, 02 March 2019, 12:13:14 »
Would like to be able to specify my second plate as half plate, other than that, in for dark red with black!
Offline BAS1C
« Reply #79 on: Sat, 02 March 2019, 12:16:19 »
Hey exclusive, any pics of rose gold on PC?
Offline Olitender
« Reply #80 on: Sat, 02 March 2019, 12:18:36 »
Hopefully, I get an invoice. In for polycarbonate, with brass everything.
Going into heat.
Offline mrpetrov
« Reply #81 on: Sat, 02 March 2019, 12:22:19 »
Filled out the form for PC and rose gold brass everything.
« Reply #82 on: Sat, 02 March 2019, 12:30:30 »
Filled out for a full PC.
Offline tunadesu
« Reply #83 on: Sat, 02 March 2019, 12:39:47 »
Filled out my form this morning! Went with E-White and black badge as well as a wathet and rose gold badge to match different keysets to swap out.
Offline roostrc0gburn
  • its just plastic
« Reply #84 on: Sat, 02 March 2019, 12:48:42 »
What is the difference between e-white and MAO?
E-white is electrocoated, which is a paint coating method where the object to be coated is dipped in a bath and then has an electric charge applied, attracting the paint.  Used a lot of automotive, tends to give a very even high quality coating over complex shapes.  Think powdercoating but better.  Electrocoated white can be a very true pure white.
MAO is microarc oxidation, which is a electrochemical treatment very similar to anodization, but with much much higher voltages.  This makes a much thicker oxidation layer than standard ano.  You can get close to white with MAO, but not all the way, it tends to look grey-ish.
ok, so e-white is powdercoated. mao is still an anodization process. got it
Offline eatRAMEN
  • secret society: BLANKET
« Reply #85 on: Sat, 02 March 2019, 12:49:57 »
wow there are so many different options, amazing work!!! Wanted a No.1 65 but so tempted to jump on a polycarb WKL 6.5 :)
Offline ContaxS2
« Reply #86 on: Sat, 02 March 2019, 12:58:40 »
Does this just close after 100 forms are submitted or how does the next step in the process work, this will be my first gb here on geekhack :)
Offline bball2
« Reply #87 on: Sat, 02 March 2019, 13:01:21 »
Went with PC WKL + Red half plate + Blue/red weight + Extra nameplate  :thumb:
Offline LiL_BrOwNiE247
« Reply #88 on: Sat, 02 March 2019, 13:01:52 »
In! Excited for my first PC board  :D
Offline oldcat
  • 65% is Life
« Reply #89 on: Sat, 02 March 2019, 13:02:44 »
I think PC without brass will be too light
Offline Kevinah
« Reply #90 on: Sat, 02 March 2019, 13:05:30 »
In for a PC. Can anybody comment on the sound signature of a Polycarb? I'm looking for a deeper sound in a keyboard (only owned Alu cases) and I heard that Polycarb can provide that? If it helps I went with brass everything else (wanted some heft)
Offline donut_sauce
« Reply #91 on: Sat, 02 March 2019, 13:13:57 »
was there a weight given on the polycarb prototype vs aluminum prototype?
Offline Sic_Alpha
« Reply #92 on: Sat, 02 March 2019, 13:14:32 »
So we just submit another form if we want to change order and put reference to first and “final” in comment? Seems like that would affect 100 count
Offline Regret
  • I regret nothing
« Reply #93 on: Sat, 02 March 2019, 13:35:47 »
In for Polycarb!
No.2 Rev.1 | Gat Black Inks | OG Dyesubs \\ No.1/65 Silver & Brass | Retooled Cherry Blacks | GMK Coniferous \\ Ai03 Lunar | SKCM Blues | AEK \\ Aeryx Aegis 1800 | C3 Tangerines | GMK WoB
Offline oldcat
  • 65% is Life
« Reply #94 on: Sat, 02 March 2019, 13:55:20 »
Still kind of feel the polycarb version has too many screws. E-coat looks much better
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #95 on: Sat, 02 March 2019, 13:56:43 »
Just filled my order out! That polycarb version is super tempting, but I ended up going alum. wkl. I picked dark red top/bottom, brass PVD full plate, white A weight, dark red B weight, with a white name plate that's gonna have my user name on it, & an extra blank nameplate in white. I think this board will be the perfect home for my set of GMK Jamon & that is what I chose my colors around. Gonna wait on the Think6.5 to be my first polycarb board. :thumb:
Offline Sic_Alpha
« Reply #96 on: Sat, 02 March 2019, 14:02:08 »
Submitted a second form to update/modify/replace my first order...
Offline Tekniqs
« Reply #97 on: Sat, 02 March 2019, 14:06:10 »
PC or bust! PC case/plate, brass weight A and e white for weight B...hopefully that comes out well lol.
edit: ahh damn, read the first page and turns out the weight prices is combined as shown. I thought they were separate. sbumitting  a modified order. sorry about that!
« Last Edit: Sat, 02 March 2019, 14:14:00 by Tekniqs »
Offline eyedrop
« Reply #98 on: Sat, 02 March 2019, 14:17:56 »
So many PC lover around here.   :cool:
Offline Tekniqs
« Reply #99 on: Sat, 02 March 2019, 14:19:26 »
how does this work by the way? Will it end being a 'raffle' type if more than 100 people submitted a form?
